Two tones of terror
DIY wiring harness for 5.3 swap
I have searched but couldn't find anything that helps very much. What I am baisically looking for is any helpful threads or wiring diagrams that shows what does what, and breaks down what each pin on the ECU does so I can weed out what I don't need from the stock 5.3 yukon harness, and build a standalone of some sort. I am looking to build my own harness because while the one from current performance is all too sexy, it's just as pricey. This shouldn't be too hard for me because I have already built and installed Megasqurt'n'spark from scratch into my turbo volvo project. Im still kinda new here from the euro tuner world, but from what I have found so far this is a really good forum. Any help is appreciated
takes 2 balls in our game
Re: DIY wiring harness for 5.3 swap
you wont find that posted anywhere aroud here ....there is reasons.
Makin Sparks
http://alldatadiy.com/
$25 for a year of 1 vehicle https://www.acdelcotds.com/acdelco/action/subscribehome $20 for 3 days of pretty much every vehicle. |
Call me Mario, Princess
![]() Age: 31
you could do it the old fashioned way and go to the library and look them up in the service manuals they have there and make copies for 10 cents a peice.
go to the GM dealer, ask them to print off the diagrams from alldata. They shouldn't charge much if anything. I get mine all printed for free, (but I spend about as much time at the dealer as I do at home)
Check out ls1tech.com in the conversions and hybrids section...there is a great sticky. I also found this one to be helpful, too: http://www.lt1swap.com/2000harness.htm (yes, it says LT1swap, but it has 5.3 diagrams, too)
And I also agree with the above posters - alldatadiy is the best $25 you can spend on your swap if you want to do it yourself. Last edited by brentg454; 04-02-2008 at 01:25 PM. |
8.88@153.92
The easy way to do it yourself is pick up the phone and call Jared... Its a small investment when you consider how seamless it makes the swap and how much time it saves you from having to fight with it yourself. He's The best there is and everything will integrate just like GM built it.
Not the answer you want but its seriously a major headache saver. |
ls1 junkie
I did mine myself. it works but i still have a few issuse with dash lights. took me almost 10 hours to hunt and follow wires for different things. if i did it again, the first thing i would do is call jared and order my harness. |
I actually started looking into this swap more and more once I found Jared's site. I wasn't going to do a V8 fuelie swap unless there was a plug and play harness available. I think I slept on the decision for 2 nights and decided to pull the trigger and do the swap. So instead of a paint job for the 71, I decided to do a V8 swap with Jared's kit.
LSX Swapper
I made my own on the first one, I am making two more but at the same time, if you guys ever question why its so spendy. Try buying all those terminals and connectors... Even at a discount I still have 400 into it. If I would have known that before I got my total I would have ordered from CP. Oh well next time right...
Does Jareds harness allow you to use the stock cluster and allows everything in the truck to work right?
IE Radio Lighting HVAC etc, Because when I finally do my swap I want it to be like the truck came that way. |
its just greg
there are other companies that do the harnesses. http://www.speartech.com/ and nelson performane both make harnesses. jared has done a ton of them but you will have to wait for them. call the companies i listed and let them know what you need and they will give you a quote.
WHAAAh?
Location: IOWA, land of Corn and Pork User is: OffLine |
Or you could just buy mine right now and for $35 bucks Jerad will modify it for your needs............just a thought
. But really, why give yourself the headache???
Build them right....Mod
![]() Age: 57
http://www.currentperformance.com/ |
Makin Sparks
Like the other companies out there, we also build stand-alone harnesses for non-computer controlled vehicles, but unlike the other companies, we fully support the S-10 swap community by building complete plug and play wiring systems that are designed and built from the ground up to plug in to the engine, transmission, and truck with little if any splicing. They are designed to take advantage of existing systems in the trucks, and make everything work 100% like it did from the factory. No figuring out anything on your end. Other companies will gladly sell you a harness for the engine, I have heard it time and time again, but then you get the harness, and find out that there is a lot more to making everything in your truck work then just making the engine run. |
WHAAAh?
Yep its pretty much plug n play
rolling work in progress
so if you were to get a stock harness modified would the gauges work.
jarrad whats the price if i send u my stock harness and get u to mod it
Makin Sparks
Go with Current Performance! They know what to do and STAND BEHIND THEIR PRODUCTS.
This is a no brainer..I'm an Elevator mechanic and I'm always troubleshooting problems,tracing wires down etc.I took my 04 harness and tried to intergrate everything,had all the pin-outs and called Jared numorous times to no avail.After a month of this trying to get this to work I said screw it and ordered my harness.2 weeks later it came in the mail,pulled it out of the box(what a masterpiece)in 45 min plugged everything in and cranked right up and all my gauges worked.Worth the $825 Should have done it at the begining.
Those crazy ass dogs!!!
Yeah what they said. I have all the pinouts and wiring diagrams and it just does not look pretty.
| Sponsored Links | |
Advertisement | |
