Cracked block by the starter, LOOK HERE! - S-10 Forum
post #1 of 24 Old 03-24-2010, 08:39 PM Thread Starter
takes 2 balls in our game
s10-den's Avatar
User is: s10-den is offline
Hey fellas, would you try to have this welded or put a stud in there or ?? ?Its the inside hole (starter hole)of the block...Just need couple of quick opinions...
The LSX section is where most of the mechanics hang out...
Name:	CRACKED BLOCK 001.jpg
s10-den is offline
post #2 of 24 Old 03-24-2010, 08:55 PM
Bowtie Til I Die
s10studduts01s's Avatar
User is: s10studduts01s is offline
Re: Cracked block by the starter, LOOK HERE!
what does it look like on the flywheel side? I def. wouldn't attempt to weld it since its cast. do you know what caused it to crack?
97 rcsb s10 6.0/4l80e w/ turbo...Toy
00 rcsb sonoma 6.0/4l60e...New project
09 Chevy Defender...DD
Looking for used stainlessworks headers
post #3 of 24 Old 03-24-2010, 08:58 PM Thread Starter
s10-den's Avatar
Yep, about 90mph into something that did not move!Its out of a wrecked truck I just bought..
The crack is on both sides on the the hole.Goes a little insid ethe oil pan, I havent taken the oil pan off yet.I bolted the starter to it and tightened both bolts down.I'm worried about when I hit the key though.
The starter was broke and that bolt was bent, to bad it didnt just break off...
Cast can be welded, but you got to have the right stuff, I dont...LOL
s10-den is offline
post #4 of 24 Old 03-24-2010, 09:10 PM
Bowtie Til I Die
I know it can be but i figured since you were asking that you knew it was hard lol.
Are you sure it didn't warp the rest of the block if it did that to that part? But it seems like from the picture that the crack doesn't go to the threads so it might be able to be saved...maybe...
post #5 of 24 Old 03-24-2010, 09:18 PM Thread Starter
s10-den's Avatar
Well, I hope it didnt warp the block! Dont really know yet, im going to fire it up the weekend and see what happens, taking it to the machine shop and have them weld it and cross my fingers and eyes that its ok..
Normally I would have walked away from itbut the 30,000 miles said otherwise..
I had to cut the frame out to get the motor out of the mangled mess!
s10-den is offline
post #6 of 24 Old 03-25-2010, 08:27 AM
User is: WickedTwister is offline
If i were you i would pull the oil pan and make sure the crank spins freely. Ive seen bad wrecks snap a crank or break a timing belt/chain and the piston smacked the fully opened valve its not good. This however was not on an LSx but i would still check to be sure before you spent too much time trying to fix that crack.
Typically once a crack starts its only going to get worse (From the heating cycles as the block get to operating temp and cools back down and the directional forces on the block as the stater is spinning over.) if you don't correct it in some way. Cast is hard to get a strong weld on. Machine Shops might be able to give you a better idea on the ability to fix it.
post #7 of 24 Old 03-25-2010, 08:46 AM Thread Starter
s10-den's Avatar
Yea, it spins over, took the valve cover off and all the rockers moved, oilpan is coming off today.Im suppose to take it to the machine shop and have them weld it if they ever call back!
s10-den is offline
post #8 of 24 Old 03-25-2010, 09:22 AM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
Welding cast iron sucks. Very few people have the tools and the ability to do it!
I took a welding class and even the instrucutor wasnt very good at it, but could do it. He only did a demonstration, we never welded on it.
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #9 of 24 Old 03-25-2010, 10:18 AM
LS2Sonoma's Avatar
User is: LS2Sonoma is offline
it doesnt look very bad actually. as long as it isnt cracked all the way through into the crank case!
fire it up see if it leaks. if not, it would be just fine to put a few tacks on there. that way that little peice cant have an affair with the flexplae
you cant not be feelin dis
post #10 of 24 Old 03-25-2010, 11:21 AM Thread Starter
s10-den's Avatar
Actually, the crack stops right at the oilpan bolt.I cant fire it up right now, its sitting on my trailer..LOL but I think I will stick the starter on there and hit it with the jumper cables and see what happens.Machine shop said it would have to be a bare block and put in an oven and all kids of bull, so hell with that!
s10-den is offline
post #11 of 24 Old 03-25-2010, 11:55 AM
1995droptopz's Avatar
User is: 1995droptopz is offline
I had a chunk of a bellhousing break off of a transmission once and I found a local tool and die shop and had one of those guys weld it up for pretty cheap. While that was cast aluminum and not iron, those guys usually know their stuff and may be pretty resaonably priced
post #12 of 24 Old 03-25-2010, 12:20 PM
Build them right....Mod
philntx's Avatar
User is: philntx is offline
I wouldn't mess with it. Pick up a block somewhere and use the internals and exterior parts.
Phil
"Red-light runners" should lose their license for 30 days.
Blazer was sold! Now in Michigan!
Sounds good! http://www.youtube.com/watch?v=aejtZxXyvA4
At the Track: https://www.youtube.com/watch?v=gs1Zs8TJJ_A
philntx is offline
post #13 of 24 Old 03-25-2010, 12:29 PM
Honest Abe's Fab Shoppe
BlackEsDime's Avatar
User is: BlackEsDime is offline
Send a message via AIM to BlackEsDime Send a message via MSN to BlackEsDime Send a message via Yahoo to BlackEsDime
there is NO sure fire way to weld cast, its a hit or miss and will typically fail no matter what when put under stress. I would say weld it if it isn't a real structural part of the block.
Pre heat it with a torch and try to MIG it, stick weld it with a nickle rod, or try knocking the flux off the nickle rod and use it to TIG it. Can also try using a high nickle stainless filler rod with the TIG, or try brazing it with a brass rod. MIG with out preheating it will be worthless, you'll be able to pick it off by hand.
-Ryan
I build aluminum fuel cells. Maybe...
www.honestabesfabshoppe.com
post #14 of 24 Old 03-25-2010, 12:42 PM
Eight433's Avatar
User is: Eight433 is offline
I just welded a little tiny piece of cast. I do not have an oxy/ace torch, just a little MAP gas one, worthless I know. I used a mig, high heat, low wire feed, and started away from the area to be welded just a bit and worked it really slow to let it build up heat before I started on the piece to be repaired, all while having the MAP gas on it. The key is to cool it down as slow as possible. So far it has held, although the car has only been through a dozen or so heat up/cool down cycles since the repair (on the back side of a head, where the exhaust manifold bolts on- there was a little flange with a bolt hole and it broke off, right through the hole. This was on a 60's Cadillac 429)
-2011 Silverado Regular Cab Short Box 5.3 6 speed auto 4wd
-67 Cadillac Deville on air
-2000 RoadStar Silverado 1600
Eight433 is offline
post #15 of 24 Old 03-25-2010, 01:37 PM
different cast will have different properties... some more weldable then others, none are consistant. You'll also want to groove out the crack quite a bit.
-Ryan
post #16 of 24 Old 03-25-2010, 01:39 PM
Iroc-10's Avatar
User is: Iroc-10 is online now
If you can you need to drill stop it. Drill a hole at the end of the crack so it stops if you want to even try to use it. You certainly want to do this before trying to weld it, otherwise your wasting your time. I use to repair train traction motors, and have seen them crack all the way in half when not repaired properly, the heat cycles and stress on cast is like crumbling a cracker.
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
post #17 of 24 Old 03-25-2010, 03:02 PM
User is: bada$s10 is offline
I wouldnt use the motor. If it wrecked hard enough to crack the block im sure its going to have a good bit of crank walk. Find another block and crank. The reason i say that is because a friend of mine flipped a 383 s10. Got another body and put his motor in it. As soon as he started it up it went to rattling because there was play in the crank. Good luck on whatever you do.
bada$s10 is offline
post #18 of 24 Old 03-25-2010, 04:48 PM
Eight433's Avatar
this could be true, however what does he have to lose, except labor? It sounds like he is dropping in a stock motor. If he gets it in and it has a crank wobble, he can still swap it out and he is not out anything other than the labor. Personally, I'd take the chance. We won't know which is the right call until it's installed and running.
Eight433 is offline
post #19 of 24 Old 03-25-2010, 04:57 PM Thread Starter
s10-den's Avatar
I am not going to do anything to it, I'm going to put it in, if it dont work, well, looks like I will be pulling it right back out..
I have other plans too... ..
s10-den is offline
post #20 of 24 Old 03-25-2010, 06:17 PM Thread Starter
s10-den's Avatar
just a couple of other pics....
Name:	CRACKED BLOCK 002.jpg
ID:	110117   Click image for larger version
Name:	CRACKED BLOCK 004.jpg
ID:	110118   Click image for larger version
Name:	CRACKED BLOCK 003.jpg
ID:	110119   Click image for larger version
Name:	CRACKED BLOCK 006.jpg
s10-den is offline
post #21 of 24 Old 03-25-2010, 08:45 PM
LS2Sonoma's Avatar
i was going to say earlier this morning but i was late for work. that crack just looks like the starter bolt was pushed back. it doesnt look bad at all in the new pix. you have nothing to worry about using it. dont forget to post pics of the install, Jody!
post #22 of 24 Old 03-25-2010, 08:57 PM Thread Starter
s10-den's Avatar
Yea ,I went out and looked at it again and tightened down the bolt, seemed to be good, so I'm going to put it in this weekend.30,000 miles, I have to at least try it.
no pics of "this" install Frank, I am not worthy..LOL
s10-den is offline
post #23 of 24 Old 03-25-2010, 09:22 PM
LS2Sonoma's Avatar
Lies!!
post #24 of 24 Old 03-25-2010, 09:36 PM Thread Starter
s10-den's Avatar
Lmao!!!
s10-den is offline
