Makin Sparks
98-99 Manifolds
Okay, as the debate goes on about manifolds vs. headers, we decided to check something out.
With our coming 1-3/4" headers, we wanted to see what the stock F-body manifolds would do on a modified engine, so when we bolt up the headers, we can see what difference it gets. Engine is a '99 LS1 with 90mm Throttle body, FAST intake, Dart 225 heads, and a custom cam. The manifolds choke the engine around 5400 RPM. Now, in the next few weeks, we will have a dyno pull of the 1-3/4" long tube headers coming soon. I wish we had time to bolt up the Sanderson Shorty's, but that's just not going to happen this time around. |
Build them right....Mod
Re: 98-99 Manifolds
Wow! Was this on a chassis dyno? Even with stock exhaust manifolds, this little motor makes some great HP/Torque numbers!
Keep up the great work/research! |
Makin Sparks
Re: 98-99 Manifolds
Those are SAE numbers which by most accounts are low. STD numbers are higher, so most people like those better. |
i like (.)(.) & \'/
Re: 98-99 Manifolds
well my buddy has a 99 t/a with a ok cam and a ls6 intake and stock t-body and long tubes everything else is stock and his sae numbers were 367rwhp and 345rwtq on a dynojet dyno if that helps any..
also that was through a broke convertor (would not stay in lock up) |
Re: 98-99 Manifolds
This is why I want tubes before I do internals to my ls1. Thanks can't wait to see numbers on the tubes.
i like (.)(.) & \'/
Re: 98-99 Manifolds
have you had time to slap a set of shorties on the dyno yet?
he,he,he project over kil
Re: 98-99 Manifolds
when is this 1 3/4 will be done and how much?
Makin Sparks
Re: 98-99 Manifolds
Well... I just got off the phone with the people who are making the tubes for me. They are going to try and have them done by next week. So Hopefully it won't be too much longer.
Still shooting for around $750. We will see once we get a few sets all done though. |
i like (.)(.) & \'/
Re: 98-99 Manifolds
Re: 98-99 Manifolds
Awesome jared keep up the good work.
Good Bye SonomaST
Re: 98-99 Manifolds
i dont have any plans of putting a LSx in my truck in the very near future, but these 1.75 long tubes even excite me lol
Re: 98-99 Manifolds
Why arent you doing these on an engine dyno? That way you can do the testing on the same day, which makes results much more accurate.
Re: 98-99 Manifolds
If I had a set I would do it for you tommorow morning.
Makin Sparks
Re: 98-99 Manifolds
Registered (Ab) User
Re: 98-99 Manifolds
