9in rear end
will this bolt right into my 01 s10 and can my stock brakes bolt right onto it?
http://store.summitracing.com/partde...5&autoview=sku thanks, Gary |
Gettin' ready for V8!
Re: 9in rear end
Notes:Will fit any aftermarket brake kit with 2.5 in. offset New Style Big Bearing Ford housing ends.
Says it plain as day on the posted link... |
Re: 9in rear end
Re: 9in rear end
9.88@140.86
Re: 9in rear end
factory brakes will not fit it requires ford brakes.
ls1 on the works!!
Location: Benton harbor, Michigan User is: OffLine ![]() |
Re: 9in rear end
why don't you just buy a 12 bolt.I heard tht teh 9 inch takes hp alway.
Build it Right!
Re: 9in rear end
According to the fine print...... It's just money......
Axle packages that will bolt into your vehicle, from Moser. These Moser Engineering 9 in. housing and axle packages give you the freedom to choose components that you prefer, while still fitting your vehicle without any modifications. They include a steel housing, an axle shaft set with wheel studs, bearings, and a drain plug. You can order them with brakes, or to fit your OEM brakes or a specific brake kit. Available in a multitude of options, Moser Engineering 9 in. housing and axle packages are a perfect fit for your everyday driver or performance vehicle. You'll still need the internal components....Gears/Posi. Add another $700-800, installation kit, etc Last edited by philntx : 10-09-2008 at 11:09 PM. |
Strictly Domestic
Re: 9in rear end
Black X, you have a Currie rear end right?
Re: 9in rear end
im going to get a 9 off craigslist/junkyard and narrow/ gusset it myself and go from there
thanks, for the help |
9.88@140.86
Re: 9in rear end
Strictly Domestic
Re: 9in rear end
And no problems at all?
9.88@140.86
Re: 9in rear end
none at all. My brothers truck and my dads car also have the currie units.
ls1 on the works!!
Re: 9in rear end
I Know For Now I Am Installing Moser Axles And A Posi On 7.5 Rear End,i Hope My Truck Will Hanlde The 500 Plus Horepower I Am Going To Throw At It.if It Doesn't I Will Just Put A Moser 12 Bolt.
Re: 9in rear end
Strictly Domestic
Re: 9in rear end
My buddy has a Moser 12 bolt in his Monte Carlo SS, and its a great rear. I was just wondering why do most people go with a Ford 9 inch? Easier? Stronger?
ls1 on the works!!
Re: 9in rear end
there might be a little hook up.
Re: 9in rear end
you can change the gear ratio's in them quick. all nascar teams run a 9 inch too.
Strictly Domestic
Re: 9in rear end
Yeah the whole center cection and all comes right out of the front.
Re: 9in rear end
I just ditched my 9" in my s10 for a ford 8.8
Re: 9in rear end
Re: 9in rear end
BAGS FTMFL
Re: 9in rear end
8.8" ftmfw! ![]() Last edited by v8lonoma : 10-14-2008 at 11:32 AM. |
5 speed 4 door blazer
Re: 9in rear end
i would go with a ford 9 inch just cause its easier to change out parts, and if nascar uses them on chevy's also that could mean its more reliable than a chevy rear or easier to change.
#24 |
Re: 9in rear end
alot of fbody's use 9" rears because the housing is supposedly stronger which with their torque arm they need. i've heard in many cases that the torque arm stresses the housing, 12 bolt may warp a little and it will have a horrible gear whine because of it, where as the 9" has never had that problem. plus the 9" will handle a bit more power because of its greater contact patch on the pinion, hence the 2-3% power loss over a 12 bolt. but if you really want to be bullet proof, go for a dana60, they'll support over 1200hp in factory setup.
#25 |
Re: 9in rear end
The 9" robs less horsepower than the big GM rear.
#26 |
Registered Abuser
Re: 9in rear end
black has an aluminium ford 9 ..... which i am envious of. but it's coo
#27 |
Re: 9in rear end
#28 |
Re: 9in rear end
#29 |
Registered Abuser
Re: 9in rear end
its already right length for the s10, you will still require a third member shafts and rotors and brakes.
#30 |
Re: 9in rear end
man i want a 9 inch mosier for my 1999 4 dr blazer soo bad
