Battery light on? - S-10 Forum
post #1 of 70 Old 12-01-2011, 02:51 PM Thread Starter
s-10ls1's Avatar
User is: s-10ls1 is offline
Battery light on?
Well I just got done changing up a few things on my s10 and now my battery light says on. Well I started with a fbody bracket and alternator and I changed to the corvette alternator and bracket with power steering. That was the only thing I chaged. I didn't mess with any grounds and used the same power wire to the alternator. I tested the alternator and battery, found out the my red top battery was bad. Got a brand new red top battery and the light is still on! Anyone got any ideal what it could be?
s-10ls1 is offline
post #2 of 70 Old 12-01-2011, 03:39 PM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
Re: Battery light on?
is it charging normal?
2004 Commemorative Edition Corvette
2014 Lexus IS350 F-Sport
post #3 of 70 Old 12-01-2011, 03:44 PM
You lost me at carburetor
longboxdime's Avatar
User is: longboxdime is offline
Are the alternator turn on wires the same on both? Just a thought.......
2002 Xtreme Blazer- Lq4, ls3 heads, 222/242 118+4, zl1 blower/lid, 2.4" upper, id1000s, e85, SW Longtubes, 4200#, no e.t. yet
LSX swap exact pinouts for a 411 and a 2002 truck OS http://www.s10forum.com/forum/f213/w...ys-out-446965/
<<<<Bottom of 1st post using the word files.>>>>
post #4 of 70 Old 12-01-2011, 04:10 PM Thread Starter
s-10ls1's Avatar
Yeah check and it wad charging 14.1 and that was with the bad battery
s-10ls1 is offline
post #5 of 70 Old 12-01-2011, 04:11 PM Thread Starter
s-10ls1's Avatar
I'm not sure on that.
s-10ls1 is offline
post #6 of 70 Old 12-01-2011, 08:44 PM
User is: dailydimeben is offline
Same problem I have a new red top new alternator new battery cable gauge reads 2.5 volts higher and battery light is constantly on but with a volt meter it's at 14.3 but reads around 16- 18
post #7 of 70 Old 12-01-2011, 09:51 PM
User is: tevol1 is offline
How many wires is in the alternator plug? What year of vette alternator did you get?
tevol1 is offline
post #8 of 70 Old 12-01-2011, 10:23 PM
the_merv's Avatar
User is: the_merv is offline
^^That and is the Vette Alternator wired differently?
1984 MCSS M6 - CLASSY STREET CRUISER
408 Stroker, Ported L92's, EFI Vic Jr, BIG CAM
1991 S10 SINGLE-CAB SHORT-BOX - LS1 A4 DAILY DRIVER
the_merv is offline
post #9 of 70 Old 12-01-2011, 11:09 PM
Yes the fbody's have 1 wire and the earlier vette's had 2 wire's and the newer vette's are 3 wire alternator's.
tevol1 is offline
post #10 of 70 Old 12-01-2011, 11:11 PM
the_merv's Avatar
Get a schematic on the Vette one and see what has to be done.
the_merv is offline
post #11 of 70 Old 12-02-2011, 09:05 AM Thread Starter
s-10ls1's Avatar
I am not sure what year the alternator is. All I know it's from a c5. I'll have to look more into it.
Does anyone know if a fbody alternator will bolt right in the c5 bracket?
s-10ls1 is offline
post #12 of 70 Old 12-03-2011, 04:45 PM
Dreaming of Turbos....
tiresmokinV8's Avatar
User is: tiresmokinV8 is offline
I run a truck alternator I think like a dr22 or something, Anyways its a 2 wire plug and charges fine along with the gauge working as it should but the battery light on mine is also always on right from the get go. Interested to see what people come up with here.
2000 Sonoma Zq8 Extcab
'08 Ly6 6.0, Precision 7675cea TSP vvt-2 cam + more goodies, 4l80e, CircleD 3200 stall, HPTuners, Narrowed 8.8 swap: Moser axles, 3.73 gears, disc brakes, posi. Caltracs. Afco Coilovers
700whp 611wtq
10.78@125
99 Envoy front bumper cover for sale
post #13 of 70 Old 12-03-2011, 04:59 PM
Wondersmith
StirFrey's Avatar
User is: StirFrey is offline
did you get your NEW optima tested?
It isn't a death wish. It's about living.
-95 Noma (see thread >) - 2.2 5-speed http://www.s10forum.com/forum/f30/pr...sinoma-433674/
StirFrey is offline
post #14 of 70 Old 12-03-2011, 05:35 PM Thread Starter
s-10ls1's Avatar
No but I called cpw and they said I need another wires going from my alternator to my fuse box
s-10ls1 is offline
post #15 of 70 Old 12-03-2011, 08:40 PM
to which fuse?
700whp 611wtq
10.78@125
post #16 of 70 Old 12-03-2011, 09:23 PM Thread Starter
s-10ls1's Avatar
They said to the battery fuse. They said when I get to the point to wiring it to just give them a call and they would tell me where. So you might just want to give them a call
s-10ls1 is offline
post #17 of 70 Old 12-03-2011, 10:04 PM
Hmm, I did get my harness from them, Ill have to ask them.
700whp 611wtq
10.78@125
post #18 of 70 Old 12-03-2011, 10:43 PM
I got my wiring harness from Jared at Cpw too. But when I hooked mine up my battery light came on. Im using the Ls2 corvette alternator. After inspection the F terminal was pinned out wrong on my ecu. After switching the wire fixed my problem..
BTW Im in no way talking crap on Cpw or jared they are Awesome products and refer them to anyone..
tevol1 is offline
post #19 of 70 Old 12-03-2011, 11:27 PM
Same boat as me. theres been some complications but I still wouldnt have it any other way. Do you happen to remember which circuit or name listed on the pin you had to move it to. I have a wiring schematic and pinout for the ecu and tune Im using.
700whp 611wtq
10.78@125
post #20 of 70 Old 12-04-2011, 12:53 AM
Yeah mine was the f terminal on the alternator plug. It was pinned into connection 2 terminal 75 and it should have been connection 2 terminal 52.
tevol1 is offline
post #21 of 70 Old 12-04-2011, 01:52 PM
What was the name of the circuit if you know? My ecu and tune are most likely different then yours.
700whp 611wtq
10.78@125
post #22 of 70 Old 12-04-2011, 04:50 PM
O yeah sorry. Its called the Generator Field duty cycle signal..
tevol1 is offline
post #23 of 70 Old 12-04-2011, 05:02 PM
If you have a c5 alternator and are coming from a 1 wire fbody alt. you dont need a wire going to the fuse box it needs to go to the Ecm.
You have 2 main wires from the alt the Generator turn on signal and the Generator Field duty cycle signal If you dont have the cycle signal wire hooked up the battery light will come on due to it not registering that your alternator is charging correctly.
tevol1 is offline
post #24 of 70 Old 12-04-2011, 09:32 PM
You can sort of see the plug in this picture.
2 pin plug running a 140amp truck alternator. Ill have to check out the wiring. Thanks.
700whp 611wtq
10.78@125
post #25 of 70 Old 12-08-2011, 04:10 PM
CPWire's Avatar
User is: CPWire is offline
I just looked through our build sheets and it does look like there was an error in some of our stuff. Some of the harnesses were built with one of the alternator wires going to C2 75, when in fact it should go to C2 52.
So, Anyone getting a battery light on might take a look and see if there is a wire in the wrong spot on the red computer connector.
C2 75 is the right spot on some of the later computers, but if your light is on, might try switching that wire to pin 52. Should be a gray wire.
Jared,
Current Performance Wiring
CPWire is offline
post #26 of 70 Old 12-10-2011, 12:02 AM
With those pins possibly mixed could that throw the gauge reading off? If I unplug my alt. My gauge still reads, and no matter what it shows 2+ volts higher
post #27 of 70 Old 12-10-2011, 02:23 AM
hmm, My lights on but my gauge reads correctly and at first I didnt have the alt connected and it read nothing.
Jared what plug would I look in for my e67 ecu, I think its pin 29 in c3?
700whp 611wtq
10.78@125
post #28 of 70 Old 12-12-2011, 11:08 AM
CPWire's Avatar
I think yours may be a different issue. You probably need a generator battery control module on the neg battery cable.
Looks like this:
Jared,
CPWire is offline
post #29 of 70 Old 01-01-2012, 11:15 PM
THELSXS10's Avatar
User is: THELSXS10 is offline
Anyone had this problem running a stock 2000 5.3 computer and harness? Mine is on but is charging fine as it has not killed the battery yet.... Seemsto be ok but i hate the light on
275 radial S-10 back on hold!!!
5.3 Daily driver blazer under way!!!
post #30 of 70 Old 05-03-2013, 03:37 PM
Mr Cheech
Sleeper S10's Avatar
User is: Sleeper S10 is offline
saw this post ways back and it had me hoping this wouldn't happen on my truck, however it is.
i have the battery ligh on.
my alternator also has one brown wire and is a LS2 alternator.
i called Jared on it ways back in November and was told I wouldn't have the light on, though it is.
what can i look for or do to correct it?
LS2 402 STROKER SWAP:
http://www.s10forum.com/forum/f213/s...x-swap-430296/
S10 Sonoma Envoy Swap - NEW & 99% COMPLETE!
Best offer!
http://www.kijiji.ca/v-view-details....teLocale=en_CA
Hellwig Rear Sway Bar - New Other
Best offer!
http://www.kijiji.ca/v-view-details....dId=1124629793
post #31 of 70 Old 05-03-2013, 04:31 PM
Mr Cheech
just checking a note i had from Jared and he mentioned that, the one light brown alt wire should go to:
C2 Pin 15
i do have a light brwn wire running there but also have another light brown wire in C2 Pin 2.
on the alternator it has three connectors with only the one light brown wire going in.
that one wire is on the connector to the very left OR driver side.
Best offer!
Best offer!
post #32 of 70 Old 05-04-2013, 08:53 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
I have a harness that Jared sent me to correct this issue. I will check it out tomorrow, and let everyone know what he sent me.
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #33 of 70 Old 05-04-2013, 10:27 PM
Mr Cheech
I am looking forward to hearing about this.
Great of Jared to work with you. He's super helpful!
He's helped me out on several issues that didn't even relate to things I purchased from CPW.
Hope it works out.
I'm on a waiting list to be called back myself.
You can't pass emissions here with any dummy lights on.
Can you post pics of what you received?
Best offer!
Best offer!
post #34 of 70 Old 05-05-2013, 12:28 PM
User is: XtremeBoost is offline
Every swap I have done has this same issue. Easy fix, pull the cluster and break the bulb or put a black piece of a sock or something in the cavity for the light on backside of cluster. Problem solved.
2002 Xtreme Blazer, JY L33 5.3, Cam, Front Mount T76mm Turbo, Intercooled, Built 4L60e, Precision 2200 Converter, 8.8 Swap, 340 Pump, 19" Saleen Wheels, 305 rear tire, Tuner by me HPTuners, NASTY as a mofo
post #35 of 70 Old 05-05-2013, 12:36 PM
Mr Cheech
That would solve crap!
Would still throw a code and couldn't pass emissions.
Best offer!
Best offer!
post #36 of 70 Old 05-05-2013, 10:44 PM
What code??? Maybe I am not reading something correctly but I think the OP is only trying to get the battery light from coming on, no code.
post #37 of 70 Old 05-06-2013, 12:12 AM Thread Starter
s-10ls1's Avatar
I ended up just pulling the bulb out
Tuned by Patrick G
s-10ls1 is offline
post #38 of 70 Old 05-06-2013, 12:15 AM
Now that's a success story!! Problem solved
post #39 of 70 Old 05-06-2013, 12:21 AM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
you probably need two wires going to the pcm from the alternator. a brown or red one in c2 15 and a gray one in c2 52. The brown or red one should be in the b position on the alternator and the gray one should be in the c position.
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #40 of 70 Old 06-28-2013, 02:48 PM
Mr Cheech
thanks to Jared/CPW, tev01 and AceHaag for helping me.
MY BATTERY LIGHT IS OUT!
Best offer!
Best offer!
post #41 of 70 Old 06-28-2013, 02:51 PM
CPWire's Avatar
Pair of needle nose pliers would get the light out too.
Jared,
CPWire is offline
post #42 of 70 Old 06-28-2013, 02:55 PM
I never thought a pro like you would say something sooooo funny!!!
post #43 of 70 Old 06-28-2013, 02:56 PM
Mr Cheech
lol
Best offer!
Best offer!
post #44 of 70 Old 06-28-2013, 06:47 PM
Wheres the bulb for the batt light? I've taken the back black cover off the IP and all I see is the circuit board.
700whp 611wtq
10.78@125
post #45 of 70 Old 06-28-2013, 07:58 PM
CPWire's Avatar
They are surface mounted LEDs, just find the one behind the symbol for whatever lights you want gone and rip it off the circuit board. Pretty easy to do actually.
Jared,
CPWire is offline
post #46 of 70 Old 06-28-2013, 08:30 PM
I take it there is no fix for his tiresmokings combo?
post #47 of 70 Old 06-28-2013, 08:57 PM
CPWire's Avatar
Depends on why the light is on, with some of the newer computers, it takes a generator control module to be wired in just to turn off a light.
Jared,
CPWire is offline
post #48 of 70 Old 06-28-2013, 11:08 PM
I guess I would rather buy a generator module that way I don't get stranded. To each his own though. I have not had the pleasure to mess with any new style ecms so thank you for enlightening me Jared.
post #49 of 70 Old 06-28-2013, 11:13 PM
On mine its charges at 13.8v at all times. So with the reading Ive done theres a fault somewhere in the field generator circuit. the pcm tells the alternator how much to put out on the newer setups. '10 Colorado os on '10 e67.
700whp 611wtq
10.78@125
post #50 of 70 Old 06-28-2013, 11:27 PM Thread Starter
s-10ls1's Avatar
When you pull the back cover off it will look like this.
There are some small white clips that hold the board down. Unhook them and flip it over. The just pull the bulb out that's behind the battery sign. This pic kinda shows you what it looks like. I pulled the abs light and a security light.
Tuned by Patrick G
s-10ls1 is offline
