#51 |
I SHIT BRICKS
Re: How TO: 1st gen AVS Door Popper kit
just wondering if anyone has used the How to for there install? if so is there anything i am missing of u need more info on?
#52 |
Works too much.
I woulda used it, my instructions got rained on, but it's pretty simple to figure out.
I'd like to see where you're relocating the receiver box and the relay. |
#53 |
Truck #121616
so with the pushers, or poppers... how do they work? is it just a sprung rod that pushes all the time, and when the latch opens, they get to push?
or is it an electric one? or am i thinking of something else? (autoloc??) might consider getting this kit, if im allowed to spend anymore money for a while hahaha! ill just get the basic kit and hook it up to my autoloc brain and stuff. |
#54 |
Works too much.
The poppers are seperate, I had thought they came with the AVS kit I ordered from SD. Reading > me. I'm assuming it's a spring with a pushrod that has constant tension against the door, and then when the latch opens, the doors pop open. |
#55 |
Truck #121616
on the avs website, they have the pushers optional in a drop down box.
#56 |
I SHIT BRICKS
the poppers are basically just a spring. if uwere to run electricity to it.......it would act more like an actuator. the brain box and relays have been located inside behind the panel that is directly under the steering wheel |
#57 |
Truck #121616
![]() ![]() this is an old picture. its since then been cleaned up |
#58 |
Works too much.
I don't even have that panel, it kept getting kicked off, so it stays off now.
#59 |
Truck #121616
the one that hugs the bottom of the steering column? how did it keep getting kicked off?
#60 |
Works too much.
Maybe I'm thinking of the one closer to the pedals..
That one got kicked off, hopping into and outta the truck for work all the time, it took a beating from my work boots. Next time I'm down your way I'd love to come take a look at your truck. |
#61 |
Truck #121616
also, yea, its the closer panels. i kicked mine off too, so i just removed all of them hahaha! |
#62 |
Works too much.
Chestermere, I'm only 30-45 mins away from you. |
#63 |
Truck #121616
do you hang out with any other minitruckers? |
#64 |
I SHIT BRICKS
also make sure that if you are to do it under that panel and you want to run it for remote up and remote down with the ARC 7 series switch box..... you will need to run about 5 relays and this would be a good place to put them also
#65 |
Works too much.
#66 |
Drag-N-Fly Customs
Where abouts is Chestermere? Try
http://www.dragnflycustoms.com/ I'm part of them even though I live by Edmonton. We have some good guys there with lots of knowledge. |
#67 |
Works too much.
I try not to associate with them, I've had problems with some of them before. Or at least guys running their decals.
#68 |
DefiniteObsessions.com
I'll be using this tomorrow. Bought a truck with doors shaved and previous cheap kit fried so I made sure and got a good one.
#69 |
I SHIT BRICKS
good if you have any questions or anything just post them up and ill try to answer them if i am on
#70 |
Got it done with no issues at all, and its a VERY nice setup. A lot of my crew were talking about using them on their dimes.
#71 |
I SHIT BRICKS
good did the thread help you out a lot?
#72 |
The pics did.
#73 |
REMEBER THE OLDSCHOOL
would u be able to fix the pics again that would help greatly! great write up!
#74 |
i second the friendly request...
#75 |
I SHIT BRICKS
yup ill work on it right now...sorry i was organizing the photo bucket........totally forgot about if you move them they dont work....be with you shortly
#76 |
what happend to the pics great how to to bad pics aint working
#77 |
you think of something
i just picked up my avs universal door popper kit and am wanting some tips on installing it so i need those pics son
#78 |
wo my last message was 666 just making it go away lol
#79 |
Just a quick question about the wiring .. I bought the avs set, have the kit mounted to my latch and installed in my door. In my S10 there are no wires to the door from the car body which means I'll have to drill them myself. Does anyone have any pointers on where to drill them?
Thanks, Tom |
#80 |
Thanks again, Tom |
#81 |
Site Sponsor
Best thing to do is right below the hinge, look for a spot on the door that is a single sheet of metal and drill a hole out, put a grommet in to keep your wires from getting cut on any rough edges or shavings and then run your wires through. If you want to get it water proofed you can go down to a junk yard and look for a similar truck with power windows/locks and take the rubber boot from them and just install it on your truck.
