quick switchbox wiring question
ok, my current switchbox, the giant 10 switch one, is wired directly to my valves, so if i take and cut that wiring harness in half, then just strip the ends of the wires and put them into the correct connectors for the new box, that will work right?
ohhhh yeahhhhh
Location: Charlotte(matthews) NC User is: OffLine ![]() |
Re: quick switchbox wiring question
that would be a pain in itself. you ever seen the wiring inside one of those boxes? might be cheaper and easier, to just buy a whole new ten switch box then match the colors back up.unless you are just talking about cutting all the wirings off an old box, then splicing the wires together off a diff box, then yes that will work. but if you mean cutting the wires, then wiring it up to all the switches inside a diff box that would be a huge pain in the ass IMO
no, i mean just cutting the cord off the old switch box and hooking it up to the new box, cause the avs rocker boxes have that little computer or whatever that the wires plug into, i think it will work
Kris from AVS
Grab 12+ Drill Battery Tapped valve wire on positive side of battery You will hear the click or air up/down Once you know what valve it is plug it into your NEW AVS box |
formyadidas!!!
or do what i do and just insert one valve wire into the slots until it is on the right switch, ive had to do this numerous times
or you could just color code the things, after about 5 vehicles you tend to do this... red for fills black for dumps and 4 different colored zip ties. works great
I needs paint!
