having prob. with shaved door kit
well i have had my doors shaved for a few months now but my truck was broken into over the weekend and my stereo stolen. i guess when the took all the stereo stuff out the somehow damaged the control box for the door acuators. its all hooked up no loose wires but the doors wont pop. luckily the windows broken so i can still get in and out. the red light on the unit is not on so i am assuming its bad. can i purchase just the control box and two remotes or do i have to get the whole shaved door kit again. need answers asap so i can fix.2002 s10 xtreme extended cab
Burnt out
Re: having prob. with shaved door kit
I need to know this too as my 12 channel remote brain suddenly stopped working after my battery died on me. I tried resetting the brain a few times and it does nothing. Can a new brain be purchased separate or do I have to buy a whole kit again?
airbagparts.com
It sound to me like maybe they damaged or ripped out some of the wires going to the brain or wiring harness. Probably a power wire some where. If you say everything is still all hooked up, you could always just send the brain to us for testing. And to answer your questions of whether you can buy just the remote and brain. Yes, the 12 channel is $70 and our new AVS 4 channel is also $70. Hope this helps...
i actually figured it out it was the power wire to the battery. i t was cut under the dash.
Burnt out
Mine still isn't working and it's definitely not the wiring b/c its getting power to the brain. I ordered a new brain so we will see if that fixes it. It just sucks b/c I have to use the backup wire to get in every time until I get the new brain.
***JACOBY***
Burnt out
This did not work. How can I tell what "sufficient" power is to the brain? I have a multimeter and can test the voltages. |
actually i was about to post a thread about mine... my truck sat for about 2 weeks .. come to find out battery is dead... charged battery everything was working and i go to pop doors and nothing .. i have the 12 channel and the light on the remote flashes like it did but no action ... ?? does it need to be reset somehow or something ?? thank god i can roll my windows down throw my (other ) remote...
please help what could be my problem? |
00 noma
well congrats... lol ..
iunno jsut one of those things ... no heat.... cold weather... me not drive |
00 noma
no but make sure the relays are not loose or anything i had a similar problem but after i jumped the truck once it sat after fixing the relay it was fine(i really need a damn back up switch ) |
okay guess ill look into that tomarrow...
and no i havent get it back on the 5th of january.. and yes ill do it for a fee |
00 noma
i was thinking more on the lines of you helping me out ![]() |
ahh gotcha ... just go buy a new rear end from the junk yard
00 noma
thats 450 and i just bought an axle for 100 |
ok
***JACOBY***
Burnt out
okay thanks ill try that now
***JACOBY***
Burnt out
Hey Jeff,
I got my problem figured out, it was a bad ground. I already ordered a new brain but now I don't need it. Is there any way I can send it back? Would I need to call to get a RMA number? |
#24 |
avsontheweb.com
#25 |
forum idiot
hey its a new guy
#26 |
avsontheweb.com
#27 |
Burnt out
