Upper control arms...
Old 03-25-2006, 08:07 PM   #1
Doc
Just another asshole
Doc's Avatar
I have had a set of the upper and lower control arms and have had Zero problems with the lowers.. the uppers on the other hand have not been so kind. I have talked to Tony about them a lil bit and here are the issues..
I had the arms recoated with red (since the truck is....lol)
When i got the arms back from coating, the cross bars were stripped on the end and them lil tiny threaded nuts were trash. I went to the local store and bought regular lock nuts and a rethreader for the shafts. I installed the bushings, which were a huge bitch and got it all together. Less than 1 week later i find that the bushings have slid through and the control arm is rubbing on the outer washer, also was having a problem (which i also heard many people do) with the nuts coming loose at the ends even with red loctite. At that time it wasnt a huge issue, just something i would fix when i had some time, well i havent had much time and still have been driving on them...now that my ball joints are damn near falling apart i figured its time to fix them. I want to send the arms to ART and have them put new bushings and cross bars on them and tighten to what they should be. After i get them back i will drill a tiny hole big enough to install a cotter key to keep them from backing off again. Anyone else having issues with them? Any info from Tony would be awesome as well!
Old 03-25-2006, 09:42 PM   #2
draggin plastic
aquaxtreme's Avatar
Re: Upper control arms...
i had a few problems with the nuts on the ends staying tight at first. and my balljoints are screwed. i havent even had them on the truck but a few months, and the boot could never stay in place, and the grease is all gone. so i dont know what to do about the balljoint,
Old 03-26-2006, 12:38 AM   #3
Afterhours Admin
AVTekk's Avatar
the balljoints will never work out, you need to switch them to a diff style that uses an acordian boot and/or crimped ends. however ive installed quite a few sets and never had problems with the bushings or nuts..
Old 03-26-2006, 02:35 AM   #4
Doc
Doc's Avatar
Thats because you are a GOD at this stuff and i suck....
Old 03-26-2006, 10:24 AM   #5
Afterhours Admin
AVTekk's Avatar
na, i didnt do anything different, at least not that i know of..
Old 03-26-2006, 10:24 AM   #6
Doc
Doc's Avatar
Just giving you shit dave...
Old 03-26-2006, 10:30 AM   #7
I guess you're not showing up at the met today.
Old 03-26-2006, 12:11 PM   #8
Low & Yellow
yell02sonoma's Avatar
So would the power performance balljoints be a good set to switch to?
Old 03-26-2006, 12:46 PM   #9
Doc
Doc's Avatar
those are what im going to go with.. i have only heard good from them..
Old 03-26-2006, 01:44 PM   #10
Low & Yellow
Yep. I would like to switch them out before I install the arms since the art balljoints are crap, so I hear. What's involved in switching the balljoints out?
Old 03-26-2006, 06:23 PM   #11
Afterhours Admin
AVTekk's Avatar
the power performance are good, but spicer are available locally and have the same style boot, i think ac delco is good too. dont use moog tho, they will rip.
Old 03-26-2006, 06:28 PM   #12
Doc
Doc's Avatar
do spicer have the movement that power does?
Old 03-26-2006, 06:34 PM   #13
Afterhours Admin
AVTekk's Avatar
dunno, probably not, but you dont need the increased travel with tubular arms because they have corrected balljoint angles.
Old 03-26-2006, 08:05 PM   #14
Low & Yellow
Why are the balljoints that come with the art arms junk?
Old 03-26-2006, 09:33 PM   #15
If it feels good, Do it!
ss350's Avatar
Just my 2 cents, I put a set of ART upper and lowers on my truck. I used 2B7s w/ a 3" cup fom SD, on 225/45/18s. The upper ball joint was maxed out at 60psi and I was just shy of clearing my fender. The upper ball joint boot was cut the first time I raised it to 60psi. I may be wrong, but it seems like the tubular arms are angled at the plate where the ball joint mounts, to help lay out. If correct, that decreases the amount of ball joint travel, when lifted. I installed a set of power performace ball joints and it didn't seem like they have any more travel. But the boots are sweet and they look like a beefier ball joint. Since my truck has a 3.5" BD and I got a set of 20s, I installed a set of stock spindles w/ 2" cups and @ 70psi the fenders are cleared and the upper ball joints are almost perpindicular with the ball joint mount plate. It lays rocker fine, the camber is just all wacked out. I have some pictures of before and after, if anyone is interested.
Old 03-26-2006, 11:55 PM   #16
Afterhours Admin
AVTekk's Avatar
the only problem with the ART balljoints is they have a normal rubber boot, and it doesnt last, the cup cuts right into it, you need one thats acordian style..
Old 03-27-2006, 01:40 PM   #17
v8 and bagged
tuckn20s's Avatar
where do you get these boots
Old 03-27-2006, 06:21 PM   #18
Low & Yellow
Can you just get a different boot to put on there or does the whole balljoint need to be changed?
Old 03-27-2006, 11:29 PM   #19
Afterhours Admin
AVTekk's Avatar
get them on ac delco, spicer, and power performance balljoints.
Old 03-28-2006, 09:45 PM   #20
ss350's Avatar
NO comments on my 2 cents??????????
Old 03-28-2006, 10:39 PM   #21
Center your wheels!
layinbody31's Avatar
I'd like to see some up and down pics of the truck
Old 03-29-2006, 02:20 AM   #22
Doc
Doc's Avatar
Just for fun i ordered new ART arms from Pork today and the power performance ball joints.. so when i get the new ones in i will ship the old ones to ART and install new cross bars and bushings.
Old 03-29-2006, 11:10 AM   #23
Low & Yellow
Let us know how the balljoint installation goes.
Old 03-29-2006, 09:05 PM   #24
Doc
Doc's Avatar
its easy.. they bolt right in
Old 03-29-2006, 09:06 PM   #25
Doc
Doc's Avatar
Dave, how do you tighten the upper nuts on the cross shaft? i want to do this right this time and not have it all jacked up again?
Old 03-29-2006, 10:44 PM   #26
ss350's Avatar
Have you done this? When I installed the Power performance upper ball joints, they did not just bolt right in. I had to open the hole in the control arm. I have read threads on others doing this also.
Old 03-29-2006, 10:51 PM   #27
Doc
Doc's Avatar
lemme look.. they are right here.lol
Old 03-29-2006, 10:52 PM   #28
Doc
Doc's Avatar
well they fit in there.. but they are snug.. wont have to open them at all
Old 03-29-2006, 11:09 PM   #29
ss350's Avatar
Glad to hear it!
Old 03-29-2006, 11:14 PM   #30
ss350's Avatar
0 Psi, stock spindles 2b7s, 2" upper cups, 245/35?20
Old 03-29-2006, 11:15 PM   #31
ss350's Avatar
70 Psi in the front, still have the old 18s and 2b6s on the back
Old 03-29-2006, 11:18 PM   #32
ss350's Avatar
original balljoints that came with ART arms @ 60 psi
Old 03-29-2006, 11:21 PM   #33
ss350's Avatar
Power performance ball joints @70Psi, same as before raised picture
I still have to weld the pipe in for my tie rod notches.
Old 03-30-2006, 02:19 PM   #34
Center your wheels!
damn thats all the smaller your upper cups are to lay on 20s with arms and stock spindles?!? I always thought they needed to be super short (like 1" tall) but I guess not. Thanks for the pics man
Old 03-30-2006, 04:15 PM   #35
Low & Yellow
So are the balljoints on the lca's any good or should they be replaced also?
Old 03-30-2006, 07:46 PM   #36
s10nospeed's Avatar
damn, I wanted to get new uppers and lowers but idunno now, do you guys think its worth all the hassl?
Old 03-30-2006, 10:29 PM   #37
Doc
Doc's Avatar
My lowers are fine.. they dont get the angles like the uppers..
Old 03-30-2006, 10:44 PM   #38
ss350's Avatar
I agree, I don't see any problems with the lowers.
Old 03-30-2006, 11:28 PM   #39
s10nospeed's Avatar
hmmm . . You guys may be influencing my next purchase
Old 03-31-2006, 03:39 PM   #40
Low & Yellow
Cool. I'll just swap out the upper balljoints then.
Old 03-31-2006, 05:51 PM   #41
digital_xtreme's Avatar
Thanks for the info guys... i'm finishing up my truck when i get home and i'm glad i saw this because i'm going to switch out my upper ball joints then. Just placed an order for the Performance EXTREME upper ball joints.
Old 03-31-2006, 10:25 PM   #42
Dallas@2020Kustoms's Avatar
Holy frickin hacked up frame ! Get out the welder ...
Old 04-01-2006, 01:48 AM   #43
Deadlines are Overrated
wirrrey21's Avatar
are you guys having these problems cause you don't have drop spindles or are the guys with drop spindles having similar problems?
Old 04-01-2006, 12:11 PM   #44
UNDER CONSTRUCTION
Twin-10s's Avatar
i have drop spindles on mine, and have the same problems as doc with the uppers. pulled the rear passenger side bushing thru the arm. destroyed the upper ball joints in 1 day, 10 miles.lol
sent the arm back to art. they took care of it no charge. then i installed power performance upper ball joints and left the nuts on the cross shafts almost loose, no problems yet.
Old 04-01-2006, 05:25 PM   #45
fiveinchbodydrop's Avatar
how bout art putting the new ball joints in to start????
Old 04-01-2006, 06:22 PM   #46
cain's Avatar
if anyone wants a set of air ride uppers..brand new design hit me up in a PM..
Old 04-01-2006, 09:46 PM   #47
ss350's Avatar
Like I said before, I am redoing this truck. I have some 2.5" schedule 80 pipe cut and ready to weld in. Just need to see how much additional meat I have to weld in. Believe me, I will have to add some serious metal to make it right. I also have to cut off the frame horns and align all of the stuff in the front. It is not right. But thanks for noticing.
Old 04-01-2006, 10:09 PM   #48
wirrrey21's Avatar
thanks....guess i'll be purchasing those ball joints also.
Old 04-05-2006, 11:21 PM   #49
Do the upper ball joints get mounted underneath the control arm or above it? The Extreme ball joints i got don't sit in the control arm hole too good so i'm just wondering...
Old 04-05-2006, 11:26 PM   #50
Doc
Doc's Avatar
they go on top, you may have to round out the hole some for them to fit right..
Page generated in 0.68790 seconds with 31 queries
[Output: 210.40 Kb. compressed to 191.57 Kb. by saving 18.83 Kb. (8.95%)]
