5.3 turbo build VS Racing 7875 - S-10 Forum
 15Likes
post #1 of 113 Old 11-30-2016, 04:52 PM Thread Starter
User is: ogoz23 is offline
Hey guys I'm starting my 89 blazer build . I will be using a VS Racing 7875 billet turbo on a 5.3 . I started building the cross over pipes today and I notice that the truck manifolds facing forward hit the steering column shaft . Any ideas how I can fix this. I can't move over the engine any more . Here are some pics . Enjoy.
ogoz23 is offline
post #2 of 113 Old 12-01-2016, 08:45 AM
no green's Avatar
User is: no green is offline
Re: 5.3 turbo build VS Racing 7875
I've never seen someone successfully do that. However, to gain room there's the jeep steering shaft mod, and/or you can slot the mounting holes in the column to move it over, and/or put washers between the steering box and frame on the lower bolts to angle it.
G/L with the build, I'm going to use the same turbo on mine.
no green is offline
post #3 of 113 Old 12-01-2016, 08:48 AM Thread Starter
No Green : what is it that you haven't seen someone successfully do? Now you got me scare lol .. are you talking about utilizing the truck manifolds facing forward ?
ogoz23 is offline
post #4 of 113 Old 12-01-2016, 08:54 AM
no green's Avatar
Correct, if you get those manifolds to clear the steering shaft in an s10, you'd be the first that I've seen. However, it looks like you don't have too far to go from the pictures?
Another thing I've seen is angle (or strait) mill the flange on the manifold to get it to clear. I've even seen a guy notch the manifold, and weld in a pipe, but it looked butch.
no green is offline
post #5 of 113 Old 12-01-2016, 09:19 AM Thread Starter
Green : what manifolds are guys using then , I rather just buy the manifold that will clear .
ogoz23 is offline
post #6 of 113 Old 12-01-2016, 09:35 AM
no green's Avatar
I'm building logs. starting them next month.
no green is offline
post #7 of 113 Old 12-01-2016, 09:40 AM Thread Starter
Does anyone know what manifolds are known to clear the steering shaft without building logs ?
ogoz23 is offline
post #8 of 113 Old 12-01-2016, 01:32 PM
It's a 4. something
scriptedmind's Avatar
User is: scriptedmind is offline
There are no stock manifolds or headers known to clear in an S10 LS swap when forward facing. Everything I've ever heard of always hits the steering shaft. That's why everyone either runs a custom setup or a modified driverside header or manifold.
97 S10 RCSB 4.8 V8, 4L60E swap. (Speed)
99 Blazer ZR2 4.3 auto. (Mud/Winter)
2000 Trailblazer edition, 2wd, graphite interior.
13 Ford Fusion Titanium (Wife's DD)
co-owner of S10s Unlimited Inc.
post #9 of 113 Old 12-01-2016, 01:34 PM Thread Starter
How can I modify the manifold ? Just grind away material ?
ogoz23 is offline
post #10 of 113 Old 12-01-2016, 09:20 PM
User is: cookmaster301 is offline
just move the column down and over. cut the hole where the column comes through the firewall and drill new holes
post #11 of 113 Old 12-01-2016, 10:35 PM Thread Starter
Are there any pictures of this mod ? How much can I move it over (about 1 1/2" ? )
ogoz23 is offline
post #12 of 113 Old 12-02-2016, 10:52 AM Thread Starter
Got it to work .
1) shim the gear box to angle it
2) move the steering column, down and to the right
3) 3 minutes of grinding the manifold sides
4) 20 hours of stressing 30 minutes of work time .
scriptedmind and no green like this.
ogoz23 is offline
post #13 of 113 Old 12-02-2016, 02:25 PM
no green's Avatar
Nice!! Put up some more pictures when you're further along.
no green is offline
post #14 of 113 Old 12-04-2016, 02:13 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
Yeah glad to hear you got it to fit. Post up some pics from the front/driver corner so we can see how it fits better. Do you have the front accessories drive on?
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #15 of 113 Old 12-05-2016, 06:11 PM Thread Starter
I'm changing the route I'm taking with the downpipe . I tacked in place some V-bands to see if I like it .
ID:	268289   Click image for larger version
scriptedmind likes this.
ogoz23 is offline
post #16 of 113 Old 12-05-2016, 10:21 PM Thread Starter
Is this water to air inercooler to small ? It measures 5x8. I want to keep my AC . Any other ideas ?
ogoz23 is offline
post #17 of 113 Old 12-05-2016, 11:01 PM Thread Starter
I didn't realize you need a heat exchanger for the water to air inercooler... now I have no idea where to put it. Need advise on this one .
ogoz23 is offline
post #18 of 113 Old 12-06-2016, 02:00 PM
no green's Avatar
I'm (hopefuly) going to put a treadstone tr1235 in mine in front of the condenser, but not until after Christmas.
I bought a used a/w intercooler, but once I figured out the pump and heat exhanger would be more money than the treadstone, and more complex, I changed it up.
This was my plan, but not sure about servicing it (dumping water all over the engine when I take it off) and it needed surgery after I installed the wiper motor it didnt fit this nice.
no green is offline
post #19 of 113 Old 12-06-2016, 02:07 PM
no green's Avatar
This is what I ended up buying: https://www.maperformance.com/produc...rcooler-tr1235
This is my buddy's install on the same one: http://www.s10forum.com/forum/f213/p...14/index2.html
no green is offline
post #20 of 113 Old 12-06-2016, 02:14 PM
no green's Avatar
The billet 7875 you have is 1000 crank hp worth of turbo, that's way undersized for the turbo capacity. If you fast forward in the thread, tiresmokinv8 makes like 750 wheel with that treadstone, with cast precision.
no green is offline
post #21 of 113 Old 12-07-2016, 08:10 AM Thread Starter
I like the idea of that innercooler, I wonder if I can make it work on a 1st Gen .. also what would I do for the grill ? I guess the inner cooler will be the grill?
ogoz23 is offline
post #22 of 113 Old 12-07-2016, 08:23 AM
no green's Avatar
I've seen that done, there's a local guy with a big cx intercooler frenched into his grill. Might want to check out Barry's build, though... http://www.s10forum.com/forum/f213/s...49/index4.html
and 'ohcrapitsdave' did a couple with ac and a/w intercoolers, but bigger ones. check out frozenboost.com
no green is offline
post #23 of 113 Old 12-07-2016, 11:58 AM Thread Starter
Damn Cookmaster I saw your truck.. That's sweet!!!
ogoz23 is offline
post #24 of 113 Old 12-08-2016, 01:06 AM Thread Starter
I think I want to run a set up like this , I believe this is a Mishimoto intercooler , I wonder what size is it .
ogoz23 is offline
post #25 of 113 Old 12-08-2016, 08:09 AM
no green's Avatar
That's just like the local guy has. Check out Viren's intercooler, it's on sale for Christmas. http://www.vsracing.net/catalog/prod...oducts_id=1344
That would go good with your turbo.
no green is offline
post #26 of 113 Old 12-09-2016, 08:18 PM
Addicted to boost
Boosted6's Avatar
User is: Boosted6 is offline
I just looked through some of your pictures on photobucket. Looks like you do nice quality work. I love the attention to details. Looking forward to seeing this build come together.
2001 GMC Sonoma ZQ8 4.3 turbo w/ t56 6 speed
12.6 @ 119 with a 2.3 60' | 480 rwhp 529 rwtq (20 psi)
1991 GMC Sonoma 5.3 turbo
Build in progress...
Pics | Dyno Pull Video
Boosted6 is offline
post #27 of 113 Old 12-09-2016, 08:26 PM Thread Starter
You guys have been a ton of help
no green likes this.
ogoz23 is offline
post #28 of 113 Old 12-13-2016, 09:52 PM Thread Starter
Got the 4l80e build today .. shift kit with Racing clutch.. hopefully it will be plenty strong.
ID:	268665   Click image for larger version
ogoz23 is offline
post #29 of 113 Old 12-18-2016, 04:03 PM
Iroc-10's Avatar
What parts did you use in it specifically? Did you use the HD-2?
Currently Running:
Yank SS3600
Iroc-10 is offline
post #30 of 113 Old 12-18-2016, 11:03 PM Thread Starter
Honestly I'm not sure , I know it has a shift kit and racing red racing clutches im sure is not top of the line but hopefully a little better then factory
ogoz23 is offline
post #31 of 113 Old 12-22-2016, 09:32 PM
Iroc-10's Avatar
I am guessing the manifolds fit because this is a Blazer, however, I don't know for sure, because I don't know if the first gen Blazers have the engine sitting higher, like the second gens? Who can verify?
Currently Running:
Yank SS3600
Iroc-10 is offline
post #32 of 113 Old 12-23-2016, 12:53 PM
Bowtie Til I Die
s10studduts01s's Avatar
User is: s10studduts01s is offline
Actually the factory ones are better due to utilizing thicker steels. The only place I put more clutches than factory was in the direct drum where I put 6 factory clutches instead of 5. I just used .077" steels from the forward clutch pack. The direct is the most common failure but this can be remedied buy doing the dual feed mod. There are different ways to do it. The HD2 kit allows one to do it without taking the transmission appart. Since I have a trans brake from a vendor on ls1tech and was rebuilding anyway I had to do it the other way.
97 rcsb s10 6.0/4l80e w/ turbo...Toy
00 rcsb sonoma 6.0/4l60e...New project
09 Chevy Defender...DD
Looking for used stainlessworks headers
post #33 of 113 Old 12-26-2016, 09:51 PM Thread Starter
Turbo got here ! Wating for my 3200 stall converter and flywheel to start this !!
ogoz23 is offline
post #34 of 113 Old 12-27-2016, 03:55 PM
no green's Avatar
pix or ban
no green is offline
post #35 of 113 Old 12-27-2016, 07:15 PM
Iroc-10's Avatar
Maybe we should change the forum to where your must post pics, and words are optional. LOL
cookmaster301 and no green like this.
Currently Running:
Yank SS3600
Iroc-10 is offline
post #36 of 113 Old 12-27-2016, 07:57 PM Thread Starter
Lol ok here you go ... yea my bad
ID:	269041   Click image for larger version
ogoz23 is offline
post #37 of 113 Old 12-29-2016, 09:49 PM Thread Starter
So I got my JGS 60mm wastegate, funny how this wastegate is just as much as my turbo. $500 bucks!!!
ogoz23 is offline
post #38 of 113 Old 12-30-2016, 11:45 AM
thats why i stuck with vs racing all around. thats crazy
post #39 of 113 Old 12-30-2016, 12:58 PM Thread Starter
Well your truck is no joke I saw your YouTube videos.. so VS Racing is more then good enough.
ogoz23 is offline
post #40 of 113 Old 12-30-2016, 04:31 PM
thanks man. i have always ran cheap wg and bov's. so i will continue on with this build lol
post #41 of 113 Old 01-01-2017, 06:13 PM
Iroc-10's Avatar
I am glad you have done that Barry. I have considered doing so because of you, but a Chinese turbo won't blow up a motor, like a hanging wastegate, so I still have a hard time going cheap on a wastegate. I can see the bov, again, not going to hang a window in the block if it doesn't work, but to me, I just can't pull the trigger on a cheap WG so I get it ogoz23!
Currently Running:
Yank SS3600
Iroc-10 is offline
post #42 of 113 Old 01-02-2017, 06:50 PM
its all good man. i have overboost built into my ms3 pro so that helps. as long as we all get to play in the turbo fun thats all that matters
post #43 of 113 Old 01-04-2017, 08:54 PM Thread Starter
I think I've put this enegine in and out about 7 times.. I think this is my final time .. I didn't account that the 4l80e is so much bigger .. I had to build a custom crossmember because I had to move it back like 6 inches .. I also had to hammer the transmission túnel to make room for the transmission cooler lines.
ogoz23 is offline
post #44 of 113 Old 01-05-2017, 12:54 PM
no green's Avatar
might want to hammer the firewall around the drivers foot, too. mines real close to get that bolt out just above the dowl pin. I think I might even drill a big ass hole there and plug it to reach through with a socket.
no green is offline
post #45 of 113 Old 01-06-2017, 07:11 PM
Iroc-10's Avatar
That sure would be a nice feature! How does that work? Does it use a solenoid or just cut spark or something along those lines? Obviously, a factory ecm doesn't have all that cool shit, but us broke mofo's can't have everything. LOL
Currently Running:
Yank SS3600
Iroc-10 is offline
post #46 of 113 Old 01-06-2017, 07:14 PM
Iroc-10's Avatar
Curious why you didn't use the 90* banjo fittings? It sure does give a LOT more room. I will be doing the 80E swap here soon too, I can't afford to build another 60E just to break it.
Currently Running:
Yank SS3600
Iroc-10 is offline
post #47 of 113 Old 01-08-2017, 11:26 AM
yeah you can do it a few ways. i believe i have mine set to kill boost and spark. you can do ms3 pro from my buddy shannon taylor for about 1350 for a plug and play setup. i despise hptunes and all the credits bs and plus having boost control and everything built into the pro its not all that much more by the time you buy hptuners and a good elec boost controller.
it is a good chunk of change but well worth the money. trust me i feel ya on the money. i have been slowly upgrading mine over the last 5 years. i have a ex wife and 3 kids and work for best buy so i am no big baller i promise
post #48 of 113 Old 01-08-2017, 03:59 PM Thread Starter
If I get ms3 pro do I need to get a new harness ? I just bought my standalone harness
ogoz23 is offline
post #49 of 113 Old 01-09-2017, 06:12 PM
Iroc-10's Avatar
Yes. MS3 pro has it's own harness, and if you want to use that 4l80E with MS3, you need to trans controller also. I think thats another $500. I looked at swapping my setup over when I met Barry down at LS Fest. I may at some point, but for now, I am staying with my harness and my HP Tuners since I already have it, and it works.
Currently Running:
Yank SS3600
Iroc-10 is offline
post #50 of 113 Old 01-09-2017, 08:51 PM
yeah ms3 pro has a plug and play harness. i believe the micro to run the trans is 350ish. i ran a mvb setup in my 80e
