WTF Shockwave is a POS
Old 02-15-2008, 09:15 PM   #1
Undecided
redxtruck's Avatar
redxtruck is on a distinguished road
Old 02-15-2008, 09:18 PM   #2
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
Re: WTF Shockwave is a POS
its broken
Old 02-15-2008, 09:20 PM   #3
Undecided
redxtruck's Avatar
yeah. why?
Old 02-15-2008, 10:14 PM   #4
Red -n- Chrome
RedXtreme's Avatar
RedXtreme
those big brakes musta stopped your truck too fast once? haha
Old 02-15-2008, 10:23 PM   #5
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
DJDAudio is a splendid one to beholdDJDAudio is a splendid one to beholdDJDAudio is a splendid one to beholdDJDAudio is a splendid one to beholdDJDAudio is a splendid one to beholdDJDAudio is a splendid one to beholdDJDAudio is a splendid one to behold
The shockwaves where never designed for the punishment us mini truckers put them through lol
I had a set of shockwaves some time ago.
Talk to Tony over at ART about your problem.
Also how old are they? and how/where , where they installed?
Old 02-15-2008, 10:36 PM   #6
Undecided
redxtruck's Avatar
i probably drove on them for about 3000 miles. My truck isn't my daily since i put the brakes/shockwaves on. I also limit myself to laying out, because i read somewhere that will blow the shocks, aswell as turning the rate to the higher levels.
I wasn't sure what was wrong, but I could only get 3/4 of the travel, so i had to take it out. The other one is fine.
Old 02-15-2008, 10:46 PM   #7
bellcranks no more
greencactus3's Avatar
did you have bumpstops and limits to keep from bottoming them and/or pulling them apart?
Old 02-15-2008, 10:51 PM   #8
Undecided
redxtruck's Avatar
what do you have in your truck to keep your shocks from pulling apart... and no i don't have bumpstops because airbags are made to set the truck on the ground
Old 02-16-2008, 12:52 AM   #9
Resident A-10 Crewcheif
ablues10's Avatar
ablues10 is on a distinguished road
Yeah we busted 4 of them on a 300C. Its because the shock retainer thing is made from aluminum and it breaks. I say make them out of stainless or Ti. I hate them. I have 1 good one if anyone wants to buy it lol.
Old 02-16-2008, 01:07 AM   #10
Local Tech
lt1s10onair's Avatar
lt1s10onair is on a distinguished road
i had the same problem with my shockwaves... i spoke to A.R.T. and they told me the "fingers" that line up the factory spring in the frame pocket put a sideload on the shock... ull see like teeth marks on the billet top of it... they replaced mine for free, but i had to cut the fingers out of the frame...
Old 02-16-2008, 01:07 AM   #11
brakenit's Avatar
brakenit is on a distinguished road
No, airbags are made to offer adjustability. Suspensions can be designed to lay a truck on the ground. An airbag is only part of a suspension, and if it's not designed properly for your application it's not going to work very long.
Old 02-16-2008, 06:58 AM   #12
Undecided
redxtruck's Avatar
i have the Air Ride upper and lower control arms, so if it is not designed properly, that is Air Ride's fault.
Old 02-16-2008, 07:42 AM   #13
anti-bama
Layn Dime's Avatar
Layn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud ofLayn Dime has much to be proud of
damn that sucks, been considering them for something
Old 02-18-2008, 11:16 AM   #14
Canyon Carver
s10cyncrvr's Avatar
s10cyncrvr will become famous soon enoughs10cyncrvr will become famous soon enough
They require a limiter to keep them from compressing completly. The same rules apply to any type of shock. If a shock is completly compressed before the frame is on the ground, or the bumpstop is bottomed out, then it will break.
Old 02-18-2008, 11:30 AM   #15
Give me 3 yrs...
JollyRojer's Avatar
JollyRojer is on a distinguished road
looks like u bought somthing, pushed it passed its limits and its broken?
if ur plan is to lay out and uve already got tubular upper and lowers, why dont u just SAVE yourself the money and buy a re6 and mount the shocks urself?
Old 02-18-2008, 12:27 PM   #16
bellcranks no more
i was under the impression that shockwaves were not designed for 'laying out' but i dunno
Old 02-18-2008, 12:28 PM   #17
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
They have limited travel so if you want to drive close to stock height you will not lay out. and if you try it may damage the,.
Old 02-18-2008, 12:28 PM   #18
Give me 3 yrs...
JollyRojer's Avatar
as was I... if your going to spend the money on tubular uppers and lowers, why not just bag and shock mount urself?
Old 02-18-2008, 12:30 PM   #19
Post Whore
Tony@AirRideTech's Avatar
Tony@AirRideTech is on a distinguished road
Without having it here and actually seeing it...it is impossible to tell what happened. In most cases in S-10's that we see them come back off of, they are either driven topped out or they are sideloaded from the bellow hitting or the aluminum top making contact with the coil spring retainer. Give either Jeremy or myself a call down here and we will write you up an RMA number so you can send it back to us so we can check it out and get you fixed up. The Shockwave issue on your 300..... If I had to guess it was from homemade brackets or brackets from someone else. There was a place that was building some brackets before to use our Shockwaves with them and they bound the shock up and put a huge side load on em. We have not had one single set of our new LX platform Shockwaves come back.
Old 02-18-2008, 12:45 PM   #20
Jon@ridetech.com
Juan@AirRideTech's Avatar
Juan@AirRideTech is on a distinguished road
beat me to it
Old 02-18-2008, 09:06 PM   #21
Undecided
redxtruck's Avatar
alright. Now can you comfirm wether or not you can lay out on shockwaves.
Old 02-18-2008, 09:08 PM   #22
Kurrupted Kreations
Garage Customs's Avatar
Garage Customs is on a distinguished road
that sucks!
Old 02-19-2008, 10:35 AM   #23
Post Whore
Sure you can.... if it is fabbed up right and you use the right Shockwave in the right application....... Out of the box, it is not going to put the crossmember on the ground unless you are running a set of 13" Daytons. If your main criteria is to "lay out" the you really should have went with the CoolRide kit with upper and lower arms. The Shockwave is engineered and designed as a completely modular high performance design. So in other words, your truck will handle like it is on freakin rails and you will have complete control over the shock valving to be able to tune for any varying track / road conditions but you will also give up a little bit of stroke compared to the Cool Ride....... The nice thing about the Shockwave being that it is a modular unit and we actually hand build and dyno all of those shocks in house.... they are completely rebuildable. I am actually running our Double adjustable shockwaves in front and rear on my 61.
Old 02-19-2008, 01:25 PM   #24
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I had to cut the coil spring 'fingers' for my shockwave install, it even said so in the directions lol
Old 02-19-2008, 01:38 PM   #25
NObama
2Lo4aFatHoe's Avatar
2Lo4aFatHoe can only hope to improve
Since when does the MacGyver of S10Forum use directions?
Old 02-19-2008, 04:02 PM   #26
Post Whore
he must have been out of paper clips, ball point pens and plastic explosives...........
Old 02-19-2008, 04:46 PM   #27
Undecided
redxtruck's Avatar
I bought them for performance, but I was just wondering for the sake of arguement. And i still don't lay out unless i am at a meet or i just wanna show off.
Old 02-19-2008, 04:51 PM   #28
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
You guys
Its, masking tape And smoke demodulators get it right
Old 02-19-2008, 04:51 PM   #29
Jon@ridetech.com
if you havent given us a call yet give us a call 812 782 2932
Old 02-19-2008, 04:58 PM   #30
