The Masked Magician
will 3 inch blocks fit with airbar
Hello I have the airbar and was trying to get the truck to sit a little lower. I have the bolt in c notches and a set of slated blocks that measure 3 inches at the widest part. Would I be able to put these 3 inch blocks in to get more of a drop? I have heard of people using 2 inch blocks before but never 3. Thanks
Local Tech
Re: will 3 inch blocks fit with airbar
i cant speak for the airbar, but in most cases, all a block will do for you (being bagged, that is) is limit your lift..... is the axle hitting the notch?
The Masked Magician
It's not hitting but it's pretty close
to me the 3 in blocks is over kill. im running only a 1" block with the notches and laid out i have issues with the pumpkin hitting the bed as well as my axle laying tucked up in the c-notch with no where to go, so i cant imaged laying out with 3" blocks what would come up....
