Jon@ridetech.com
New E3 control system
www.ridetech.com/e3 for more info and videos
Your suspension provides control of your vehicle, but what controls your suspension? We have packed our new RidePRO e3® system with accuracy, repeatability, versatility, dependability, visibility and a wide range of other abilities to give you unparalleled levels of control - all at the push of a button. ALL NEW CONTROL PANEL - Building on the experiences of previous systems, the new RidePRO e3® represents a leap forward in onboard suspension controls, starting with a completely new control panel that is sleeker and brighter. The auto-dimming transflective display is completely visible in the sun and is only 3/8” thick. Interface buttons are backlit and have a distinct “click” to let the driver feel when he has made a change. Two mini USB connections are offered to allow a variety of panel mounting and connection opportunities. ALL NEW ELECTRONIC CONTROL UNIT - The new e3 ECU is faster, more robust, and offers more options to refine your air suspension. In addition to the 3 ride height presets and the “ride height on start” feature, the calibration process, weight compensation, and crossload compensation are now all automatic. If a problem should arise , error detection and troubleshooting menus have been added into the unit to make finding and fixing problems much easier. The new e3 ECU uses M12 twist connections and is now waterproof to allow mounting in any location on the vehicle. Solid state compressor relays are built in to eliminate external relays and wiring. The LevelPro e3 leveling system is compatible with any air suspension and is a great upgrade to your current system.
![]() Last edited by Juan@AirRideTech : 08-19-2009 at 10:36 AM. |
Dime Bagged
Re: New E3 control system
very nice, I tell you what that is my biggest complaint with the rideproe2 you can see crap when the sun is out, drives me nuts. So how easy is this to convert to the new from the rideproe2? And whats the cost of it?
she will lay one day
10 grand lol he doesnt keep up with his section in the forum
Jon@ridetech.com
if you would like to upgrade from the E2 it is a 800.00 upgrade to the e-3
PM me.... |
Tom@LRD
oooo la la. Our shop truck sure could use an upgrade... hint hint
Dime Bagged
Ouch, it might be a while |
Jon@ridetech.com
shoot me a PM
