Air filter setups
Old 06-06-2008, 12:19 PM   #1
Build it Right!
philntx's Avatar
philntx is on a distinguished road
Air filter setups
Can you guys take some good pictures of your air induction setups and email them to me at philntx@aol.com?
I'll build a "sticky" showing how-to build an effective air filtration system for the many applications on the LS conversion site.
If you just put a "K&N" on the end of your throttle body, you don't need to send me that one.
If you did something custom, describe in a few words what you did and what parts you used.
Thanks,
Old 06-06-2008, 07:11 PM   #2
RITALIN, IT LOVES ME!
99 BUCKET is on a distinguished road
Re: Air filter setups
dont have access to them at work but u have the go ahead to dig them out of my photobucket (link in the swap sticky)
Old 06-06-2008, 09:21 PM   #3
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
I know you seen the silver truck that Rick Bottom(think thats the name) built in the magazine a while back??That is the best looking intake system I have ever seen, it was an lt1 but same difference ....
Old 06-12-2008, 01:38 PM   #4
Build it Right!
philntx's Avatar
Can you see if you can find me a link or a pic?
Phil
Old 06-16-2008, 04:53 PM   #5
s10-den's Avatar
http://www.texassseries.com/photoplo....php?n=452&w=lLooking around and found this air box settup,kinda like I was talking about up there in my other post
Old 06-16-2008, 04:59 PM   #6
s10-den's Avatar
http://www.texassseries.com/photoplo....php?n=380&w=lthis is the one I was talking about
Old 06-16-2008, 06:24 PM   #7
Christobevii3 is on a distinguished road
I'll take a picture later this week but it is literally just a 4" piece of pvc pipe...
Old 06-16-2008, 11:13 PM   #8
Build it Right!
philntx's Avatar
Thanks Jody!
Old 07-01-2008, 01:56 PM   #9
big pimpin'
02dime's Avatar
02dime is on a distinguished road
so any luck with enough to post setups yet, im making on in the next few days so ill send you some pics when its complete
Old 07-01-2008, 02:32 PM   #10
Build it Right!
philntx's Avatar
No one has sent any pics to me at my email address.
I've got about 6 or 7 that I've managed to locate on the internet, but haven't done anything.
I was waiting for more user/builders to send theirs.
Old 07-01-2008, 04:39 PM   #11
Jonce007's Avatar
Jonce007 is on a distinguished road
IntakeHoses.com setup
Two 90 degree 4" elbows
One short 4" tube to connect the eblows
CPerf MAF sensor - believe its a 85mm
One 4"x3.75" insert sleeve to connect elbow to MAF
One air filter with 4" inlet
5 t-bolt clamps for 4" rubber tubing
I am running a cowl hood, clearance shouldn't be an issue
Old 07-01-2008, 06:35 PM   #12
Big96Zr2
that looks pretty good, but I think that will hit the hood. I did something similar it wouldnt work with my truck and I have a 2" body lift.
Brian
Old 07-01-2008, 08:57 PM   #13
Jonce007's Avatar
Brian
I will find out soon enough, I'm running 2.5" cowl induction hood. I'm hoping it will clear it. Did you go with a 4" setup like that on your swap?
Old 07-03-2008, 02:10 PM   #14
big pimpin'
02dime's Avatar
Jonce it will probably hit the far side brace, I had to go under my Rad hose and I made sure I had the inner fender with the overflow tank and comp on and I put the battery back in when I fabbed mine today, it actually looks great,its 4"coupler that's reduces to 3.5" for the TB I started wit a 13" aluminum 90 which I cut pretty much down to the bend on it, than a 3.5"coupler than I had a 13" 45 that I also cut to fit the contour that I needed than one more 3.5" coupler to the maf(which is 3 5/8)it was a bitch to get on but nothin a little grease and heat never fixes, than the maf straight into a k&n with a 4" inlet you will be surprised by how tight it is where the filter of the right size needs to go, but that was just my setup, ill post some pics when I get to a comp
Old 07-03-2008, 02:33 PM   #15
Build it Right!
philntx's Avatar
Remember, you can always use two smaller diameter pipes and two filters with a merge collector. SLP sold this one for the 94-97 LT1 Z28's.
Old 07-06-2008, 07:47 PM   #16
Jonce007's Avatar
I reworked my air filter setup a little bit. I changed the angles on the upper radiator hose, eliminated one 90 degree angle and added a 45 degree angle. It now sits lower than the previous setup.
Old 07-10-2008, 11:42 AM   #17
jeffrobaum's Avatar
jeffrobaum is on a distinguished road
Its hard to see in the pic, but its a stock air duct for a GTO flipped over and a K&N on the end of the MAF sensor. I'll see if I have better pics on the comp at home, but I'm going to the exhaust shop at lunch to talk about a different setup. I'll let you know what happens.
Old 07-10-2008, 12:29 PM   #18
Build it Right!
philntx's Avatar
Still collecting pictures. Come on guys, send me what you are using
When I get around 20 of them, I'll put the info on a single post and submit for a sticky.
Here are a couple that I've found for GTO's:
LT1 motor in an S10
And this one!
Another LT1
Truck motor:
6.0 Turbo S10
In a Gen1 (Typhoon)
Old 07-10-2008, 12:59 PM   #19
RazorS10's Avatar
RazorS10 is on a distinguished road
Damn! that has to be the best engine bays ive seen!
Old 07-10-2008, 02:05 PM   #20
big pimpin'
02dime's Avatar
well this is mine its a phone pic but i have some on my digi i will post sometime, let me know if this link works
Old 07-11-2008, 12:22 PM   #21
Need LSx swap.....
Kampz69's Avatar
Kampz69
The GTO shaker setup is great looking. Is that turbo 6.0l a members truck on here? That thing must haul!
Old 07-11-2008, 12:53 PM   #22
s10-den's Avatar
I like the grey truck's air box!!Would work for a lsx swap..the one with the chrome air box
Old 07-11-2008, 02:40 PM   #23
Build it Right!
philntx's Avatar
I think the GTO Shakers could be adapted to the S-trucks. I've never seen anything written about the turbo 6-liter, however, I do have a few more pictures of it.
Old 07-11-2008, 02:57 PM   #24
Need LSx swap.....
Kampz69's Avatar
Kampz69
would any of these setups present issues with the motor getting water? Obviously more of the ram air setups, not the CAIs. I know Camaros and TA's had them factory, so it works. Just curious how you dont suck water in when air is blowing directly from the hood to an air filter.
Old 07-11-2008, 06:06 PM   #25
s10-den's Avatar
If the filter gets soaked enough, then yes some water will get sucks through.
Old 07-11-2008, 08:34 PM   #26
ls1 on the works!!
bitchin sonoma's Avatar
bitchin sonoma
post them up, becuase in the future i am aiming at putting twin turbos on my truck!!!
Old 07-12-2008, 11:34 AM   #27
LS1Shorty is on a distinguished road
Anyone have any "cold air" intake photos? thanks
Old 07-12-2008, 07:27 PM   #28
Thizz or Die u bezzy. . .
Thizz_Xtreme's Avatar
Thizz_Xtreme is on a distinguished road
your talking about a full length CAI right?
Old 07-13-2008, 12:22 AM   #29
Build it Right!
philntx's Avatar
My original question is asking for owners to post pictures of how they built their air induction systems.
If it's just an elbow with a filter on it....I've got plenty of these.
I'm looking for fabricated either rubber tubing or aluminum.
Sealed air boxes
Fresh air systems with the filter routed out of the engine bay.
Somewhere, I have a picture of an old trans am fender vent that someone installed on an S10 fender. That's where he's getting air for his filter.
I'm sure there are more than what I've already shown that had some thought put into them.
Old 07-13-2008, 08:42 AM   #30
s10-den's Avatar
That would be the chit, the vent for the firebird !!
Old 07-14-2008, 01:12 PM   #31
2000extemeturbo's Avatar
2000extemeturbo is on a distinguished road
I wouldn't mind seeing anything you've got on the turbo 6.0, That looks exactly like what I want to do.
Old 07-14-2008, 06:16 PM   #32
Build it Right!
philntx's Avatar
I probably have several thousand pictures and files on 3 different hard drives.
I emailed the owner, I'm hoping he'll respond with more pictures
Here's another on of the 6 liter single turbo truck:
He ran the iintercooler behind the lower grill on the Extreme bumper:
