Aluminum tank dimension?
Hey AVS, im looking at picking up two of your aluminum 5 gallon air tanks for an under bed setup I have planned out, and I need a few dimensions just to confirm everything will fit how I have it planned.
So I'll need the following dimensions: -Height with legs (and ports?) -Length between the legs (from mounting hole to mounting hole) -Length with ports included Thanks a ton for the measurements avs. if everything will fit I'll be picking up a pair and some dominator bags from you guys! |
