First gen 5.3 swap.
Old 11-16-2007, 02:48 PM   #51
s10 newb
horsepwraddict's Avatar
horsepwraddict is on a distinguished road
Re: First gen 5.3 swap.
Dropped the motor in today to mock up some stuff and check all clearances.
I made the notch a litte bigger than i had to but whatever, nothing with this truck has ever been the same as other v8 dimes so maybe you shouldn't use mine as an example LOL
Look at all this room i made in the tunnel. You v8 s10 guys will appreciate it.
Old 11-16-2007, 05:50 PM   #52
s10 newb
finished the last hole on the firewall too.
Old 11-16-2007, 09:10 PM   #53
jeffrobaum's Avatar
jeffrobaum is on a distinguished road
When you get the carb/air cleaner and the hood on will ya give me an guestimate of how much clearance there is from the bottom of the hood to the air cleaner please?? I just got a 1gen and thinking of going this route also..
Old 11-16-2007, 10:43 PM   #54
s10 newb
sure, i will slap it on tomorrow and rest the hood on to let ya know. It didn't fit with my old 355 and i dont think it will with this motor either....but i will check.
Old 11-17-2007, 12:00 PM   #55
camaro1 is on a distinguished road
you should have plenty of hood/air filter clearance, i have a 14" x 3" airfilter on mine and the stock hood closes fine
did you mock up the engine/trans together so you can keep your original driveshaft length?, i dropped in the engine/trans, hooked up the driveshaft and where ever the engine ended up is where i bolted it down
also a 99 or newer malibu brake booster will give you way more clearance for the drivers side valvecover/ coil packs, check out the space between the brake booster and coil pack now
Old 11-17-2007, 12:44 PM   #56
s10 newb
I didn't have the tranny in, but because of the two piece driveshaft, i have room to play. Between where the yoke goes into the tranny, and the slip joint behind the carrier bearing i should have enough room to get my driveshaft to work. If not....i will just have to get it lengthed or shortened accordingly.
I was wondering about the coils. Its a damn tight fit in their. Does the malibu booster bolt right up? Its not neccesary though is it? I know others who have been able to fit the truck coils in without a different booster.
I still have to figure out what im going to do for accesorie brackets. Im not running power steering and i dont want the alternator on the driverside so i dont know what im going to do. Any ideas?
Old 11-17-2007, 01:18 PM   #57
without changing the brake booster you will have to re-locate the rear coil,, the malibu brake booster is almost a bolt in swap, just have to put the s-10 rod on the malibu booster(cut off and re-weld 15 min job)
easiset set up is like mine, truck bracket with the bottom 1/2 cut off(manual gear box here also), why do you not want the alt on the drivers side
Old 11-17-2007, 01:27 PM   #58
another thing i just noticed, you are missing a dowel pin on the back of your engine,, make sure you get a new one in there or you will have major trans issues
Old 11-18-2007, 06:15 PM   #59
s10 newb
did some wiring removal. Only left the wipers, headlights, brake lights and blinkers,
This is all thats left.
Old 11-18-2007, 10:53 PM   #60
Electronics Guru
outtowinpahc's Avatar
outtowinpahc is on a distinguished road
Nice progress, it looks much better
Old 11-21-2007, 04:33 PM   #61
More Go then Show
THEKING's Avatar
THEKING is on a distinguished road
now that was a rats nest holy crap
Old 12-13-2007, 11:52 PM   #62
s10 newb
removed the bed. ground off the second bed mount pedestals, bump stops and rear cross member. Going to make a new, more compact crossmember. Will do the same for the front gas take cross member.
Got my Fuddle Racing Converter
245mm
ls1 pilot
3k stall
Got some new shoes too.
Centerline Warriors. 15x4 up front and 15x8 in the rear with ET Streets
Old 12-15-2007, 03:14 PM   #63
s10 newb
made this to stiffen up the rear frame rails.
Old 12-16-2007, 02:03 PM   #64
m007gunit's Avatar
m007gunit is on a distinguished road
Looking good so far. I am curious to see what it is gonna run.
Old 12-16-2007, 04:00 PM   #65
s10 newb
me too...hopin for mid 12's if i can pull a respectable 60'
Old 12-16-2007, 05:37 PM   #66
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
you doing the blazer gas tank conversion?
Old 12-16-2007, 10:43 PM   #67
you will have no problem running that number,,
Old 12-17-2007, 10:15 AM   #68
wlsmoku is on a distinguished road
good work man, keep the pics rollin in!
Old 12-17-2007, 05:19 PM   #69
s10 newb
fuel cell.
Old 12-29-2007, 01:18 PM   #70
s10 newb
the hollidays are over so time allows again. Got a bunch of parts ready to go in.
Summit -6 Pushlock hose
fittings
Quick-fuel regulator
Moroso fuel filter
Holley Blue pump
Sport comp Oil pressure and water temp gauge
Autogage Tach
Moroso switch panel
Russel carb inlet fittings
Holley 650dp
Old 01-09-2008, 02:00 AM   #71
twisselman1968 is on a distinguished road
looks good man how much ground clearence does it look like your going to have I looked into doing a LS1 swap but my trucks full drop and I was afraid with the LS1 pan I would have to hog to much cross member and with the truck pan I'd bottom out all the time
Old 01-09-2008, 11:29 AM   #72
s10 newb
i have alot, mainly because i dont run a low truck though. The oil pan sticks about an inch below the crossmember, maybe not even that much. You could always build a small skid plate for the oil pan.
Old 01-10-2008, 02:21 PM   #73
s10 newb
got the dash in the other day, got the switch panel in and took my locker out.
Got an 1998 Explorer 8.8, 3.73's, track lok or whatever ford uses, 31 spline axles and disc brakes for 100 bucks. Im pretty happy.
Old 01-11-2008, 02:19 PM   #74
s10 newb
cut the swaybar and shock mounts off the rear.
Old 01-13-2008, 03:08 PM   #75
s10 newb
Made my own distribution block and started wiring up the panel.
Old 01-24-2008, 02:45 PM   #76
s10 newb
got my springs and ordered a big 'ol aluminum radiator.
made my own spring tool, insteead of paying 100+ dollars for the same thing, had the springs done in 45 minutes tops.
Old 01-24-2008, 06:38 PM   #77
What to put here?
slam is on a distinguished road
I like that! lol Nicety the mother of invention.
Old 01-24-2008, 07:54 PM   #78
2500avalanche is on a distinguished road
When you took the dash out, where were the main bolts to take it out? any hints that might help me (I have to take mine out...)
Old 01-24-2008, 09:45 PM   #79
s10 newb
their are 4 or 5 small screws along the top at the base of the windshield and two large ones on the bottom of the dash, one on each side. Sometimes its still a pain to take it out, just make sure everything is unplugged and be patient. It may take some persuasion.
In this picure you can see a tab above the e-brake pedal, thats where one of the larger bolts goes through on the bottom, its in the same location on the other side.
Old 01-24-2008, 10:01 PM   #80
What to put here?
There is one hidden around the steering column to... Its on the side kind of....You should be able to find it pretty ez tho.
Old 01-25-2008, 10:55 AM   #81
s10 newb
got my tranny cooler this morning. This thing is badass.
Old 01-27-2008, 06:08 PM   #82
s10 newb
Got a big 'ol radiator too. This thing is massive (for an s10 anyway) measuring in at 19x31. Im going to have to cut the bottom of the core support out and notch the frame rails.
Its a summit brand radiator but it says Northern right on it, so its a really nice piece for the price.
Old 02-01-2008, 05:04 PM   #83
s10 newb
Here's the broken spring.
Picked up a brand new set of leafs from a friend, returned the polyurethane bushings as these came with new ones in them.
it looks empty, picking up u-bolts tomorrow morning. Should have the rear end in tomorrow morning, then i need to make shock mounts.
