First gen 5.3 swap.
Old 03-01-2008, 12:16 PM   #101
s10 newb
horsepwraddict's Avatar
horsepwraddict is on a distinguished road
Re: First gen 5.3 swap.
Quote: Originally Posted by s10-den
will ya hurry up already?...hehe,great progress
ya ya ya. trust me, i want nothing more than for this thing to be done. I do what i can when money allows, trying to leave small stuff to do for when i dont have money to spare.
Old 03-03-2008, 01:20 PM   #102
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
shit man,we all do what we can.......i have been "planning" the swap for who knows how long now,stuff always comes up seems like...I got lots of parts, a truck,but thats about it..lol
Old 03-03-2008, 01:38 PM   #103
9.88@140.86
Black X's Avatar
Black X is on a distinguished road
Man that thing is coming along great... I really need to spend more time checking out these build threads... GREAT WORK!
Old 03-09-2008, 06:43 PM   #104
s10 newb
Stripped the rear end down.
Rebuilt the Traction-Lok. Alternated and stuffed more discs into it so it should grab pretty hard.
Installed Ford Motorsports 11" drum brake kit, still need to get drums.
Got the rest of my gauges and just about got the truck wired. Check out the cyberdyne digital
Speedo/Tachometer gauges. I like it.
Old 03-10-2008, 12:31 AM   #105
Banned
LS2Sonoma is on a distinguished road
nOice!
Old 03-11-2008, 09:48 PM   #106
s10 newb
gauges/switch panel in and wired up. just need to get the rear end in to get the speed sensor hooked up.
Old 03-12-2008, 10:46 PM   #107
camaro1 is on a distinguished road
good idea running the speedo from the 8.8 abs sensor, will your speedo program to this type of signal?,
Old 03-13-2008, 10:31 AM   #108
s10 newb
it will drive it, my only concern is that it wont put out enough voltage at low speeds, but it 'should'. If it doesn't, i may just give in and put speedo gears in my tranny (doesn't have any) and run the adapter. I called cyberdyne and they said they have yet to find a vehicle with a factory speed sensor/abs sensor that wouldn't work with their speedometer.
Old 03-15-2008, 11:49 AM   #109
s10-den's Avatar
ready for takeoff?looks like a cockpit of a 747 with all those gauges and switches...ha
Old 03-16-2008, 09:21 PM   #110
s10 newb
welded the axle tubes and put the rear end in today.
Old 03-18-2008, 04:07 PM   #111
All up in your shit
jakethegriff's Avatar
jakethegriff is a jewel in the roughjakethegriff is a jewel in the roughjakethegriff is a jewel in the rough
man, this is looking great! I can't beleive i didn't see this before!
Old 03-18-2008, 06:27 PM   #112
HemiChallenger's Avatar
HemiChallenger is on a distinguished road
Great thread. What are you planning for headers.
How much wider is the explorer axle? I've heard that they are like 3" wider?
With the fuddle converter, I'm not knocking you or anything. BUT having seen many of them on the chassis dyno next to many other converters and they dont perform very well.
Also someone mentioned the beehive springs earlier I'd HIGHLY suggest those with stock retainers and stock rocker arms as long as your staying with a hydraulic(sp?) roller. I'd also be curious to hear your cam specs.
Old 03-19-2008, 10:56 AM   #113
s10 newb
-Im using '98 F-body manifolds for the exhaust.
-The explorer is overall about 5-6" wider from wheel mount surface to wheel mount surface.
-As far as the converter goes, i bought it from fuddle because i heard nothing but good things about them over on LS1Tech.com and took advantage of their holiday sale and got a good deal on it.
-Im running Scoggin Dickey's drop in springs, stock retainers and rockers. The cam is a Thunder Racing TR220-114
Old 03-21-2008, 02:27 PM   #114
s10 newb
mounted my tranny cooler and ran the lines. The cooler hangs down below the bumper a little, plenty of air flow but im afraid it might be a bit vulnerable. I think bending up tranny lines is my new favorite thing to hate...royal pain in the butt.
also mocked up the exhaust manifolds, these f-body manifolds fit better than the swap headers did with my SBC.
Old 03-21-2008, 04:30 PM   #115
s10 newb
drilled and tapped the water pump for the coolant crossover tube.
Old 03-21-2008, 05:33 PM   #116
s10-den's Avatar
if you could/would,get a pic of the passenger side how close it is to the cab???....
Old 03-29-2008, 01:30 PM   #117
s10 newb
made a y-pipe. 2.25" mandrel bends with v band clamps. Its going to be a single 3" out the back exiting in the stock location w/ a magnaflow 3" cat and summit fully welded muffler.
Old 03-29-2008, 10:52 PM   #118
brakenit's Avatar
brakenit is on a distinguished road
That Y pipe looks nice.
I like the front tires too, doing a front wheel drive conversion?
Old 04-02-2008, 12:29 AM   #119
What to put here?
slam is on a distinguished road
So how about a little more info on these f-body hedders.Plz.
Old 04-02-2008, 12:41 AM   #120
s10 newb
not much to tell really. They are just stock manifolds off a '99 F-body. I cut the flanges off, welded a 2.25" pipe into the end (fits perfect after cutting the flange off) and put a flange on the end of the extension.
Old 04-05-2008, 04:53 PM   #121
s10 newb
didn't really like the sharp 90* merge. I took a piece of 3" pipe and put it in the vice untill it was 2.25" wide, slid it over the y-pipe, marked it, cut it and welded it on. Its not a whole lot better, but it sure wont hurt.
Old 04-05-2008, 05:40 PM   #122
s10-den's Avatar
no job is ever complete with out bandaids....
Old 04-05-2008, 08:01 PM   #123
s10 newb
'tis the truth.
Old 04-06-2008, 06:02 PM   #124
JJ's Automotive
SoLowXtreme's Avatar
SoLowXtreme is an unknown quantity at this point
any pics of the passenger side Manifold on ?
Old 04-06-2008, 06:35 PM   #125
s10 newb
Keep in mind, i have a little more room around the firewall than most people. My motor is also set ALL the way back, the driverside head actually just barely touches the firewall. The picture of the control arm isn't very good either, their is more room than it looks, its still clost though.
Old 04-06-2008, 08:07 PM   #126
s10-den's Avatar
plus the flanges are still on there,unless your not cutting them off...
Old 04-06-2008, 08:08 PM   #127
s10 newb
nope, cut them off and welded extensions on.
Old 04-06-2008, 08:26 PM   #128
s10-den's Avatar
how much more room did it give ya?
Old 04-06-2008, 08:31 PM   #129
s10 newb
I probably could have used the stock flange on the passenger side, on the driverside i had to cut it off just to get the manifold into place though.
As far as control arm clearance, i think i might go with speedway motors tubular control arms down the road which will help with clearance alot. In the mean time i think i might fill the mounts with poly urethane to stiffen them up a little and run an engine limiter to keep movement down.
Old 04-06-2008, 09:04 PM   #130
s10-den's Avatar
for the passenger side manifold next to the cab?What, about another 3/4 inch space?
Old 04-06-2008, 09:14 PM   #131
s10 newb
sorry, i dont understand what your asking?
Old 04-07-2008, 06:59 AM   #132
s10-den's Avatar
when you cut the flange off,how much more room is there between the cab and the pipe you welded on the manifold now versus when the flange was on there
Old 04-08-2008, 09:26 AM   #133
s10 newb
oh, i gotcha. Just like it looks, about another .5". Not a whole lot, but it is some, depends how you weld the extension on too. Obviously.
Old 04-08-2008, 11:12 AM   #134
JJ's Automotive
