Hola Bitches
Side To Side
I bought a truck with the BIG RED system and it's hooked so that I can raise the front and back but I was wondering how I would go about hooking it up to go side to side ...it has the buttons for it and it has another gauge hooked up to ...didn't come with any instructions and am looking for a way to do it ...maybe a link ..some advice ...etc ...thanks
Hola Bitches
Re: Side To Side
I found this
http://www.ridetech.com/instructions/docs/ARC4700e.pdf except the way this setup is made I have 2 switches that work ...I have one switch hitting up or lowering the front and the other does the same for the back ...could I hook everything up so that its the same but the other two switches cover the side to side ...? |
registered s10 sex offender
Location: Indian Trail, NC User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: Side To Side
1st question...is do you have a front sway bar?
Hola Bitches
Re: Side To Side
yes I do but I can take it out ...
Hola Bitches
Re: Side To Side
I know taht I could plumb each bag individually ...but I had wanted to have the front together and move on one switch...the back together and move on one switch ...THAN have the front/back drivers side bags move on one switch ...and front/back pass. side bags move on one switch...any help on that is it possible?
Re: Side To Side
its possible, but i would have just hooked it up individually like 'normal' ya know, then just use two fingers to do combos..
but anyway, to do it youll need to wire in diodes so that electricity doesnt feed back thru the other switch. |
Hola Bitches
Re: Side To Side
you mean I could jsut do it normal and be fine ...OR do "diodes so that electricity doesnt feed back thru the other switch" ..not sure what that is ..sorry man
Re: Side To Side
to wire the other switches, youd have to basically hook up the same wires that are on the switches you are using now, but in a diff configuration. however, you cant do that, because when you hit one switch itll send power thru 3 solenoids instead of 2. to solve this you use diodes (very cheap) to isolate the switches.
or you can just wire up the switches to control individual bags, and just hit 2 at once, unless you only have 4 valves (2 solenoid blocks)..then youre screwed. |
Hola Bitches
Re: Side To Side
well I have the whole big red kit ...so it has what 4 valves right?
Hola Bitches
Re: Side To Side
sorry man I'm new at the bagging ..I am rolling into it but learning thanks for helping but still a bit confused ...I understand the diodes ..that wiring would probably be out of my league ...but to manually put each bag on one valve shouldn't be a prob I would think
Hola Bitches
Re: Side To Side
so that would probably be my best bet right ...just plumb each bag seperately?? ..and they would each be hooked into there own switch
Re: Side To Side
yep, and if you have 8 black things on the red things
then you have 8 valves...![]() |
Hola Bitches
Re: Side To Side
haha ..thanks for putting it in retard lamen terms...lol...I appreciate the help ...the sway bar would have to go right?
Re: Side To Side
wouldnt have to, but getting rid of it will increase the amount of lean you can get.
Hola Bitches
Re: Side To Side
ok ...is it just possible to say screw it and get a switchbox do I don't have to deal with the diodes ...but I wasn't sure if this system is compatible with a switchbox
Re: Side To Side
you could, but i dont really see any reason to, id rather have each switch hooked up to individual bags..
Hola Bitches
Re: Side To Side
gracias amigo
