Afm 5.3l To Non-afm?? - S-10 Forum
post #1 of 11 Old 01-31-2011, 07:45 PM Thread Starter
I finally got blown
99xtrm's Avatar
User is: 99xtrm is offline
I did a search on this but i can't come up with anything that satisfies me. I'm looking into an 08 aluminum 5.3l w/afm. Can i convert it to non-afm? I was thinking i could switch out the lifters, oil valley cover/oil distribution manifold from a non-afm engine. What about the cam also? i think this one has the vvt plug/solenoid in the end of the cam. Can i put a non-afm cam in the block and be done? do i have to change front engine cover? I was looking at a ls1 98-02 camaro ecm/harness to run it. I guess i would have to change crank triggers/reluctors also. Any and all input welcome and appreciated thanks.
best time of 13.9 looking for 12's. Pics and vids https://myspace.com/270507651
99xtrm is offline
post #2 of 11 Old 01-31-2011, 08:30 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
Re: Afm 5.3l To Non-afm??
Yes it can be done. Someone on here has done it, I think NYCBlazer, but not 100% on that. I think your about on the right track, swap lifter, I think front and maybe rear cover. If your going to run a Camaro ecm, I think you'll have to swap to a 24 tooth reluctor or run a converter.
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #3 of 11 Old 01-31-2011, 08:51 PM
It's a 4. something
scriptedmind's Avatar
User is: scriptedmind is offline
If you're gonna be running a truck engine, why now run a truck harness and PCM? I'm assuming you're building your own harness?
97 S10 RCSB 4.8 V8, 4L60E swap. (Speed)
99 Blazer ZR2 4.3 auto. (Mud/Winter)
2000 Trailblazer edition, 2wd, graphite interior.
13 Ford Fusion Titanium (Wife's DD)
co-owner of S10s Unlimited Inc.
post #4 of 11 Old 01-31-2011, 09:15 PM
Bowtie Til I Die
s10studduts01s's Avatar
User is: s10studduts01s is offline
05 and up blocks don't have the provision for the cam sensor at the back of the block like the blocks from 99-04. So you will have to keep your front cover. Im 99% sure about this
97 rcsb s10 6.0/4l80e w/ turbo...Toy
00 rcsb sonoma 6.0/4l60e...New project
09 Chevy Defender...DD
Looking for used stainlessworks headers
post #5 of 11 Old 01-31-2011, 09:28 PM
On da bottle
zx9rgreen's Avatar
User is: zx9rgreen is offline
I think these guys have it nailed, my blazer project is an 07 afm swapped to non.
"The course of history shows that as the government grows, liberty decreases.” Thomas Jefferson
post #6 of 11 Old 01-31-2011, 09:29 PM
Low_S-10's Avatar
User is: Low_S-10 is offline
Low_S-10 is offline
post #7 of 11 Old 02-01-2011, 06:51 PM Thread Starter
I finally got blown
99xtrm's Avatar
I was looking at this here
http://www.summitracing.com/parts/PRF-60508/
i saw in another thread that a 4l60e would work better than a 4l80e, I'm assuming that if i run the truck pcm i would have to run a 4l80e. ???? Also i dont want any part of an electronic throtle body. I like throtle cables.
99xtrm is offline
post #8 of 11 Old 02-01-2011, 06:52 PM Thread Starter
I finally got blown
99xtrm's Avatar
Thanks that was what i was looking for.
99xtrm is offline
post #9 of 11 Old 02-01-2011, 06:57 PM Thread Starter
I finally got blown
99xtrm's Avatar
I work at a gm dealer. Does anyone know if i can peice together my own kit? Using my discount of course and peicing it together cheaper. If so what kinds of cars trucks do i tell the parts guy to look up? The kits say ls2, ls7 and so forth but they cant look up parts with out a car first. Would i be looking at corvette stuff and which years? Or does anyone have part numbers for the kits.
On the vvt delete kits I'm assuming the front cover on the engine im looking at has to be replaced with an ls1 style, i'm not sure if this aluminum 08 5.3l has a cam crank sensor hole or not.
Thanks everyone for the good information.
99xtrm is offline
post #10 of 11 Old 02-02-2011, 06:48 PM
Low_S-10's Avatar
Originally Posted by Mrgoodwrench3 View Post
The parts can be purchased separately at gmpartsdirect.com
LS7 lifters 12499225
Lifter trays 12595365
Valley cover 12570471
Sprocket 12586481
Dampener 12588670
I would recommend ARP head bolts. 134-3610 best price on ebay. I paid $91.00
get on performancetrucks.net and search around and you will find info on the vvt and afm deletes
Low_S-10 is offline
post #11 of 11 Old 02-03-2011, 06:24 PM Thread Starter
I finally got blown
99xtrm's Avatar
awsome thanks
99xtrm is offline
