98 s10 5.3/4l60e
Old 09-04-2008, 04:29 AM   #1
Location: i live in huffman tx.on 2 acres north of houston
chevysten is on a distinguished road
98 s10 5.3/4l60e
How can I get my gauges to work,oil,temp,fuel?Sent my pcm and harness to Jared at CPW.He is going to rework my harness but the gauges will not work.Will I have to use my 4cyl.pcm to make them work?
thanks for your input Mike
Old 09-04-2008, 03:26 PM   #2
Need LSx swap.....
Kampz69's Avatar
Kampz69 is on a distinguished road
Re: 98 s10 5.3/4l60e
did you ask Jared? everything should work as stock when you get the ECM/reworked harness back.
Old 09-04-2008, 03:41 PM   #3
Yes,I think he said that it would'nt.I'll have to call him.
Old 09-04-2008, 04:52 PM   #4
Makin Sparks
97 SS 350's Avatar
97 SS 350 is on a distinguished road
A new harness is designed to plug in and make everything work.
The reworked/Stand-alone harness are designed to run the engine only (That's why it's cheaper). The rest is up to you.
Old 09-04-2008, 05:19 PM   #5
In order for my gauges to work,do I have to use my old pcm?Run both pcm's?One for the motor and trans and the other for gauges?
Old 09-04-2008, 05:24 PM   #6
Makin Sparks
97 SS 350's Avatar
Typically you would just use the 5.3 computer to do everything.
Old 09-04-2008, 10:09 PM   #7
OK thanks Jared.I'll be talking to you soon.
Mike
Old 09-05-2008, 01:10 PM   #8
Wannabe Dragger
ExtCab96S_Dime's Avatar
ExtCab96S_Dime is an unknown quantity at this point
Really? I think the sticky might be outdated then, because I believe it says to just use the engines computer for just running the engine and the stock computer in the truck for the rest of the functions in the truck (gauges, abs, etc.) If I can just use one computer, that would be awesome.
Old 09-05-2008, 01:22 PM   #9
Wannabe Dragger
Nevermind, I'm a damned retard. lol I was reading for the LT1. Damnit, sorry guys.
Old 09-05-2008, 03:29 PM   #10
denali_on_26's is on a distinguished road
so what all do you have to do to make your factory gauges work with the stand alone wiring harness???
this it gonna be VERY IMPORTANT in my build also
Old 09-05-2008, 03:35 PM   #11
Makin Sparks
97 SS 350's Avatar
Well... The stand-alone harness has the outputs from the computer for tach and speedo. You will have to find out where to splice those in to the truck, then, find the schematics for the rest of your gauges and figure out where to put the wires for those. Either they will go to a sending unit directly, like the oil pressure, or they may need to go to the computer depending on the gauge and the year of the truck.
Enjoy!!
Old 09-05-2008, 06:35 PM   #12
O...ok i can do that... just as long as the gauges don't need to go through the computer i will be OK
Page generated in 0.11822 seconds with 11 queries
