draggin plastic
383 or ls1
I'm going to do a v-8 swap in my 2001 X-treme but I'm not sure whether I want to go with a 383 or an ls1. Emission laws are not a factor in the decision. The truck will not be a daily driver after it is all done. Mostly for show. How do you decide which way to go? Thanks
stroked memba
Re: 383 or ls1
ls1 ftw
Fronkensteen
Re: 383 or ls1
I'd think a ls1 would be the way to go if you going for emissions, theres almost everything available aftermarket to make it street legal with an ls1
Re: 383 or ls1
lsx all the way
Diesel Fan
Re: 383 or ls1
im old school build a nice 383...I built my last 383 and it olny cost me around 3g's to build the motor myself and the truck went 10.7's. Throw a th350 behind it and your set
drag racin > dragin frame
Re: 383 or ls1
<3 redheads
Re: 383 or ls1
werd 383 ftw
Re: 383 or ls1
383, depends though, what mods are done to each?
if you're talking a stock LS1 and a modded 383, DEFINATELY the 383. |
Re: 383 or ls1
Fuel injection! Gas mileage, and many mods are easier to tune for all year use.
I didn't build it for you
Re: 383 or ls1
Compromise?
http://www.dallasexportsales.com/RALS1383.htm |
Re: 383 or ls1
383 ftw
STPSYDR
Re: 383 or ls1
For me, the best thing about an LS-1 is the weight savings, your truck won't be so front heavy, should still handle well, plus there's an exotic-ness about an all aluminum vette motor between your fenders, I start my swap hopefully in fall of this year
Re: 383 or ls1
I guess I fail to understand the question considering you can make a 383 out of an LS1, as I posted in the link above. Just run a 383. Much better performance and "wow" factor. It's easy enough to keep the fuel injection instead of a carb if need be.
MPG is overrated
Re: 383 or ls1
if it's going to be daily, i would recommend staying away from the stroker motors (e.g. 383's) they produce good power, but don't like to idle. which is normally a big factor with a DAILY
Re: 383 or ls1
I think he mentioned that in the first post.
NOW AIR RIDE EQUIPPED!
Re: 383 or ls1
how about a loan and a 402 LSX engine...lol just kidding go with the 383 for cost and the fuel injection for gas mileage
I call her: NIGHTMARE
Re: 383 or ls1
How about an old school 383 stroker built for boost with...say.... a holley stealth ram? and maybe some nitrous with a Y-trim??????
Thats what I plan on in the next 5 years Well....I havnt decided on the exact method of fuel delivery, but its gonna be efi of some sort.http://www.dallasexportsales.com/383485EFITK.htm |
Re: 383 or ls1
if its for show, definately a 383. everyone seems to be concerned about daily driver and gas mileage, but the guy said its for show. i think a 383 is much sweeter than an LS1, and IMO looks better on a show truck.
Diesel Fan
Re: 383 or ls1
what does a stroker motor have to do with idling?
The creeper next 2 you...
Re: 383 or ls1
ls1 from personal experience... infact get the best of both worlds and get a ls2...
RITALIN, IT LOVES ME!
Re: 383 or ls1
um, 5.3 with 355 at the fly on the aeroforce scan gauge. gitting an average 21mpg hwy/city.
so ls1 makes the most sense to me... |
draggin plastic
Re: 383 or ls1
If I decide to go with the LS1, is there anywhere that is known to have an abundant supply of used LS1 engines at a reasonable price? I think a new one is a little out of my price range. I'm in South Carolina and traveling to a reasonably close state is not out of the question. Thanks.....
ɔıɹɔ&
Re: 383 or ls1
Yeah go ls1 or bore an iron 4.8 to a 5.7. weee revs. |
#24 |
Re: 383 or ls1
EBAYDOTCOM.... |
#25 |
Re: 383 or ls1
why does everyone seemed concerned with MPG and such on a SHOW TRUCK. i think a 383 would look MUCH more impressive on a show truck.
#26 |
ɔıɹɔ&
Re: 383 or ls1
i would be more impressed by a show truck that preformed well and got good gas mileage.
#27 |
Re: 383 or ls1
#28 |
Re: 383 or ls1
The LS1 will get more oohs and ahhs at shows.
I'm also wondering what a stroker kit has to do with the way an engine idles. My 383 idles dead on 1000 rpm all the time. |
#29 |
Lifted Member
Re: 383 or ls1
#30 |
Re: 383 or ls1
i dont know... more wieght in the stroke?
#31 |
I'm a huge ass
Re: 383 or ls1
The gas money you will save from an LSx will be more then worth your money for the swap! A 383 would be sweet, but it's just to impractical for a daily.
#32 |
Diesel Fan
Re: 383 or ls1
If anything a 383 would idle better then a motor with small cubes and the same cam. The more cubes usually "mellows" out a cam. If its just a toy save the money you would drop to buy a LS1 and build a kickass fuel injected 383. I like the holley stealth rams
plus with them you dont have to worry about how big a cam you run because of the computer. The computer only operates the fuel injection. Throw a 700R4 behind it and it will get as good gasmilage as a LS1 |
#33 |
Re: 383 or ls1
Rink, my little LT1 is slightly louder than that, and except for a bad set of Comp lifters, it's reliable enough to daily drive if I wanted to do so. Now that the Morels are in place, I just need to fire it up and finish the fuel system. Here's a quick vid of it before the lifter exploded.
Outside The Car - Google Video A 700r4 behind a 383 will get better mileage than a th350 would, but LS1 fuel economy would be tough to match. The lean cruise mode is hard to beat on the highway. |
#34 |
Re: 383 or ls1
#35 |
Diesel Fan
Re: 383 or ls1
this is true but theres a guy in baltimore thats great with tuning EFI so all of us let him do the work for a couple of bucks
I ment that it would be closer then a 383 with a carb and a th350 behind it. The overdrive helps out along with the EFI. I was just throwing a few extra ideas out there |
#36 |
Diesel Fan
Re: 383 or ls1
Set of protopline 220cc iron head i picked up from a buddy $500 Used brodix single plain intake $100 Comp Xtreme Energy solid roller XE292(biggest off the shelf xtreme solid roller) regular base circle cam and springs off ebay $250 New Comp pushrods and steel retainers $100 Comp solid roller lifters, bought em used from a buddy $100 Erson roller rockers $150 new ebay Cloyes Timing set $50 new ebay balancer (summit style SFI approved $250 oil pump, gaskets, bolts, odds and ends $150 or so I had the valve covers, distributor, timinig cover from last motor Only thing i dumped alot of money in which i dont include in the build was my carb. I bought a prosystems 860 carb that was $800 add the prices up right around 3g's, prices may very depending on how you buy everything and who you know. I bought a few used parts and a few parts off ebay. Ebay is your freind ![]() |
#37 |
Diesel Fan
Re: 383 or ls1
#38 |
Strictly Domestic
Re: 383 or ls1
Ls1 Ls1 Ls1 :-)
#39 |
draggin plastic
Re: 383 or ls1
How much different is to rebuild an LS1 compared to an older 350? If I could get an LS1 for cheap but had a lot of miles on it I may want to rebuild it before I install it. Thanks.......
#40 |
Re: 383 or ls1
YES! YES! YES! The LS1 is sexy no doubt, and technology kicks ass. But you cant beat the availability and afordability of a 350 based motor. Plus if you get a nice efi system you can tune it for economy and have a performance mode...... AND my big selling point....pretty much everything I have will bolt up to a vortec 350; AKA my supercharger. |
#41 |
oops i think i dropped it
Re: 383 or ls1
i say 383 if you want to run what you brung if not i say the ls1 its a bit more expensive but they look more like they belong compared to the carburated 350 based motors unless its a first gen then it looks a bit more like it belongs but hell i say go with a 400 small block and do all the same performace mods to it as you would the 383 and get less fuel milage yes but more power
i personally would go with the ls1 it looks better stuffed under the hood but for power i vote 383 |
#42 |
Re: 383 or ls1
#43 |
Re: 383 or ls1
The cost difference to build an LS1 compared to a conventional small block is negligable. What's going to cost you is the accessories, computer, and harness since you have to use specific components where a small block just needs an alternator and a water pump.
FWIW, a small head/cam package on an LS1 is enough to put a full weight F body into the 11's, yet it's usually docile enough for grandma to drive to the grocery store if need be. |
#44 |
MPG is overrated
Re: 383 or ls1
ok guys. i appologize for the idle comment. i hasn't educated at the time. but bang for the buck, go 383.
BTW zerogravity, impressive runs. especially all motor |
