6.0L won't rev past 1400 rpm?
Old 05-01-2008, 01:15 AM   #1
Sherk is on a distinguished road
It's an '03 out of a van, tune is an '02 Silverado 6.0 tune so it would work with the 411 PCM already in place. (Using EFILive for flashing). Truck is a 2000 S10 that had a 4.3/5 spd.
Either I've got a tuning issue somewhere (I wouldn't think so, the engine is totally stock), or something else is wrong...
I can't rev the engine past 1400 rpm! This is killing me. I can stab the throttle and get it up to maybe 2k very temporarily but it bounces back down extremely quickly. I can give it light throttle under 1400 rpm and am able to hold rpms, but if I get up to that level, it knocks me down.
Same issue in gear (manual transmission), I've got it up on jackstands but I've tried running it and it won't go over the same 1400 or so. Rev up, stumble down...
I've tried running with and without the MAF, unplugging the TPS and IAC (still cable driven throttle), can't get anything to change. Everything is up to operating temp (100C or so), no DTCs except the CKP relearn (can't do because I can't get to 5k) and 4 other ghost ones for the U0000 stuff.
I checked all over for vacuum leaks and can't find anything (the idle is very good too, leading me to believe that's not the issue). Fuel pressure is 4 bar without the vacuum line on, about 50 PSI with it in place... goes up slightly when I bump the throttle and goes down to 48 or so when I leave the throttle steady about 1k rpm...
All cyls are getting spark, I did a cylinder balance test and everything looks good, I think. I don't know what else to do...
Old 05-01-2008, 02:19 AM   #2
LSX Swapper
sparkinak's Avatar
sparkinak is on a distinguished road
Re: 6.0L won't rev past 1400 rpm?
who did the harness cause I wonder if something isnt hooked up correctly, Like the engine is looking for a particular parameter and isn't seeing it so its stayin a safe mode?? not sure but just a thought.
Old 05-01-2008, 07:16 AM   #3
Makin Sparks
97 SS 350's Avatar
97 SS 350 is on a distinguished road
Is the '02 6.0 tune set for electronic throttle instead of cable throttle? That will cause what you are seeing without a doubt.
Old 05-01-2008, 09:35 AM   #4
jhankinson's Avatar
jhankinson is on a distinguished road
my P/N switch got grounded out and it did the exact same thing. Cuase it sensed it was ALWAYS in park or nuetral. Just another option
Old 05-01-2008, 02:10 PM   #5
I switched over to another tune from an '00 Silverado just to be sure that ETC was off. That apparently isn't the problem...
As for the P/N switch, I don't know how that would be wired up. It's a manual transmission (T56)... so it should only have the VSS output and backup lamp indicator wiring, right? The only other plugs that I can think of back there are the CAGS plug and a reverse lockout solenoid...
The clutch pedal position switch is wired up correctly, as you have to press the clutch to the floor to get the truck to start...
The tune has Camaro manual trans segments copied over, so it should not be asking for auto tranny stuff, right?
Old 05-01-2008, 04:31 PM   #6
jhankinson's Avatar
OO ok yes...then you shouldnt have any of that active. Hmm dunno man sorry
Old 05-01-2008, 05:50 PM   #7
camaro1 is on a distinguished road
what are you using to tune it,, post up your tune
Old 05-01-2008, 08:51 PM   #8
jnoehl's Avatar
jnoehl is on a distinguished road
hmmm... i've heard of something similar to this. try this.
i know it wont rev past 1400 when the car is in neutral, try seeing if you can push the clutch in and see if it will rev. if that is the case then its the sensor on your clutch pedal.
Old 05-02-2008, 07:41 AM   #9
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
about like the rental cars have the rev limiter on them...Not very good at 5000rpm's neutral drops,just kills it.
Old 05-02-2008, 10:34 AM   #10
Found the issue...
It was the cam position sensor. I got to thinking of why it was having rev limiter issues and unlugged that... as soon as I did and started it up, she was able to rev to the true limiter. What a beautiful sound.
Now I gotta go get a CMP sensor.
Old 05-03-2008, 10:41 AM   #11
Good Bye SonomaST
91sonomast's Avatar
91sonomast is on a distinguished road
awesome dude, glad u got it figured out
Page generated in 0.14118 seconds with 12 queries
