baggin
Location: Frostburg, Western Maryland User is: Online ![]() |
bad switchbox?
i think i have a bad switchbox but im not sure. i hooked it up and it kept blowing fuses, so i took my DMM and did a continuity test from ground to all the "valve connections" and my front left dump is shorting out. how do you have this wired up? i figure its very simple and an easy fix, is it just a set of relays and momentary switches?
Kris
Re: bad switchbox?
baggin
Re: bad switchbox?
well i decided to open it up and take a look inside. when it was assembled one of the solder joints was pressed into the ground wire, it cut the ground and was shorting out that way. i fixed the wire and moved it out of the way. it seems to be working fine now.
its the 9 switch rocker with keylock. |
bonghits and bodydrops
Re: bad switchbox?
ive been having similar problems...my back left corner slowly leaks in air and its NOT the valve...but i have yet totake the box apart...
Kris
Re: bad switchbox?
I Want To Play A Game...
Re: bad switchbox?
Wow, Kris layin it down. (no pun intended)
