Fire In The Hole
Old 09-22-2009, 10:12 PM   #1
NCRides's Avatar
Fire In The Hole
well the first attempt to start it wasn't a complete failure, at least it tried to run. It only fires momentarily as soon as turning the key but won't fire after that
Old 09-22-2009, 10:19 PM   #2
LS2Sonoma's Avatar
Re: Fire In The Hole
VATS disabled?
Old 09-22-2009, 10:21 PM   #3
NCRides's Avatar
I believe Jared did when he programed it
Old 09-22-2009, 10:27 PM   #4
LS2Sonoma's Avatar
not sure what else it could be until you get a scanner on it
Old 09-22-2009, 10:33 PM   #5
turbobandit's Avatar
stock sized injectors?
Try unplugging your TPS and restart it.
MAF plugged in?
Old 09-22-2009, 11:01 PM   #6
On da bottle
zx9rgreen's Avatar
Sounds like the typical VATS, Have you verified Fuel Pressure?
Old 09-22-2009, 11:10 PM   #7
NCRides's Avatar
I'm going to put a pressure gauge on it in the morning, the house is starting to smell of gas and the girls are gagging
Old 09-22-2009, 11:13 PM   #8
Fvck New Jersey
Tim99Zr2's Avatar
tell them to go outside. haha. good luck!
Old 09-23-2009, 01:06 AM   #9
WTF!!!!
Xtremechubs's Avatar
I worked on a 03 yukon denali with a 6.0 and if you let it sit for 30mins or so it would start and run for about 2 seconds then it would die and just crank and do nothing. if its doing this then it is probably your fuel pump as it was with his and if it starts everytime then comes up to about a grand then shuts off its your vats.
Old 09-23-2009, 09:19 AM   #10
NCRides's Avatar
I'm thinking the injectors are just air bound it fires sometimes randomly while cranking so I'm going to bleed it at lunch time
Old 09-23-2009, 08:29 PM   #11
NCRides's Avatar
I bled the injectors then hooked a gauge to the rail, 58 psi, so it's looking like VATS.... Jared is checking into it
Old 09-23-2009, 09:24 PM   #12
Jonce007's Avatar
If they are the original injectors, make sure they aren't gummed up from sitting. That happened to mine - it would start and then barely run. It sounds like its leaning towards the VATS as people said before.
Old 09-23-2009, 10:54 PM   #13
NCRides's Avatar
that would be a concern it has been 4 years since it last ran and the fuel rails wreak of 4 year old gas but...when this thing fires it is deffinatly on 8, it sounds awesome with no tail pipes, then it dies no sputtering no miss fireing just "blip"...turn the key off and try it again, same thing...keep cranking it and nothing but turn the key off and immediatly try to restart it and it fires then quits
Old 09-24-2009, 03:35 AM   #14
LS2Sonoma's Avatar
so frustrating
Old 09-24-2009, 06:20 AM   #15
WTF!!!!
sounds like vats for sure thats what mine did when i first put it together and hadn't had jared build the wiring and tuned the computer
Old 09-24-2009, 12:18 PM   #16
no need to bleed an EFI fuel line. Soon as those injectors pop open once, those bubbles will be SQUEEZED out in an instant
Old 09-24-2009, 02:07 PM   #17
NCRides's Avatar
that's what I thought but I still got a lot of air out of it even after turning it over several times
Old 09-25-2009, 01:17 AM   #18
CODE4LS1's Avatar
My money is on VATS, I chased down all the same symptoms as you and finally figured it out.
Old 09-25-2009, 09:36 AM   #19
NCRides's Avatar
yep it's deff pointing to vats, I sent the pcm to Jared this morning
Old 10-07-2009, 08:46 PM   #20
NCRides's Avatar
Jared had to reprogram the computer he said the predator program seemed to have been deleted but he wasn't to surprised he's had problems with those and no longer sells them...any way it lives I fired it up tonight and it sounds sweet so far......
Old 10-07-2009, 08:48 PM   #21
On da bottle
zx9rgreen's Avatar
Old 10-07-2009, 09:04 PM   #22
Whats this for?
mr spree's Avatar
When did you order your harness and computer? hopefully i dont have the same problems
lets see a video of her
Old 10-07-2009, 09:32 PM   #23
NCRides's Avatar
I got it back in March of 06 so by now he has worked all the bugs out of the progamming for our swap...you'll be OK....
I won't be able to get a vid up for a while I don't have a camcorder,but I do have some money coming just don't know when
Old 10-07-2009, 10:44 PM   #24
Whats this for?
mr spree's Avatar
ill be waiting for that video then
diggin the first gen lsx swaps
Old 10-07-2009, 11:12 PM   #25
LS2Sonoma's Avatar
awesome dude, were waiting for a vid now.... surely you know someone with a digi cam....
Page generated in 0.59439 seconds with 31 queries
[Output: 120.59 Kb. compressed to 110.77 Kb. by saving 9.82 Kb. (8.15%)]
