Whats this for?
Coolant Crossover Pipes
What are people doing with this? Im not exactly sure where it should go after it runs through the bottom of the TB? Anyone have any pictures of what there doing with them? Thanks
Re: Coolant Crossover Pipes
A lot of people just bypass the TB and run the hose from the coolant cross over pipe to somewhere in the cooling system you see fit.
I used Jared's radiator and removed the drain pet cock and screwed a 1/8" barb and ran it straight there from the coolant cross over. |
Whats this for?
Well there is a hole in the radiator for a fitting i could screw in but idk what size it is
Location: prince albert, sk, CANADA! User is: OffLine |
i'm running mine through the tb then to the jtr coupler that goes inline on your upper rad hose
If you've got a spot in the radiator, that is probably going to be the best spot for you. As long as you are not looking at the trans cooler connections.
s10 newb
I welded my rear ones shut and ran the fronts to a fitting i put in the top of one of my radiator tanks.
Whats this for?
Idk, might be the trans cooler connection. heres a picture
looks like the right spot to me.
Whats this for?
now i just gotta find a fitting for it....
Yeah that is the newer design radiator that incorporates that spot just for the coolant crossover hose. Older ones didn't have it.
