problem with doors
Go Back   S-10 Forum > Sponsor Forums > AVS
Old 08-27-2008, 09:16 AM   #1
Not rich, Just broke
Aftershoxxx's Avatar
Aftershoxxx
problem with doors
I've had ur bolt in kit for the second gen s10 with wiring harness and remotes installed for a lil over a yr and a half now and they've worked really well up until just recently. The pass door still works perfect but drivers door seems to stick. hit the button and u can hear relay click and motor click like normal but door doesn't move but about 3rd or 4th time and door comes open like it's supposed to. and i watched the voltage drop when u hit the button and it drops from 14.4 with truck running to 11.9 but pass side it barely moves at all. i was just wondering if anyone had ideas as to what could be the problem.
Old 08-27-2008, 12:36 PM   #2
Kris
AVS_KRIS is an unknown quantity at this point
Re: problem with doors
I will send this to jeff
Old 08-27-2008, 12:40 PM   #3
Moved on to Mazdas
FLGatorsRule's Avatar
FLGatorsRule can only hope to improve
sounds to me like the motor is wearin out and drawin more power to get it to function??? Or a wire is crimped somewhere
Old 08-27-2008, 05:23 PM   #4
***JACOBY***
AVS_JEFF's Avatar
AVS_JEFF is on a distinguished road
Where are you taking this voltage reading from? Your voltage should never go that low. That's waaay below charging. Also, are your doors starting to sag? Can you lift up on the door when it's open and feel any play in it? Let me know so we can get you working 100% again!
Old 08-28-2008, 01:12 AM   #5
Aftershoxxx
aiight i'll check it out asap
Old 08-31-2008, 01:36 AM   #6
Aftershoxxx
well looks like i've got a lil play in the top hinge bushing...i hopefully get a chance to fix it this week weather permitting
Old 08-31-2008, 04:45 AM   #7
***JACOBY***
AVS_JEFF's Avatar
ok, let me know if that fixes it or not.
Page generated in 0.15360 seconds with 11 queries
