ARC-9 switches going bad
Go Back   S-10 Forum > Sponsor Forums > AVS
Old 11-05-2009, 10:28 PM   #1
is rockin' out to
tsayyote's Avatar
I picked up this box from a member on here and when I got it, 3 of the switches stuck down like it had soda spilled on it then over time it turned into sludge. I had pm'd Kris a while back and was told I could send it in but it was on my DD so I couldn't. Picked up some rocker switches on ebay and soldered them in myself but a couple months later those are acting up along with 1 or 2 of the original rockers. If pressed all the way down, they do nothing, but if I slowly press the rocker at a certain point the contacts engage inside the switch, but any farther down, the switch doesnt work. What am I looking at price wise to send it in (getting motor swap so I can send it in now) and have all the switches replaced?
Old 11-06-2009, 07:02 PM   #2
airbagparts.com
AVS_JASON's Avatar
Re: ARC-9 switches going bad
I would need to see what condition the box is in to give you a price. Switches run about 3-6 bucks each. Just send it in and I'll have them do an evaluation before they work on it. Then I can let you know what the cost will be.
Old 11-06-2009, 08:12 PM   #3
is rockin' out to
tsayyote's Avatar
i wonder if it would be cheaper for me to just solder everything in myself and just buy the switches from avs. should i post a pic of the box? what would 9 switches run with shipping?
Old 11-10-2009, 06:27 PM   #4
airbagparts.com
AVS_JASON's Avatar
If you do this yourself. It will void the warranty.
Switches run $3 each for 3 prong and $5 each for the 6 prong. I will take care of the shipping for you, if you go this route.
Old 11-10-2009, 11:21 PM   #5
is rockin' out to
tsayyote's Avatar
i've already replaced 3 myself so it looks like i'm outa luck on a warranty so i'll probably be calling in an order for some switches soon. Do you know the specs on the diodes in between a few of the switches? The wires attached to those are fragile and i'm just gunna pull those and the switches out and replace them.
Old 11-11-2009, 12:05 PM   #6
airbagparts.com
AVS_JASON's Avatar
The diodes are already built in to the circuit boards. So I don't know the exact specs on them. I would try taking one in to RadioShack or something like that.
Old 11-13-2009, 12:38 PM   #7
is rockin' out to
tsayyote's Avatar
Ordered! Thanks Jason
Page generated in 0.56134 seconds with 31 queries
[Output: 60.71 Kb. compressed to 57.29 Kb. by saving 3.41 Kb. (5.62%)]
