Avs popper wiring
Go Back   S-10 Forum > Sponsor Forums > AVS
Old 08-05-2009, 06:43 PM   #1
white02noma's Avatar
Avs popper wiring
Is this correct?
Old 08-05-2009, 06:46 PM   #2
Re: Avs popper wiring
Cant get it to post. anyone have a diagram?
Old 08-05-2009, 07:44 PM   #3
Site Sponsor
avs_dom's Avatar
Are you saying you have our sdw shaved door wiring kit?
Old 08-05-2009, 08:20 PM   #4
No I have the bolt in poppers. And did a diagram using relays but cant get to post. Can I email it to you and see if its corrects.
Old 08-05-2009, 09:47 PM   #5
Site Sponsor
avs_dom's Avatar
yea email me the diagram, dom@avsontheweb.com
Old 08-06-2009, 07:00 PM   #6
Ok emailed it to you in ppt. last night.
Old 08-06-2009, 07:34 PM   #7
Site Sponsor
avs_dom's Avatar
The middle diagram is for ya, let me know if this helps
Old 08-06-2009, 07:55 PM   #8
The middle one will work with avs s10 bolt in door poppers?
Old 08-06-2009, 08:18 PM   #9
Site Sponsor
avs_dom's Avatar
yes sir
You will hook the number 30 of the relay to the green wire of the actuator and then extend the blue wire of the actuator into the cab and ground it in the kick panel area, if you ground it to the door it could cause problems with the door
Old 08-06-2009, 11:44 PM   #10
Thanks last question do both 85 and 87 get twelve volt constant or is one run for emergency lock out?
Old 08-07-2009, 12:46 PM   #11
Site Sponsor
avs_dom's Avatar
the 12 volt is constant
Old 08-07-2009, 05:54 PM   #12
Yes understand its 12 volt constant but are both used for twelve volt constant or is one used for emergency lock out. Never seen a relay that needs two 12 volt constants.
Old 08-07-2009, 06:36 PM   #13
Site Sponsor
avs_dom's Avatar
One is for the coil and one is for the input, both need 12 volt constants
Old 08-07-2009, 08:55 PM   #14
WWW.CAROLINATRUCKSCENE.
FarEastDime's Avatar
i think this would be a perfect time to upload all the popper wiring diagrams...
and an idea came to me, what about usinga 12 volt bike battery as a secoundary that would only get used for the poppers...
