completed LS1 rear disc swap
Old 08-25-2004, 03:46 AM   #1
lowass91's Avatar
lowass91 is on a distinguished road
Thumbs up completed LS1 rear disc swap
I know most people dont think swapping rear discs is easy well it is if you have a four bolt axle flange. i had a 3 bolt and it was pretty easy, i used LS1 rear brakes and it stops like you just a brick wall, and I did not have to change out my proportioning valve either. I tried locking the rear tires up in the rain and it wouldnt happen.. I also did not have to turn down the axle flange or space the caliper bracket from the housing....any ????? email me
Old 08-25-2004, 07:00 PM   #2
Boozer member
mimadogg's Avatar
mimadogg
Re: completed LS1 rear disc swap
what were there from camaro vette?
Old 08-25-2004, 09:15 PM   #3
lowass91's Avatar
98 camaro...
Old 08-26-2004, 02:45 AM   #4
Its a Blue thing.
Mr Blue's Avatar
Mr Blue is on a distinguished road
Where did you get the parts at, and how much did it all cost you out the door?
Old 08-26-2004, 02:54 AM   #5
Got Baked Potatoes?
Platinum_Blazer's Avatar
Platinum_Blazer is on a distinguished road
shit thats funny i JUST got finished myself.....total for me was 470....220 for setup at the salvage yard another 220 for a new backing plate and a bolt and guide pin bushing and pads at the dealer (get replacement parts at www.gmpartsdirect.com to save some money i just needed the parts immediately) and other little miscellaneous shit like gear oil, additive, brake fluid, turning the rotors, blah blah
ill post pics later.....i had little trouble but nothing i couldnt do a second time even easier...i was just scared and skeptical, havent got to test them yet tho....
so all in all the cost is anywhere from 275-500 depending on what all you need and need to replace....
Old 08-26-2004, 03:00 AM   #6
Drastic Mini's WPG
Snafu Pimp's Avatar
Snafu Pimp is on a distinguished road
so then what happens to your e-brake?
Old 08-26-2004, 03:03 AM   #7
Got Baked Potatoes?
right now my cables are ziptied out of the way...ill get to doing that later....i am in no dier need for pbrake...automatic and no bad hills... ill figure it out later or someone who has onyx02extreme's or whoever's instructions give them to us.....its in an old thread HERE
Old 08-26-2004, 03:25 AM   #8
Its a Blue thing.
Mr Blue's Avatar
You just use an e-brake cable off of a 4x4 blazer with 4 wheel disc.
Old 08-26-2004, 03:49 AM   #9
I Love Tools
rainingbullets's Avatar
rainingbullets is on a distinguished road
How hard would it be for this to work?
blazer rear end
Old 08-26-2004, 03:51 AM   #10
Its a Blue thing.
Mr Blue's Avatar
It would probably just bolt right up
Old 08-26-2004, 03:53 AM   #11
Its a Blue thing.
Mr Blue's Avatar
Except the offset for your rims would have to be for a 4x4 in the rear, and they wouldn't be LS1 quality or performance.
Old 08-26-2004, 05:45 AM   #12
lowass91's Avatar
It only cost me 190 *gm parts at cost... i havent installed my p brake yet i got hte cables that go to the brakes just havent installed them yet either, ihave mine zip tied up outta the way.. It's really easy to do only took a couple hours and make sure you have a really sharp drill bit,and cut off wheel (where applicable) ...
Old 08-26-2004, 11:43 AM   #13
JYD
JYD is on a distinguished road
could someone do a complete write up on this? with part number and pictures?
Old 08-26-2004, 08:15 PM   #14
lowass91's Avatar
What kind of write up do you want??? step by step instructions what to do what not to do?? If you do attempt this swap get the camaro brake lines hard and soft. Stock s10 lines do not fit different type flares (s10 standard flare,camaro roll back flare)....
Page generated in 0.13491 seconds with 11 queries
