DON'T use Russell quick connect fittings!!!! - S-10 Forum
post #1 of 72 Old 06-01-2011, 05:19 PM Thread Starter
Killing Time
Petro's Avatar
User is: Petro is offline
Just had another pop off on me while driving . This time it was the return line at the filter. I must've been spewing gas cause it ran out quick!!!!I obviously didn't realize it until I puttered to a stop. Looked around and a trail of fuel behind me for a ways.... So yeah not to happy right now
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!"
Petro is offline
post #2 of 72 Old 06-01-2011, 05:24 PM
User is: PPI Typhoon is offline
Re: DON'T use Russell quick connect fittings!!!!
Yeah, when messing with fuel, I don't want anything that disconnects easily.
Glad to hear nothing bad happened other than an empty tank of gas.
post #3 of 72 Old 06-01-2011, 05:33 PM Thread Starter
Killing Time
Petro's Avatar
They have a new design because so many people had been having issues with them popping off... I obviously would have never purchased them had I known this. I'm definitely not the only one though...And of course I have 5 of these fittings in my fuel system setup to top it all off..
Petro is offline
post #4 of 72 Old 06-01-2011, 05:34 PM
LSX Jimmy
moon509's Avatar
User is: moon509 is offline
Send a message via MSN to moon509
yea, good to know, I was putting my order together at summitracing for the fittings
2000 GMC Jimmy 2wd 2 door / LQ9, L92 heads, 224/230 cam and LS3 intake part out in progress
2006 Trailblazer SS
2000 Olds Bravada- SOLD
moon509 is offline
post #5 of 72 Old 06-01-2011, 06:27 PM
User is: ss454 is offline
I used the Dorman OEM fittings for all but the one that meets the rail and I used a JEGS brand quick connect at that point after reading a lot of trouble from the Russell fittings. It doesn't look the same as the Russell so I'm not sure who makes the fitting but it went on very snug and had a very positive lock when it went on.
ss454 is offline
post #6 of 72 Old 06-01-2011, 07:59 PM Thread Starter
Killing Time
Petro's Avatar
Well I popped it back on just like the one at the fuel rail the other day and tried hard as hell to pull it off with no success...What gives?!?!?! It took forever to get the pump sucking fuel again...Tapped the bottom of the tank and got it running..I dunno if that's what did it but it cranked afterwards...I will be speaking with Russell/Edelbrock tomorrow about the issue and see what can be done about it..This is absurd IMO that so many others have had this issue...I'm usually easy going but I'm a lil upset about this issue since I don't think it's a user error and more of a manufacturer error...
Petro is offline
post #7 of 72 Old 06-01-2011, 08:08 PM
5 speed 4 door blazer
NYCBLAZER's Avatar
User is: NYCBLAZER is offline
And the way gas prices are right now, I would hate to be spilling it also..
Good thing nothing bad happened, and you and your truck are ok.
post #8 of 72 Old 06-01-2011, 08:18 PM Thread Starter
Killing Time
Petro's Avatar
Yeah the other day when the one at the fuel rail popped off and spewed fuel all over a fully warmed up hot engine/headers/etc I'm lucky it didn't catch fire...I don't have a fire extinguisher in the truck so it would've burnt to the ground..Thank God it didn't though...Cause at 55~58PSI A LOT of fuel can spew out in a few seconds!!!
Petro is offline
post #9 of 72 Old 06-01-2011, 08:42 PM
Yes, they're all mine
pwtr02ss's Avatar
User is: pwtr02ss is offline
i used them on my swap. hope like hell i have the new design. I have just started my truck a few times for a few seconds, haven't finished it yet but i hope this doesn't happen to me. like you said they feel tight so it'll be interesting to hear what they have to say. @ $13-$15 bucks each they should be perfect cause like you i have 6. mine are the -6 braided fittings if that makes a difference
Yes he said that...
Originally Posted by Noboundries View Post
Yes sir like a real man. Real men suck dick. Softies like women.
2008 Avalanche LTZ- All stock
2002 Camaro SS- Heads, Cam, Forged Internals, Nitrous, Bla Bla Bla
1996 S-10- Lowered 5/5, Boyd Billets, Custom Paint, Daily Driver
1974 C-10- Lowered 5/5, Bonspeed Billets, 08 LSX Swap, Full Frame Off Build
pwtr02ss is offline
post #10 of 72 Old 06-01-2011, 08:56 PM
518MOTORSPORTS
kybrad's Avatar
User is: kybrad is offline
These are the fitting I used on my first swap, drove it 6000 miles and one never failed....but on the bad side I now have a total of 4 of these fitting where I only had two on the last truck. We also used 3 or these on a vette filter setup on the Silverado and it has 2 Walbro 255 and has not blown a hose yet.
Not to point fingers but I have noticed it is easy to put one of these on and not make the white tabs "lock" in place. I always push them on as hard as possible and then push the tabs to make sure they lock and then pull on the fitting as hard as I can to make sure it doesn't come off. Hope these dont become a problem tho, makes me a little worried.
518MOTORSPORTS
96' ECSB, 5.3, 4L60E, 3:42, G80, 2/3" drop RIP
99' Jimmy 2 Door, 5.3, FTL lvl 4, 150 shot, 3:42, Power-Trax, 3/3" drop. 368HP/500TQ Tuned by BLUE CAT RIP
96' SCSB, 5.3, 4L60, 3:42, 3200 Stall DD
09' Silverado, SCSB, 5.3, LS9 Cam, 80lb, 6L90E, turbo 10-15psi, meth, 4/7" drop, 22"s, 513hp on 10psi, Tuned by BLUE CAT
98' Z28, carbed 370ci , Th350, cage, tubular front suspension, Afcos. Building
84' Ford LTD 2, LS1, 4L80E Done
kybrad is offline
post #11 of 72 Old 06-01-2011, 09:02 PM Thread Starter
Killing Time
Petro's Avatar
You would know if you had the new design check this out:
http://www.jegs.com/InstallationInst...799-641300.pdf
http://www.ls1tech.com/forums/conver...-fittings.html
I know I pushed them on all the way upon intial installation. I remember trying to pull them back off and then pushing them back to back sure my pulling didn't unseat them..
Petro is offline
post #12 of 72 Old 06-01-2011, 09:51 PM
518MOTORSPORTS
kybrad's Avatar
It does seem like they do have a problem. Them coming out with a new one makes me worry about my fittings. It would really make me mad if my truck burnt over a $15 fitting after me having to build a second truck because the last one was destroyed by someone else. We are all wondering what they will say to you when u call. I'm sure if they replace yours then they have stepped on a very slippery slope because we will all want them replaced. But on that same note replacing a few thousand fitting is cheaper then paying for 10 trucks that burn.
518MOTORSPORTS
kybrad is offline
post #13 of 72 Old 06-01-2011, 10:01 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
I still don't have my fuel stuff, but I won't be using them. Thanks
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #14 of 72 Old 06-01-2011, 10:02 PM Thread Starter
Killing Time
Petro's Avatar
I agree...They obviously realized something was wrong by them just changing the design...Some people may never have a issue but others have obviously had problems...
Petro is offline
post #15 of 72 Old 06-01-2011, 10:05 PM
Barry's Avatar
User is: Barry is offline
thanks for this link Petro. I have the return and feed on the tank only thankfully. Im going to use his tube trick to lock it in for the time being. I always thought these things looked kinda chincy...
1999 Sonoma: Reg. Cab, SWB with a LS6 block A4 combo. Goin' Pro-Touring...
Barry is offline
post #16 of 72 Old 06-01-2011, 10:13 PM Thread Starter
Killing Time
Petro's Avatar
The OP in the tech thread apparently had no luck with getting Edelbrock to admit fault. I may get nowhere fast by calling them but will still call none the less. Maybe they'll man up the the fault and replace them. We shall see
Petro is offline
post #17 of 72 Old 06-02-2011, 10:16 AM
It's a 4. something
scriptedmind's Avatar
User is: scriptedmind is offline
lol FML I have 4 of these on my truck. It seems like every single part that I bought for my truck has now turned into parts that no one wants or buys.
Mien haven't come off yet but I know they were almost impossible to get on all the way.
97 S10 RCSB 4.8 V8, 4L60E swap. (Speed)
99 Blazer ZR2 4.3 auto. (Mud/Winter)
2000 Trailblazer edition, 2wd, graphite interior.
13 Ford Fusion Titanium (Wife's DD)
co-owner of S10s Unlimited Inc.
post #18 of 72 Old 06-02-2011, 11:48 AM
The Animal
V893S10's Avatar
User is: V893S10 is offline
I have not had an issue yet, but im gonna do the hose trick to be safe. Thanks for letting us know.
R.I.P. Jeremy Chad Hobbs
1/19/1990 - 8/27/2011
I Love You Brother
Magnacharged 93 Reg Cab LS1/T56 471RWHP/472RWTQ
Best time - 11.20 @ 123 mph w/ 1.64 60'
Build Thread....
http://www.s10forum.com/forum/f213/1...-build-417620/
Magnuson Install....
http://www.s10forum.com/forum/f213/m...thread-505486/
V893S10 is offline
post #19 of 72 Old 06-02-2011, 10:40 PM Thread Starter
Killing Time
Petro's Avatar
I didn't get a chance to call them today..Busy at work and when I got home I was prepping the truck for my tuning session tomorrow!!! Hopefully nothing pops of then....
Petro is offline
post #20 of 72 Old 06-03-2011, 08:43 AM
User is: myth is offline
The plastic lock clips are the same as Gm has been using for many years. One trick is when you plug the connector over the clip you dont just slide it all the way on and forget about it. You have to pull outwards on the ears of the clip and slide the fitting back until the locks on the clip seat inside of the fitting.
In the other thread on tech, he tells how to make a saftey catch for the fittings.
myth is offline
post #21 of 72 Old 06-03-2011, 12:46 PM
Dreaming of Turbos....
tiresmokinV8's Avatar
User is: tiresmokinV8 is offline
Glad I found this before picking up my fittings. So have we figured out what brand fittings to use? The russel revisioned ones look good though.
2000 Sonoma Zq8 Extcab
'08 Ly6 6.0, Precision 7675cea TSP vvt-2 cam + more goodies, 4l80e, CircleD 3200 stall, HPTuners, Narrowed 8.8 swap: Moser axles, 3.73 gears, disc brakes, posi. Caltracs. Afco Coilovers
702whp 611wtq
10.78@125
99 Envoy front bumper cover for sale
post #22 of 72 Old 06-03-2011, 01:13 PM
User is: dailydimeben is offline
Danng I hope this doesn't apply to my jegs brand quick connects I have like six of these hooked up!
post #23 of 72 Old 06-03-2011, 01:30 PM Thread Starter
Killing Time
Petro's Avatar
Im pretty sure the new versions have a better retention system and wouldn't be worried about it with them. I'm nervous about the old style though because after the one at the fuel rail popped off I triple checked the rest of them and still had the other pop off....
Petro is offline
post #24 of 72 Old 06-03-2011, 03:50 PM
Are the new russel ones under the same p/n? Im making a big list for Summit next weekend when they have their 10% off your order sale.
702whp 611wtq
10.78@125
post #25 of 72 Old 06-03-2011, 06:10 PM
Iroc-10's Avatar
Glad to hear that. I have not been on here much lately, but it sounds like that job interview went well a while back. Thanks again for the heads up on these.
Currently Running:
Yank SS3600
Iroc-10 is offline
post #26 of 72 Old 06-03-2011, 09:42 PM Thread Starter
Killing Time
Petro's Avatar
Again no time to call them today...Work and then the short tuning session this afternoon...
The job interview did go well...Got a job as Nuclear Security...
Petro is offline
post #27 of 72 Old 06-09-2011, 07:52 PM
So does russel have the new design in the 3/8 and 5/16 sizes? All Ive found are -8an and 1/4 ones.
702whp 611wtq
10.78@125
post #28 of 72 Old 06-09-2011, 08:27 PM
darkracer#212's Avatar
User is: darkracer#212 is offline
good to know thanks
post #29 of 72 Old 06-09-2011, 08:32 PM
I put an order in on 3 644000 fittings -8an male to 3/8 push on. Summit has them back ordered until the end of the month but Pur Performance didnt list it as so plus they were much cheaper there, so I hope that they are in stock. Ill just have to run a -8an hose.
702whp 611wtq
10.78@125
post #30 of 72 Old 06-09-2011, 08:36 PM
Russel doesnt have any 5/16 redesigned fittings listed so Ill just do that vinyl hose insert safety method.
702whp 611wtq
10.78@125
post #31 of 72 Old 06-09-2011, 08:50 PM Thread Starter
Killing Time
Petro's Avatar
I dunno if that -8an will affect anything or not...I thought they did have it 3/8 in -6an and not 5/16 -6an....hmmm...Russell had told me that it was most likely a user error and to give them a call if it continues to happen...I will be keeping a very close eye on everything...
Petro is offline
post #32 of 72 Old 06-10-2011, 12:14 PM
sprayed99's Avatar
User is: sprayed99 is offline
This is odd they must have made a change in the machining process. I used several of these fittings in 08 and 09 and none of them have failed. By several I mean at least 40-50 fittings
2002 S-10 5.3L auto all power Wifes truck
1932 Prostreet Ford truck Build in progress
post #33 of 72 Old 06-17-2011, 12:55 PM
Well Pur Performance cancelled my order since the fittings arent in stock. Are these new fittings even out yet? Both Summit and Jegs have the fittings listed as expected ship dates during the end of the month. And the black fittings arent shipping until July. I thought they were out already??
702whp 611wtq
10.78@125
post #34 of 72 Old 06-17-2011, 01:53 PM Thread Starter
Killing Time
Petro's Avatar
I thought they were out already also...The guys over on Tech talk like they're already using them...
Petro is offline
post #35 of 72 Old 06-17-2011, 05:06 PM
Bowtie Til I Die
s10studduts01s's Avatar
User is: s10studduts01s is offline
Man I tried getting mine on and off the fuel rail last night. It wasn't easy by any means so Idk what the deal is. The rest of the fittings I buy are going to be the dorman ones from Advance though just to keep from having as big of a chance with issues
97 rcsb s10 6.0/4l80e w/ turbo...Toy
00 rcsb sonoma 6.0/4l60e...New project
09 Chevy Defender...DD
Looking for used stainlessworks headers
post #36 of 72 Old 06-17-2011, 05:16 PM Thread Starter
Killing Time
Petro's Avatar
That one guy in the thread over on tech said it seems to be something that occurs over time with road/engine/etc vibrations making them come off...Because after I had that first one pop off I checked them all and could not for the life of me get them to pop off...then a few days later that other one popped off...
Petro is offline
post #37 of 72 Old 06-18-2011, 08:54 PM
Checked russels online store and even they dont have these fittings listed? Need to make a decision on fittings this week, Maybe Jegs brand??
702whp 611wtq
10.78@125
post #38 of 72 Old 06-29-2011, 07:01 AM
Looks like the new screw on style fittings will be out July 16th. So far just in blue but Black will be offered at a later date.
Check out the thread for p/n's on -6an 3/8 and 5/16
http://www.ls1tech.com/forums/conver...sconnects.html
702whp 611wtq
10.78@125
post #39 of 72 Old 07-20-2011, 02:15 AM
Straight from Russells facebook page
"#644110
(Blue -6 AN Male to 5/16" SAE Quick-Disconnect Female with threaded retaining cap)
#644113
(Black -6 AN Male to 5/16" SAE Quick-Disconnect Female with threaded retaining cap)
#644120
(Blue -6 AN Male to 3/8" SAE Quick-Disconnect Female with threaded retaining cap)
#644123
(Black -6 AN Male to 3/8" SAE Quick-Disconnect Female with threaded retaining cap)
#644130
(Blue -8 AN Male to 3/8" SAE Quick-Disconnect Female with threaded retaining cap)"
Should make it easier for people to look up the new fittings.
702whp 611wtq
10.78@125
post #40 of 72 Old 07-20-2011, 02:21 AM
sprayed99's Avatar
"#644110
#644113
#644120
#644123
#644130
too bad summit racing keeps kicking the dates back..
Anyone need a 644120
Blue 3/8 to -6an I have an extra one.. Yes I got my hands on it and through the nose for it. brand new in the package
Anyone need it?
post #41 of 72 Old 07-20-2011, 06:23 AM
I just bought 3 3/8's and 2 5/16 all black yesterday at performanceparts dot com. Already got the confirmation email that theyve shipped out. I noticed that Summit keeps pushing them back for some reason. Its easier for me to get them there since I live down the street from them. People on tech have recived theirs from Summit already though, I know the first couple that bought the revised blue ones recieved them on July 8th through Summit. Figured Id swap out the old clip style before my truck even fires, better safe then sorry.
Got 5 old style fittings for sale never seen fuel.
702whp 611wtq
10.78@125
post #42 of 72 Old 07-20-2011, 08:10 AM
LSX Jimmy
moon509's Avatar
I ordered about 8 of the black ones from performanceparts.com last night. I also picked up a wixx 33737 for under 25 at
http://cgi.ebay.com/ebaymotors/ws/eB...OC%3AUS%3A1123
2006 Trailblazer SS
moon509 is offline
post #43 of 72 Old 07-26-2011, 10:10 PM
User is: nocturnalsixer is offline
The russel connector are junk I thought it was just bad luck for some people and I got my engine to turn over tonight while it was turning over the engine backfire and big flame came up and burnt down driver side of my s10 and took half of cpw harness with it and melted body lights horn etc wiring and more I got a burnt up s10 to deal with its depressing after all money I sunk into getting it lsed now I think ill cut my losses with 94 and source other intake manifold then locate other cpw fans and get another cpw harness or build my own and put the 5.3/t56 in my 89 instead and also the fire heat messed up my droid phone volume button from just heat
89 RCSB 5.0 TBI
94 RCSB 5.3/T56 in progress
97 OLDS Cutlass Supreme SL
02 ECSB Silvderado Z71
My swap in progress http://www.s10forum.com/forum/f213/9...ogress-469306/
Coming soon....s10 with 6.6 408 lsx & 6L90E
post #44 of 72 Old 07-26-2011, 10:51 PM Thread Starter
Killing Time
Petro's Avatar
So one popped off and caused your truck to catch fire and melted your harness etc??? bummer man
Petro is offline
post #45 of 72 Old 07-27-2011, 12:07 AM
Fat tony's Avatar
User is: Fat tony is offline
Send a message via AIM to Fat tony
Mine have been working fine. Just wondering, did you remove the white clip from the inside of the fitting and install it on the hose end first?
Fat tony is offline
post #46 of 72 Old 07-27-2011, 01:07 AM
Is that the correct way?? I think most install it with the white clip inside the fitting as a whole. I know thats how I did it and pushed it one until I heard a click then pulled on it until the white tabs pushed outwards. But switched to the newer style to avoid the fires.
702whp 611wtq
10.78@125
post #47 of 72 Old 07-27-2011, 01:32 AM
Yes I installed it as whole and I have to buy new intake manifold and coil packs and other stuff I'm hong to keep the 94 frame and hopefully the 89 body will.swap right over.this time I'm going to just buy fuel rails with 6an fitting right on the rail that way it be safe and im losing sleep on this because I cheaped out on fitting fat tony chuck the fittings u have and get better u dint want same result as me mine clicked tight then it flame up
The $30 ain't worth the sight of truck burning down
89 RCSB 5.0 TBI
post #48 of 72 Old 07-27-2011, 10:03 AM
It's a 4. something
I put the white clip on the rail first then installed my fittings and I've never had an issue.
post #49 of 72 Old 07-27-2011, 10:37 AM
Bowtie Til I Die
I think that is where most people mess up...
post #50 of 72 Old 08-02-2011, 08:56 AM
slonlow92's Avatar
User is: slonlow92 is offline
So what are you guys going to use now? I'm ready to buy and I'm glad I seen this thread....
