#101 |
More Go then Show
Re: 5.3l Swap Back from college finally!
whats IAC?
#102 |
Sdimess84
Idle air control. its on the driver side of the thottle body
#103 |
More Go then Show
have you talked to jared at all about it?
#104 |
Sdimess84
Yeah we are he is lost on it too. He wants me to send him my ecu and predator tuner to him so he can take a look at everything. The only problem is finding a donar 03 ecu to use.
Have you gotten your problem fixed yet? |
#105 |
Sdimess84
the king, have you talked to jared any?
#106 |
first try checking the fuel pressure. easiest way there is to see is the motor has a fitting on the fuel rail (kinda like a valve stem on a wheel), connect a gauge and see what the pressures are. might have too low of pressure.
If not that, try looking at the egr valve. You start getting into diagnosis mode there. checking supply voltages and looking at input signals. To me it sounds like a fuel related issue. You have fuel and spark because it is running. Do you have hookup for OBD 2? And if so does it pop up any codes? |
#107 |
More Go then Show
I do not have my egr hooked up right now and yes it does throw a code for that? Is there a way to turn it off using the predator programmer?
And zerocool i have not talked to jared about this problem yet. |
#108 |
Sdimess84
In the predator there is some egr stuff you can turn off. I did it with mine, even though the 03 motors didnt have egr. It was weird. What egr codes are you throwing?
#109 |
I'm wondering if the programmer is seeing the codes from the egr and either dumping more fuel in or taking fuel away. I would definitely try starting there before doing anything else. Not familiar with the programmer itself, but definitely talk with the tuner to see if there is ways around the egr.
#110 |
More Go then Show
Well guys, thanks for the help for now. I'm off to europe for 2 weeks! So hopefully zerocool will have some answers from jared by then. When i get back i'll have some time off before i go back to work to figure this beast out.
#111 |
Sdimess84
Ill let you know if I find anything. Have a good trip!
#112 |
More Go then Show
hey zerocool i stoped by a internet caffe cause i wanted to see if you had any progress and i didnt see any news? are you still working with jared on it?
#113 |
Sdimess84
#114 |
guys breaking his shoes about estimating 10k invested. Thats just about right, its not the big stuff but the little stuff that rack the price up, like going down a getting a few race fittings for power steering or the fuel line $100 bucks here and there add up so quick. ordering misc parts like headers motor mounts radiators efans wiring, fluids for startup are easily a 100 etc The project is coming out great and really impressed me. I'm doing a build myself and totally know how the pennies go, keep up the great work man
#115 |
I WISH I only spent 10k on my swap
Double that and your close to everything I spent on mine haha |
#116 |
Sdimess84
mine costed me about 6500ish
#117 |
More Go then Show
#118 |
My boy says....F*ck You!!
Nice! That is around the "red light" district! LOL.
#119 |
More Go then Show
ya its pretty much down from the Redlight District
#120 |
ls1 junkie
how did you hook your emergency brake cables up to the disc brakes on the rear? im putting F-body brakes on the back of my 03 X and im not sure how to hook them up. what did u do or use to make them work?
#121 |
AKA DavidAndSomeNumbers
Looks awsome! Im really impressed by what you have done so far. Keep it up.
#122 |
Wannabe Dragger
THEKING - How much have you spent specifically on the engine and accessories for the engine so far?
#123 |
takes 2 balls in our game
you drove it yet?
#124 |
More Go then Show
And no i havnt driven it do to the fact that there is a problem with my computer. It was running fine for like 5 minutes straight then the fuel line poped off the in tank line. Now it will start but only stay running if i hit the gas. Jared has the computer as of today and i should have it ready for next weekend. But that ok cause this weekend is pheasent opening! Go get me some birds. |
#125 |
Wannabe Dragger
That's cool, I was just wondering. How much did you get the engine, harness and computer for?
#126 |
More Go then Show
i thought you meant like everything having to do with the drivetrain, hah. But i got the engine for 1200 all accessories, ecu, wiring, intake, the works and 24k miles. Trans was 900 with lower miles then the engine.
And all this was bout right around 2 years ago when i started the swap, i only work on this during the summer when i'm not in school. |
#127 |
Wannabe Dragger
Oh, ok, that's a pretty nice deal. Where from?
#128 |
More Go then Show
Local yard in my area, free delivery. I feel i did ok. Some people get them really cheap.
#129 |
Sdimess84
Any news on your computer from Jared yet?
#130 |
More Go then Show
Ya i've just been broke and hunting on the weekends. But he should have sent it out last thursday or friday, i'm calling him tomorrow to confirm and i should have it by this weekend!
#131 |
SK Whut !?!
Could it be a weak alternator or a going bad battery??? ![]() But good work |
#132 |
More Go then Show
well i'm going to the junk yard then working on it all day. I'll let you know before the end of the day.
#133 |
More Go then Show
Ok so here is what happened. I put the new computer in from jared took out the IAC and pushed the plunger all the way in. The first start went was kinda rough but after a few seconds it held at around 800 rpm. Second start was fine as well. Third start it went to 800 rpm then died shortly after.
So i check the IAC and it was fully extented, I pushed it back in all the way. This time on the start it reved to around 2000 rpm then bumped up to about 3000 rpm before i shut her off. I think the IAC is all fucked? |
#134 |
Sdimess84
It could be. Try going to the parts house and getting a new one. they are about 60 bucks.
#135 |
More Go then Show
I'm selling some interior pieces.. more like just giving them out for free take a look if your in my area!
http://www.s10forum.com/classifieds/...1&cat=4&page=1 |
#136 |
More Go then Show
I ordered some O2 sensors for the exhaust i don't have. But i got some header extensions from summit to weld some bungs on to test it out and see if it helps any of the engine problems.
![]() Been putting more body pannels on her. ![]() Its like a snorkle, kinda. |
#137 |
Neglected & Broke
lookin good man, coming along nicely
#138 |
Sdimess84
Let me know how those fans work as pushers.
#139 |
More Go then Show
#140 |
Sdimess84
I dont see why not. mine are pullers, and they are the exact same fan. I had to trim off the little stub coming of the water pump
#141 |
More Go then Show
I didn't know if that was allowed or not?
#142 |
Stock tires with 5.7
Awsome man! ima keep stopin by and lookin!
#143 |
Call me Mario, Princess
#144 |
what is the normal operating temp for these gen III engines?
#145 |
More Go then Show
i don't know. if i see smoke its getting too hot i think.
#146 |
#147 |
More Go then Show
IT RUNS
Well it ran before but the idle was all screwy and i wouldn't have been able to drive it. But now it runs fine and everything. To this point i have no idea what exactly was wrong. I had to switch to the new HP tunners software. Jared is the man and helped me threw all this, this is why you pay the extra bucks to go threw him! |
#148 |
Sdimess84
Good deal. Glad you got it running!
#149 |
An ol Scott
Location: Greenville/Simpsonville SC User is: OffLine |
I'm on the road as a aircraft electrician/avionics man so I don't have a garage-here-to work in nor do I carry/lug around all my tools. So for this old guy it's let a pro do it for me. Wellllll....most of it anyway.
New MrGoodWrench LS2, and street/strip auto. My little S10 is my daily driver/hot rod while my two Mustangs stay in storage back in Montana. Cost? 10K to start. Probably going to end up around $15K. |
#150 |
More Go then Show
Well i've been plowing threw a lotta little details recently. Truck goes to a shop to get the brakes figured out this tuesday because i have no idea whats up with them.
![]() ![]() ![]() ![]() Put glass in the doors and installed some interior pieces. Clean up the wiring and installed airbag sensors. Lota other little stuff like i mentioned. |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f213/5-3l-swap-back-from-college-finally-294516/
| ZR2 USA -> Looking for answers! | This thread | Refback | 01-02-2008 05:44 PM | |
| ZR2 USA -> Looking for answers! | This thread | Refback | 01-02-2008 02:05 PM | |
| s10 owners - LS1TECH | This thread | Refback | 12-12-2007 02:00 AM | |
| s10 owners - LS1TECH | This thread | Refback | 12-12-2007 12:58 AM | |
| New England Motorsports - Came Accross A Deal I Couldnt Pass Up (5.3l) | This thread | Refback | 05-10-2007 01:13 PM | |
| New England Motorsports - Came Accross A Deal I Couldnt Pass Up (5.3l) | This thread | Refback | 05-10-2007 12:07 PM | |
| New England Motorsports - Came Accross A Deal I Couldnt Pass Up (5.3l) | This thread | Refback | 05-10-2007 11:41 AM | |
