airbagparts.com
Instructions For Avs 4 Channel Remote
Re: Instructions For Avs 4 Channel Remote
Since I'm the first poster, do I get the free shirt?
airbagparts.com
Sorry, employees and their families are not eligible.... |
^ that's funny! |
Wow those are easy to follow
blazer is dunnnnnnnnn!
i figured those remote could just be programmed like the other ones, i didn't know it came with it's own brain. i want some of these, but dont wanna spend the $$$
so when you hook it up to the switchbox you cannot adjust while you drive so you wouldnt be able to drop it to drag while your driving...right???
so if you put a switch in between the relay and ignition you could switch on your switchbox while your driving would that work???
airbagparts.com
You can still use your switchbox while driving or parked. The remotes are meant to hook up to the light blue and gray wires from your box which control remote up/dump.
Hope this helps, let me know if it didn't... |
so adding the relay is optional... cause it says adding the safety relay will disconnect power to the switchbox while the ignition key is on...i mean i just didnt want to order and not be able to use my switchbox while im drivin..but if you say i can than hell yea!! thanks sorry for all the ?'s
***JACOBY***
In other words, hook it up as you will, but we have to cover our butts! ![]() |
i gotcha lol thanks!!!
The Masked Magician
Is this the same wiring as the 12 channel remote system? I just ordered the 12 channel and planned on hooking it up to the bags and train horns.
Big Bully
does this work with SPAL poppers?
