AWD V-8 what is easiest Lt1, Ls1, 5.3l
Old 07-10-2004, 03:29 AM   #1
Zq-8_dawg's Avatar
Zq-8_dawg is on a distinguished road
I am looking into buying up a truck from work for cheap it is a 99 2.2L and the engine and trans are about gone. I want to swap to a AWD bravada drive train using a 4x4 s-10 frame and a v-8 engine. I am thinking the lt1 cause the ls1 is too wide for the frame. Also lt1's are a little cheaper. Would a 5.3L fit or is it just as wide as the ls1?
Old 07-10-2004, 04:55 AM   #2
Wyotech = October
MoNkEyZQ8's Avatar
MoNkEyZQ8 is on a distinguished road
Re: AWD V-8 what is easiest Lt1, Ls1, 5.3l
The Lingenfelter (RIP).. AWD Sonoma was an LS1 with a (I think) denali AWD T-case, and the 4l80E transmission ..
Then again, when you have a shop like that anything is possible..
Old 07-10-2004, 05:42 AM   #3
Getting faster
ZZ4Blazer's Avatar
ZZ4Blazer is on a distinguished road
The 5.3, LS1, 6.0... etc are all Gen III motors, all basically the same motor on the exteriour. Basically like a 305 and 350.
I know with the LS1, the oil pan is the biggest problem, at least IMO. Im not sure if there still would be interferance, since the crossmember isn't there. I know you need a 4x4 pan to clear the axle with a standard sbc, not sure if theres still an issue with the LS1 pan.
I'd probably just go with a LT1. They're getting cheaper, and a good ported set of LT1 heads can flow like madd.
Oh, and Lingenfelters truck was a 427 TT.
Old 07-10-2004, 11:32 AM   #4
Banned
97s-dime4.3's Avatar
97s-dime4.3 is on a distinguished road
[QUOTE
Oh, and Lingenfelters truck was a 427 TT. [/quote]
:thumbup: Cound not remember if it was a 427 or a 454 i knew it wasn't a ls1 though
Old 07-10-2004, 12:43 PM   #5
weatherman
RedSpeck_09's Avatar
RedSpeck_09
actually it was a 427 ls1
Old 07-10-2004, 05:31 PM   #6
Getting faster
ZZ4Blazer's Avatar
Yeah, thats what I meant by that.
Old 07-11-2004, 10:47 AM   #7
monkyboy007 is on a distinguished road
couldent you just use a osmobile bravada trasfercase. thats what ive been trying to findout. i wanna do a t-case swap and a supercharger.
Old 07-12-2004, 08:05 AM   #8
LT1 S10 Expert
HectorM52
I realize this isn't the for sale section, but I have a 4x4 frame and AWD t-case if anyone is interested. I had planned on doing the AWD LT1 but just ran out of money (and time and patience and will etc...). Sorry to say I never got around to making the mounts up. Nevertheless, it doesn't seem to be that tough, as long as you have a 700r4 ready to handle some abuse!!!
Old 07-12-2004, 01:28 PM   #9
ZQ8-97's Avatar
ZQ8-97 is on a distinguished road
I dont know if anyone on here has a Bravada, maybe they could chime in but I dont think the Bravada is true all wheel drive and it probably wouldnt be a real good candidate for anything performance oriented.
Old 07-12-2004, 02:45 PM   #10
Ahhhhhhhhh Satisfying!!!
SummerWolf's Avatar
SummerWolf is on a distinguished road
the smarttrak bravadas are true AWD all the time
Old 07-13-2004, 10:51 AM   #11
ZQ8-97's Avatar
I dont think they are because they say the front wheels engage only when the rear is slipping which isnt true AWD like the Sy/Ty transfer case.
Old 07-13-2004, 12:09 PM   #12
LT1 S10 Expert
HectorM52
The Bravada's have similar t-cases to the SyTy's which are AWD all the time. Possibly you are thinking of a Honda CRV? I am 90% sure of that. I had shopped around for a Bravada t-case and found out that they were the same / or similar to the SyTy's. But I ended up getting a SyTy and not having to worry about this problem.
Old 07-13-2004, 12:25 PM   #13
sr_ryan1
are yall talking about the AWD on the 99 + s-10's? arent they called an NOP8 option at the dealership?
Old 07-13-2004, 12:35 PM   #14
pursuit S10's Avatar
pursuit S10 is on a distinguished road
First Gen Bravadas have the transfercase you need.
Old 07-13-2004, 01:57 PM   #15
ZQ8-97's Avatar
Yea I know for sure that the first gen Bravadas have a T-Case similar to Sy/Ty if not the same one. However the newer Bravadas that use the 4L60E like the 97 and 98's have something different. I watched my buddy do a real wheel burnout in a 98 Bravada so either his T-Case is busted or something is up.
Old 07-13-2004, 02:07 PM   #16
LT1 S10 Expert
HectorM52
hmm, i don't know about the newer ones. I just researched the 91-94 area.
Old 07-13-2004, 02:15 PM   #17
ZQ8-97's Avatar
Well I yahooed it and found a lot of info. The 96+ Bravadas have Smart-Trac and the T-Case is made by New Venture. It detects slippage in the rear wheels and fires a solenoid that engages the front wheels. Sounds like some people have tried swapping them into Sy/Ty's to reduce drag after the launch but they tore them up real quick and is wasnt a direct bolt in.
Old 07-13-2004, 10:55 PM   #18
gbaronetXCR's Avatar
gbaronetXCR
Have a look at http://www.usionline.net/hpm.html I've started trolling for parts the AWD deal raises a brow.
The Linkinfelter S10 did use the delani transfer case.
From syty.net
40. What kind of transfer case do the trucks have?
The BORG WARNER-4472 transfer case is a two-piece aluminum case, chain driven, viscous clutch type transfer case. This produces a system in which all wheel drive is engaged all the time. Torque is transmitted through a planetary gear set which distributes torque at a ratio of 1/3 front 2/3 rear. All wheel drive is automatic and has no external controls. The viscous clutch used in the BW-4472 is a torque distribution device and is nonserviceable. The internal construction of the viscous clutch consists of alternating plates that are connected to the front and rear outputs of the transfer case. The viscous clutch is filled with a high viscosity fluid which flows through slots in the plates. The resistance to sheer causes the plates to transmit torque.
The identificaton tag is an aluminum tag attached under one of the self tapping case bolts. The tag provides the Borg Warner part number, the General Motors part number, serial number and the build date. The information on the tag is necessary when servicing this transfer case. If the tag is removed or becomes dislodged during service operations, every attempt should be made to keep the identification tag with the unit.
Page generated in 0.17223 seconds with 11 queries
