89 s10 ls2 swap - S-10 Forum
post #1 of 164 Old 07-26-2012, 11:03 PM Thread Starter
joey
chargedextreme's Avatar
User is: chargedextreme is offline
Send a message via AIM to chargedextreme
89 s10 ls2 swap
doing a ls2 swap on my 1989 s10,currently has a built 358 sbc in it and recently decided to change it up and go to a ls2 fuel injected,cant beat the power of a lsx motor. so i will be posting pictures of the swap as i go, and would appreciate all the helpful info along the way.
today i picked up my ls2 motor its out of a 06 trail blazer ss with 6k miles on it got it for a great deal
also my cpw h3 oil pan kit cam in
2004 ford f250 Harley-Davidson edition f-250 lifted 8'' on 38s,mbrp turbo back
2000 s10 xtreme 4.3 want to sell
1989 s10 ls2,tsp torquer v3 cam,fast 102 intake,fast 102 tb,built 4l65e 4k stall,cpw long tubes,one piece drive shaft swap,billet specilties street lite drag wheels,ford 9in rear. track times to come this spring
1994 ford f150 custom exhaust,bbk headers,k&n intake
post #2 of 164 Old 07-27-2012, 04:45 AM
Un-Registered User
calebmcclellan's Avatar
User is: calebmcclellan is offline
Re: 89 s10 ls2 swap
Looks like a good start. You gonna put one in that vette too?
post #3 of 164 Old 07-30-2012, 08:44 PM
93LsxWannabe's Avatar
User is: 93LsxWannabe is offline
Re: 89 s10 ls2 swap
I'm going to be watching this one, and hopefully learn some stuff for my swap.
I have a 93 s10 that I want to swap a 5.3 into.
Good luck man!
post #4 of 164 Old 07-30-2012, 09:45 PM Thread Starter
joey
Re: 89 s10 ls2 swap
got my swap mounts in today
ordered a set of speedhut gauges for the build. I got the gauge idea from another members build he is doing. the ones i ordered are black backing silver bezel with red pointers and blue lighting
this picture of his gauges
post #5 of 164 Old 07-30-2012, 10:44 PM
Ls1 Bagged
10Droped's Avatar
User is: 10Droped is offline
Re: 89 s10 ls2 swap
Like the gauges.. How about a pic of the truck.
Jim
99 S-10 Ext cab, Bagged, 20&22's Bonspeed Sweeps, 40"x35" Legacy sliding rag top,99 LS1/4L60E,Circle D 278mm 3200 stall,243 heads,PAC 1218 springs, BTR trunion kit, 228r 112Lsa,Ls6 intake,Bosch 36lbs injectors, Eaton Tru Trac, Moser Axles
10Droped is offline
post #6 of 164 Old 07-30-2012, 10:57 PM Thread Starter
joey
Re: 89 s10 ls2 swap
needs to be painted thats next after the ls2 swap
post #7 of 164 Old 08-04-2012, 03:56 AM Thread Starter
joey
Re: 89 s10 ls2 swap
started stripping the frame for paint today
post #8 of 164 Old 08-04-2012, 05:07 AM
billetproof97''s Avatar
User is: billetproof97' is offline
Re: 89 s10 ls2 swap
Nice build so far. Any plans for the ls2 or is it just pretty much going in as is?
U.S ARMY MP
97' s10 single cab w/98 front end conversion w/8k's,autopage alarm,red top,shaved doors,dual 480's, 8 gallon/SD arms,slams,SD 3link,SD B&U,airlift, 4 sundown audio E8'sLSX swap, BRPLSX/T-56mount kit-parting out
88'Mustang GT 5.0-trickflow trackheat, trickflow 11R 190's, stockblock w/factory forged pistons,NX Plate kit
R.I.P. Terryl ('57 -'09) you will be missed
post #9 of 164 Old 08-04-2012, 10:10 AM Thread Starter
joey
Re: 89 s10 ls2 swap
Thanks.. ls6 intake manifold ported,tsp torquer v3 cam,tsp push rods,ls7 lifters, lower pulley, nitrous works nitrous kit. about it for now
post #10 of 164 Old 08-04-2012, 12:02 PM
User is: txsilverado is offline
Re: 89 s10 ls2 swap
how much did those gauges set you back?
just your average LS2 S10
post #11 of 164 Old 08-04-2012, 03:32 PM Thread Starter
joey
Re: 89 s10 ls2 swap
537.42
post #12 of 164 Old 08-04-2012, 03:43 PM Thread Starter
joey
Re: 89 s10 ls2 swap
today my 2010 camaro l99 water pump came in
and my headers i got screwed over with from another member claimed they were 1 5/8 but there 1 1/2 there brand new were just bolted up
post #13 of 164 Old 08-04-2012, 04:56 PM
Re: 89 s10 ls2 swap
Some good mods for the ls2. Sucks you got screwed over on the shorties.
U.S ARMY MP
post #14 of 164 Old 08-05-2012, 02:36 AM Thread Starter
joey
Re: 89 s10 ls2 swap
shaved some holes in the fire wall and stripped the frame ready for primer
got 3 coats of primer on it laying the gloss black tomorrow
post #15 of 164 Old 08-05-2012, 07:26 PM Thread Starter
joey
Re: 89 s10 ls2 swap
painted the frame and fire wall gloss black with 3 coats of clear
3 coats of gloss black
3 coats of clear coat
post #16 of 164 Old 08-05-2012, 07:48 PM
Air ride & Audio
s10gmconversion's Avatar
User is: s10gmconversion is offline
Re: 89 s10 ls2 swap
Looks good. Did you use a gun? If so what paint?
Cameron
WANTED for 98+...
any kaik billet accessories
post #17 of 164 Old 08-05-2012, 07:53 PM Thread Starter
joey
Re: 89 s10 ls2 swap
yea i used a hvlp gun and the paint i used was the dupli color BSP200 - Jet Black
post #18 of 164 Old 08-09-2012, 06:31 PM Thread Starter
joey
Re: 89 s10 ls2 swap
tsp torquer v3 cam came in today
post #19 of 164 Old 08-10-2012, 07:06 PM Thread Starter
joey
Re: 89 s10 ls2 swap
I got some more parts in today
ls6 intake manifold swap
ls1 coolant cross over pipe
double valve springs,retainers,locks,valve seals
push rods
post #20 of 164 Old 08-11-2012, 12:34 AM Thread Starter
joey
Re: 89 s10 ls2 swap
tore down the motor some so i can install my new cam shaft
post #21 of 164 Old 08-12-2012, 03:18 PM Thread Starter
joey
Re: 89 s10 ls2 swap
installed the camshaft and started on the valve springs
valve springs on both sides done
post #22 of 164 Old 08-13-2012, 03:27 AM Thread Starter
joey
Re: 89 s10 ls2 swap
cleaned up the block and put the h3 oil pan on
set the motor in for the first mach up
got alot knocked out just figuring out what all i need to get or modify to get it all to work
post #23 of 164 Old 08-13-2012, 09:06 AM
s-10ls1's Avatar
User is: s-10ls1 is offline
Re: 89 s10 ls2 swap
Since project man! The build is looking good!
Tuned by Patrick G
s-10ls1 is offline
post #24 of 164 Old 08-13-2012, 04:43 PM
User is: 07slobalt_1 is offline
Re: 89 s10 ls2 swap
Nice! Your gonna love the ls power!
post #25 of 164 Old 08-13-2012, 05:55 PM
User is: twomanyjeep is offline
Re: 89 s10 ls2 swap
Really clean work...Just wondering what did you do to clean and strip the frame. Also the L99 engine has VVT, and if I'm correct, the water pump should have some kind of spacing to make room for the larger timing cover associated with VVT engines. If so, what other accessories are you running (Car or truck)? I'm just curious to see what spacing is like for all the pulleys. Thanks and keep up the great work!
post #26 of 164 Old 08-13-2012, 06:07 PM Thread Starter
joey
Re: 89 s10 ls2 swap
Thanks, I used thinner and a wire wheel to clean the frame. the l99 water pump works great for running truck accessories with no spacers on the pump
post #27 of 164 Old 08-14-2012, 12:02 AM
User is: Lead foot is offline
Re: 89 s10 ls2 swap
Looking good and moving pretty quick...Any pics of the water pump and truck accessories all bolted up...
post #28 of 164 Old 08-14-2012, 02:03 AM Thread Starter
joey
Re: 89 s10 ls2 swap
put my suspension back on today speedway uppers,qa1 r series coil overs,blazer 2in drop spindles with duel piston brakes
mocked up the water pump and truck accessories
post #29 of 164 Old 08-14-2012, 02:06 AM Thread Starter
joey
Re: 89 s10 ls2 swap
Thanks man. Posted up some pics of it mocked up
post #30 of 164 Old 08-14-2012, 03:42 AM
Re: 89 s10 ls2 swap
Thanks alot for your pics
post #31 of 164 Old 08-14-2012, 06:31 PM Thread Starter
joey
Re: 89 s10 ls2 swap
my speedhut custom gauges came in today
post #32 of 164 Old 08-15-2012, 03:23 PM
lq4 s10
86jward's Avatar
User is: 86jward is offline
Re: 89 s10 ls2 swap
I would love to see some detail on how u install these and how u make your gauge pod. Great build btw keep up the great progress.
86jward is offline
post #33 of 164 Old 08-15-2012, 03:27 PM
lq4 s10
86jward's Avatar
Re: 89 s10 ls2 swap
Just realized your from stafford, my mom and sister live a little south of you in spotsylvaina.
86jward is offline
post #34 of 164 Old 08-15-2012, 07:32 PM Thread Starter
joey
Re: 89 s10 ls2 swap
I will be making the gauge cluster tomorrow using a 1/8 thick textured abs plastic sheet in place of the stock cluster. tonight im fabing up the core support to inset the radiator into it. when you come in town next hit me up and check out the truck
post #35 of 164 Old 08-16-2012, 12:58 AM Thread Starter
joey
Re: 89 s10 ls2 swap
modified the core support so the radiator will fit inside it not done yet but here is where i left off at
post #36 of 164 Old 08-16-2012, 08:49 AM
lq4 s10
86jward's Avatar
Re: 89 s10 ls2 swap
Sure, I'd love to see one mostly done. Seem like nobody around here is doing an ls swap.
86jward is offline
post #37 of 164 Old 08-16-2012, 09:50 AM
User is: j-cheezy is offline
Re: 89 s10 ls2 swap
how well does the ls6 intake seal up on the ls2 heads because ls2 heads are cathedral ported on the intake side and ls6 intakes are setup to be on rectangular ported heads im not tryin to be negative or rip on your build I was just was wondering and thaught I would ask
j-cheezy is offline
post #38 of 164 Old 08-16-2012, 12:28 PM
art
( . Y . )
art's Avatar
User is: art is offline
Re: 89 s10 ls2 swap
Ls6 and Ls2 have cathedral port heads. The newer 6.2l and a few 6.0 come with the square port heads.
Part collecting for LSx swap...
Built "5.3"
My wife's mood depends on the size of the boxes UPS leaves at the door.
art is offline
post #39 of 164 Old 08-16-2012, 01:51 PM
lq4 s10
86jward's Avatar
Re: 89 s10 ls2 swap
Plus the ls2 heads are the same heads with exception of the valves. Ls2 has solid and ls6 has light weight hollow valves.
86jward is offline
post #40 of 164 Old 08-19-2012, 03:08 AM Thread Starter
joey
Re: 89 s10 ls2 swap
started doing the gauge cluster today
laying in there the reason its crooked in there
post #41 of 164 Old 08-19-2012, 03:08 AM Thread Starter
joey
Re: 89 s10 ls2 swap
forgot to show when my gauges came in
post #42 of 164 Old 08-20-2012, 12:42 AM Thread Starter
joey
Re: 89 s10 ls2 swap
finish the gauge cluster today
post #43 of 164 Old 08-20-2012, 07:01 PM Thread Starter
joey
Re: 89 s10 ls2 swap
plug wires and socks came in
post #44 of 164 Old 08-20-2012, 09:03 PM
Re: 89 s10 ls2 swap
i really like those guages, but can't seem to find them on their site. can you help point an idiot in the right direction? they have a TON of selections.
post #45 of 164 Old 08-20-2012, 09:31 PM Thread Starter
joey
Re: 89 s10 ls2 swap
http://www.speedhut.com/custom_gauge...number-896.htm
post #46 of 164 Old 08-21-2012, 07:19 PM Thread Starter
joey
Re: 89 s10 ls2 swap
corvette belt tensioner
fast fuel rail and moon fuel pressure gauge
[IMG]http://sphotos-a.xx.fbcdn.net/hphotos-snc7/424210_10151027186286270_781038227_n.jpg[/IMG
standalone wiring harness from cpw
and ecm
post #47 of 164 Old 08-23-2012, 05:49 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
Re: 89 s10 ls2 swap
Couple questions, what PCM are you using? It looks like it only has 1 plug on your harness for the PCM, mine has 2, Red and Blue. Why did you get a Corvette tensioner if your running truck accessories, isn't the spacing for the belt going to be off, causing you to space out the tensioner, or does it mount on the waterpump? Did that engine have the stock GM red plug wires on it, and if so, do you want to sell them? Please feel free to pm me back on this question. Looks like a great build!
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #48 of 164 Old 08-24-2012, 11:33 AM
Rolnlow
railn20s's Avatar
User is: railn20s is offline
Re: 89 s10 ls2 swap
with the newer camaro water pump (L99) you have to use the that tensioner with the truck pulley on the tensioner to get everything to line up so the belt fits. I did the same thing on mine and work great.
nice looking build, cant wait to hear it run
railn20s is offline
post #49 of 164 Old 08-24-2012, 11:40 AM
Need LSx swap.....
Kampz69's Avatar
User is: Kampz69 is offline
Send a message via AIM to Kampz69
Re: 89 s10 ls2 swap
yea the L99 water pump has a "truck" alignment, its spaced out from the block to clear the vvt.
Nick
Currently Blazerless...but looking
Graphite Double Din bezel for sale, PM me!
OEM new Maroon plastic air dam for sale, PM me!
Originally Posted by AVdime View Post
it was just an old factory with a bunch of whores
Kampz69 is offline
post #50 of 164 Old 09-01-2012, 12:24 AM Thread Starter
joey
Re: 89 s10 ls2 swap
have not posted in a little but got some progress done
all the wiring harness layed out gotta tape and loom them in the am
powered up my gauges
where i put my harness threw the firewall not cleaned up and riveted on yet
my ford 9" disc brake conversion
