s10 newb
First gen 5.3 swap.
Picked up a 5.3 from an '00 fullsize for the dime a few weeks ago. Its gettin carbed with my 650 demon and using the TH350 that was behind my 355. If money allows i will throw a cam in it but we'll see.
THe before: ![]() Motor out. ![]() ![]() INterior out ![]() ![]() The new bullet. ![]() Made room for the exhaust, cut the seem out and made more room to get at the bellhousing bolts. ![]() ![]() ![]() |
takes 2 balls in our game
Re: First gen 5.3 swap.
I see a motorless truck.I see a 5.3 sittin on the ground......------oh,and then he takes a perfectly good v8 s10 apart??????...lol
His sig says he has a 5.3L S-10 already, this must be his 2nd one.
s10 newb
ahhh shut up, you know what i mean LOL
EDIT: is that better Last edited by horsepwraddict : 10-14-2007 at 01:11 PM. |
s10 newb
i need something to do this winter. ![]() |
i hear ya...I"used" to take apart good running trucks myself,well,still do sometimes...ha
s10 newb
its ok as long as your making things better...and IMHO i am. Im giving up a few ponies but i can deal with it for a smoother, more reliable running truck.
Banned
Location: edmonton, alberta, canada User is: OffLine ![]() |
wholy firewall fabrication! youre not messing around with this swap...
s10 newb
fixed a small rust hole in the floor neer the seat stud and sealed up all the seams, next comes paint, bonding the firewall and painting it black. Then i have to notch the cross member for the oil pan. |
Banned
well, it sure as hell beats hammering the firewall for extra clearance
keep the pix comin! |
is it necessary to cut the fire wall like that or is that just something you wanted to do? looking to maybe do a similar project
s10 newb
no, its not neccesary, i just dindt like not being able to get at the bellhousing bolts with my old small block, so i figured i would make it easier on myself this time around. The exhaust was also way closer to the firewall/floor than i liked, it melted my carpet at one point so i made a little more room doing this also.
s10 newb
sold the top end off my 355 and bought a TR220 cam, comp springs and pushrods for the 5.3, should put me at around 365fwhp with a good idle im hoping.
s10 newb
finished up a few spots and sealed the seams. Still have to fix that uhhh...thing up in the upper left corner. Its not the prettiest but it works. Their is tons more room to work now.
Sorry for the shitty pictures ![]() ![]() |
I cut the top part out of one of mine one time so i could get to the bell-bolts.And actually thought about doing something like that but never did.More room for the hands,thats for sure.Just dont go crazy....
s10 newb
nah, not goin crazy. What i did should leave plenty of room for the bell bolts, i did it for exhaust clearance too. I dont know if my truck was different or something but with my old motor the passenger side header was so clost i couldn't hammer it enough, i had to cut the flange off the header and weld an extension onto it.
s10 newb
not much to show for today, just pulled the intake thats all.
s10 newb
de-accesorized the motor, cleaned it up a litle bit and got one valve cover painted...gunmetal, i dont know if i like it, might get them powdercoated
![]() ![]() shot the firewall to keep it from rusting ![]() |
bank owned
Interesting project. Good luck with the build!
s10 newb
cleaned up the motor a little today, I will finish painting when the timing cover is off for the cam
![]() Thunder racing cam, pushrods and comp dual springs came today too ![]() Should i paint the heads black too or leave them natural? |
why would you put the dual springs on the 5.3 heads,, any beehive ls1 spring is a drop in for your heads, probly cheaper and you could use your stock retainers and keepers
and if you are going to be revving this engine up you should at least put a gm LS2 timing chain on it , they are only $40 (use your stock gears) and shim your oil pump spring .100"-.120" for a little more pressure at high rpm i started with a 5.3 and a hotcam, and it loved to rev over 6500,, and the hotcam is a very small cam what syle spacer are you going to use for the trans? Last edited by camaro1 : 10-26-2007 at 06:30 PM. |
if i was you,i would not get ANYTHING on the table!!!!lol
s10 newb
#24 |
s10 newb
#25 |
the table with the cam sitting on,howd you get away with that??
#26 |
s10 newb
#27 |
what are the specs on the cam?
#28 |
dont forget the new bolt for the balancer pulley, it is a one time only bolt, and there is a several step procedure to install and torque it correctly
#29 |
s10 newb
#30 |
s10 newb
PS, did you get my payment? |
#31 |
i didnt even realize till now that it was you from ls1.com,,, yes i got it friday and i willl ship out your parts monday from work and i will send you the tracking number, jay |
#32 |
s10 newb
yup, its me...thanks. |
#33 |
s10 newb
well i just opened the springs to check them out and their are 3 missing retainers, i bought the cam used and he threw the springs in extra so im not to bummed.
looks like im goin beehives afterall |
#34 |
