1987 s10 wiring help - S-10 Forum
post #1 of 10 Old 05-03-2012, 11:03 PM Thread Starter
User is: usmc.beast is offline
ok so i got a 5.3l with 4l60e, everything stock, that i put in my s10, i reworked the wiring harness to a stand alone myself, i got the info off of lt1wiring.com, and did the fuse block and everything just like said, everything works on the motor great, what the problem i got is, i have all these wires running from the fuse block inside out through the firewall on the drivers side idk where to hook in for them to work with the motor etc. i couldnt tell u where any of them go, except for the one purple wire that goes to the starter. i need some serious help, this is the last stage of the project and i am stomped on this!
post #2 of 10 Old 05-04-2012, 06:09 AM
User is: Lead foot is offline
Re: 1987 s10 wiring help
Are you going to use factory gauges? If so then you have to wire them to the water temp sensor , oil psi, alternator fuel pump ... What are you doin about your speedometer ??? Those years are still cable driven if I'm not mistaken 91 and above had and electronic speedometer that can be wired in your trans if your using a t56,4l60e etc
post #3 of 10 Old 05-04-2012, 08:37 AM Thread Starter
im going with aftermarket gauges, probably from speedhut, but what im asking, i know all those wires dont go to just the gauges, theres alot there, and the ones that do go to the gauges, which ones are those?, and which ones do i hook up to the fuse block, ignition, and so on
post #4 of 10 Old 05-04-2012, 09:07 AM
John89v8's Avatar
User is: John89v8 is offline
Here ya go just finished wiring my 89
I'm using Speedway as well,I used some of the old wires coming through the firewall to connect my guages (sender to guage), cut them from the inside and wired them to a 10 wire( got it from salvage yard any door connector harness or power window connector will work) connector for all my guages to work, this way if I ever need to remove my guage panel everything is on a connector just disconnect it and pull panel. From the stock harness all I really used was 2 reds to alternator, purple to starter, wiper harness and pink key on to power my Intrepid fans through relays, and of course headlights and horn which I made a seperate harness for, used lights on and high beam signal wires to trigger relays with 12 guage harness I made. Fuel sender I pulled signal from harness coming from rear of truck, Reverse and neutral,( using BM shifter) TCC was all done from inside cab The rest I didn't use, cut them back wrapped them and saved them in case I ever need to add anything else through firewall.
1989 S10 Blazer 2 Dr.
LS2 Iron Block(LQ9/ C6 Parts), 4L80 and Ford 8.8
John89v8 is offline
post #5 of 10 Old 05-04-2012, 09:57 AM
John89v8's Avatar
I'm guessing you have a blue n red computer, pull signal from computer for speedo and tach, guages will have there own senders from Speedway.fuel guage is 0-90 ohm (wire from rear harness Taillight harness ) Fuel pump Walbro?? Run power lead from alternator or fuse block to a relay with pump wire signal from computer, harness you made for engine, then 10-12 guage back to pump and re wire into connecter, and fuse it, use heavier grounds to.
John89v8 is offline
post #6 of 10 Old 05-04-2012, 09:44 PM Thread Starter
i really appreciate it man, ur a big help, tomorrow i am going to go fiddle with this and see what i can come up with like i said thank you man!
post #7 of 10 Old 05-04-2012, 11:19 PM
John89v8's Avatar
Your welcome, if you need anything else get back with me, I have all the schematics and lots of info.
John89v8 is offline
post #8 of 10 Old 05-05-2012, 03:53 AM
***1987 LSX S10***
SoLowXtreme's Avatar
User is: SoLowXtreme is offline
Send a message via AIM to SoLowXtreme
is the schematics the same for the 1987 ? cuz i could really use them...lol
post #9 of 10 Old 05-05-2012, 02:16 PM Thread Starter
alright man, my grandpas shop is closed today but tomorrow, im going to have a whole day of wiring! i will let u know if something doesnt workout,!
post #10 of 10 Old 05-05-2012, 04:17 PM
John89v8's Avatar
What year is your truck SoLow, I have First Gen info. Just looked at the stickies here in Electric, and its basically all in there for wiring, same stuff I have.
John89v8 is offline
