I SHIT BRICKS
How TO: 1st gen AVS Door Popper kit
Alright, I figured that it was about time to do a How-To installation thread on the AVS bolt on door kit for a 1st gen s10. Remember that this is my first actual How-To thread, so bare with me. If there are any additional questions, please feel free to ask. All comments and questions are greatly appreciated.
The first thing that you will need to do is take off the door panels The first step in doing so is taking off the window crank (if you have power windows you will obviously not have to do this). They actually make a tool to remove the “C” clips. ![]() ![]() You can pick this tool up at any automotive store. If you do not have access to this tool then you will have a little more of an issue. I have done them before with a bent flat head screw driver. I do not recommend this only because it can destroy the clip. To remove this clip you simply push the tool between the back of the window crank and the front of the door panel. To access this clip the tool needs to be placed with the window crank handle straight up. ![]() After you remove the window crank you will need to move on to the arm rest. There are 2 screws in the arm rest that you simply just unscrew. After you have those screws out the next step to installing your AVS door kit is to remove the door panel clips. ![]() There are about 8 or 9 clips that look like this. ![]() They are very easy to remove, if you are used to removing them. If you are new to this and haven’t had your door panels off yet, the easiest way that I found to remove the outer clips is with the claw end of a hammer. You will do this just like you are pulling a nail out. After all of these clips are free there is a small piece of plastic that runs up the door pillar (in some trucks there is not this piece). ![]() It is held only by 3 screws. I recommend taking out 2 of the screws and then just taking the plastic piece and slide it so that it is by the window. Take the screws and put them back into the holes in the door so you do not lose them. Now for the real work, if you notice there are 2 holes that look like a socket will fit threw them on the inside of the actual door. The socket size is 10mm. This part I will not completely be able to show you how to do, because my handles are already shaved. But I will step you threw it. If you take the 2 nuts off the door handle from the inside, the handle should be able to slide from the outside. There is still a rod that is connected to them. There is the little black plastic clip that will hold the handle to the latch, remove this clip from the rod. After you do this the door handle is off. This step is an option to keep or not. I decided to not keep it. This step is dealing with the outer door lock. There is a clip on the lock its self it’s very easy to remove. The way that I did it was simply reach your hand inside with needle nose pliers and pull on the 90 degree lip on this clip. As soon as this is off, then the fun begins There are a bunch of little clips. (My father calls them Jesus clips….just because if you lose one you will tell yourself Jesus I wish I didn’t lose that clip) ![]() To remove this clip it’s kind of tricky, if you do not go slowly. The simplest way to remove these clips is to put one of your fingers on the clip, and take a flat head screw driver, pry away from the lock on the flat part of the clip, and slide. GET A BAG OR SOME SORT OF CONTAINER TO PUT THESE CLIPS IN. Now your truck is ready to be welded shut on the outside ha-ha. Onto the actual labor now. There are also Jesus clips holding the rods for the inside door handle and lock to the latch assembly. I found that the easiest way to remove these is to actually unbolt the latch assembly first. ![]() There is your latch assembly. It should be held on by 3 screws witch are a Torx head. 30 to be exact ![]() ![]() Unscrew these 3 and set them aside. The latch itself should just be floating around in your door ![]() ![]() There is a Jesus clip for the inside door handle. With the assembly floating freely it will give you easy access to this clip. ![]() Just snap the clip off and remove the rod from the assembly There is also a clip right above this one for the door lock. Remove that also. After removing the clip the door latch assembly will just be floating in your door completely. What you need to do next is remove the assembly. Not difficult to do at all. Line it back up with the hole that is in the door, reach your hand from the inside of the door push the assembly toward the outer door skin. ![]() When the assembly hits the window track, start to turn the assembly so that the latch is facing the outer skin. I guess the easiest way to explain this is if you are sitting forward in your driver seat looking straight ahead you would rotate the assembly clockwise…….if that makes any sense at all. (If not just ask for more clarification please) Now your assembly is out. ![]() ![]() ![]() You will need to remove the actual interior door handles as well. This is very easy to do. They are held on by 1 nut. It’s a 7mm. just take that off. As soon as you have that removed you just simply hit it from the back forward and it will pop off. ![]() Alright, now you have everything taken out. You will be able to actually see what comes with the AVS kit. ![]() ![]() Both actuators ![]() ![]() Very nice remotes ![]() And of course a bunch of wiring. The wiring seems like it will be difficult when you first take everything out of the box. Let me tell you right now that it is easier then installing a CD player. Everything is plug and go. All of the wires are labeled. Anyways back to the actual install. The first thing that you will need to do is take off the return spring that is for the outer door handle on the latch. ![]() Now you are officially ready to bolt on your AVS kit. This is very easy to do. All you need to do is take the part of the kit and place it on the latch and bolt it down ![]() ![]() You need to bolt the line to the latch ![]() DO NOT MAKE THIS BOLT TIGHT!!!! THE CABLE STILL NEEDS TO BE ABLE TO PIVOT. You’re going to take the black screws that are included in the kit ![]() You will also need to take the small bolts. Tighten everything down. ![]() ![]() ![]() After everything is tightened down, you will notice that the kit includes 4 cables. There are 2 short cables and 2 long cables. ![]() You are going to take the long cables and attach them to the latch. These are also easy to do. It is basically like taking a key and putting it on a key ring. ![]() ![]() Now you are going to take the smaller cables and attach them to the interior door handles, they attach the same way as the ones you have just installed onto the latch. ![]() ![]() ![]() Your full assembly should look like this. ![]() Now you are ready to place everything back into the vehicle There is only one way that you can put this back in. what you are going to do is place the assembly so that the actual latch assembly is facing the inside of the truck. Take the assembly and slide it around the inside of the door skin. As soon as you hit the window track then you just need to rotate the assembly so that you can bolt it back in ![]() ![]() Take your bolts for the latch assembly and tighten them down. The next thing you are going to do is run wires. I chose to do my wiring on my firewall next to my other relays. ![]() ![]() You will have to run the wires that are labeled DRIVER DOOR to the driver door and the PASSENGER DOOR to the passenger side. They only will hook up one way to the kit. After you finish hooking that up, you need to ground the entire system, and run power to, with all the labeled wires. You will also need to hide the wires to make the kit flow with the rest of your vehicle. You also need to hook up the wires from the remote box to the relays. All wires are labeled and very easy to hook up. After all your wiring is hooked up, stand back and press the button on the remote. Everything should be working at this point in time. If everything is working for you then all you need to do is put your door panels back on the truck and then go cruise. You can also hook this kit up to work with your parking lights. It’s very easy to do. Take the white wires that are coming out of the remote box, and splice them into the BROWN wire that is in the lighting harness. This will make it so when you hit the button to open the door your running lights will flash. I would like to say thank you to Kris from AVS for dealing with my calls during this install, and also letting me do this How-To thread. I would also like to give props to the old guy who does the packaging for AVS, for packaging the right parts and making me look like a retard. (Kris knows what I am talking about.) |
Day Dreamin
Re: How TO: 1st gen AVS Door Popper kit
BEAUTIFUL. thanks for this, I just bought the bolt on popper kit.
I SHIT BRICKS
yes sir thats what i am here for.....if you need any more insite or anything like that make sure u hit me up. the kit is SO easy to do it was maybe an hour of actual work and like 3 hours of takin pics lol
Day Dreamin
I SHIT BRICKS
they are very stif if you do them by hand right? mine were. all i did was just clean them with a parts cleaner and then re grease everything. and they are still stiff but not bad and those actuators have a lot of power it has no issues opening mine at all
Day Dreamin
I SHIT BRICKS
if u dont have access to a parts cleaner, i would get a couple of cans of brake cleaner and just spray the piss out of them i used the lithium automotive grese and it worked great
Day Dreamin
I SHIT BRICKS
EDIT TO MY 1ST POST. DO NOT MOUNT THE BRAIN ON THE FIREWALL THE WATER WILL WRECK THE BOX MOUNT IT INSIDE THE CAB mine will be getting switched tonight
I SHIT BRICKS
ne time....is there any other questions that you have? |
Day Dreamin
I SHIT BRICKS
yes anytime
Kris
We do highly recommend locating the relays and brain inside the cab.
I SHIT BRICKS
which i did also state and will also be doing tonight. just for reference since i do not have heat mine will be relocated to where the heatercore was on the truck |
forum idiot
so that is how it looks installed...mad simple...
I SHIT BRICKS
its honestly easier then changing a flat tire lol
US Beer Drinking Team
Location: Lancaster, CA - Southern California User is: OffLine |
nicely done indeed!
I SHIT BRICKS
thank you very much
almost forgot to give that rate button some love lol
heh, won't let me. apparently i have loved your rate button for too long. it's telling me to spread the love lol. Last edited by hamagc : 10-13-2008 at 08:30 PM. |
I SHIT BRICKS
haha well thats a good thing
the only question i have about this is. Do you need to get the door pushers aswell as that kit to get your door to fully open? or does the door just swing open once popped?
Kris
alright, thanks man
#24 |
I SHIT BRICKS
#25 |
I SHIT BRICKS
Sticky????????????????
#26 |
Fvck New Jersey
owned?
nicely done man. |
#27 |
I SHIT BRICKS
whats owned lol and thank u |
#28 |
#29 |
I SHIT BRICKS
anytime any other questions at all?
#30 |
Day Dreamin
new question, where is a good place for the door pusher to be at? The ones that are on my blazer (which came that way) are by the striker bolt (bottom little corner).
#31 |
I SHIT BRICKS
i have a set there i dont really like them there they look kinda out of place. i have my new set here
![]() and i like them they work great |
#32 |
Day Dreamin
Also how did you get the return spring out? |
#33 |
I SHIT BRICKS
just open the door almost all the way and take a hammer and screw driver, and hit it. the spring should just pop out. but if u want help puttin the spring back in ur on ur own lol. i put mine back in and it still works fine
#34 |
Day Dreamin
#35 |
I SHIT BRICKS
what?
#36 |
Day Dreamin
you said the first thing to do is remove the return spring in the latch.
#37 |
I SHIT BRICKS
yes it is......whats the issue with the blazer?
#38 |
Day Dreamin
"Also how did you get the return spring out?"
"sorry about that I meant on the latch." "you said the first thing to do is remove the return spring in the latch." HOW DO YOU DO THIS? |
#39 |
Certified Auto HVAC Tech
good job man...i'm still running the ghetto protocol kit..lol...i plan on switching out to this very soon...thanks for this write up
one more thing...if you guys dont like putting the popper on the doorjamb...heres another spot to put it...it pushes the door MUCH better ![]() |
#40 |
I SHIT BRICKS
#41 |
Day Dreamin
#42 |
I SHIT BRICKS
yep also make sure that brain box is inside the cab where it will not be near the conditions that will fry it
#43 |
Works too much.
I take it your truck had the power doors? I was going to make a How To, but I got sidetracked with having to take my doors off and drill holes for a wire loom to inside the door. ![]() Well done! ![]() |
#44 |
I SHIT BRICKS
all i did was take a battery powered drill and place it inside the door and drill the whole........really simple....never had to take my doors off....and yes i did have poppers before hand but they did not function at all. |
#45 |
Works too much.
My mag drill doesn't fit. Haha.
#46 |
I SHIT BRICKS
well u fucked yourself your drill is to big..........do u have a dremmel? use taht otherwise
#47 |
Works too much.
I already cheated. I bought new doors with power windows, mirrors, and locks, and all the interior paneling on them. Junkyard ftw.
#48 |
I SHIT BRICKS
haha that works to but dremel is cheaper for sure
#49 |
Works too much.
![]() Too bad they're bright red, with chrome pieces on the bottom with GMC JIMMY in big letters, the truck they're going on is grey haha. |
#50 |
I SHIT BRICKS
u cannot be half price day lol
