its just greg
battery relocation help
hey i'm putting my batter in my bed, from there I need to run a ground to the frame, and a positive to the starter and fuse box right?
i've only ever done any wiring on older cars that only needed the cable going to the starter so i'm double checking that I need the positive going to both places. Greg |
former V8 AWD member
Re: battery relocation help
Positive cable needs to go to the starter and a different 10-12 guage to the backside of the alternator. Or loop it however you choose.
The Negative needs to be grounded straight to the frame then another from the frame to the engine at the front. |
its just greg
the wire thats in the harness is the one I need on the alternator right? I have jareds harness.
I dont need one to the fuse box then, even if there was one originally? |
My battery is in the rear. One ground cable, straight to frame from battery. Engine has a ground strap to the frame.
Positive goes up front, and T's off. One side goes to the starter, other side to alternator. ALternator also has one more cable that hops over to the fuse box. |
hmm.. mine is just ran from the battery in my bed to the little distro block or watever with the 175 amp fuse.. the starter and alt are also ran there.. been like that for years
Not so Avg
175amp enough to crank the engine? I would think that fuse would be popping.
its just greg
thanks i'll do that Does it need to have a fuse in there? |
Local Tech
ok, im not 100% how or what you've already removed, but there is a 4 gauge wire already ging from the underhood fuse block to fuse under the factory battery tray. if that is still intact, you need to run from the battery to the starter (cuz jareds wire is not meant as the feed) and a positive to the other end of the fuse under the factory battery tray. As for grounds, yes, one to the frame, one to the engine, and one to the body (most things are grounded to the body, cuz the frame is insulated by the rubber body mounts)
its just greg
I dont have said fuse under battery tray, or the battery tray, does it need to have a fuse?
big pimpin'
when i did mine i used a dist block from a 88-98 fullsize, ran 2awg from the battery to the block on the inner fender, than ran the alt wire and starter wire and the fuse block wire from the block
Fuse? pshhhh, we don't need no stinkin Battery fuse!
Everything on the car is fused, why would we need 2? i don't plan on having my battery popping a fuse... |
big pimpin'
well i had a 150amp fuse in about 6" from the positive post, i was lucky i did cuz my cable came loose and pinched between frame and body so if it wasnt for the fuse blowin i dont know how bad it would of been
i tried jump starting a car once by hooking up the battery cables backwards~~~ Not on purpose though haha all it did was melt my cables
