looking for a the cheapest i can get but great quailty
Old 01-02-2008, 10:43 PM   #1
LosT is on a distinguished road
im 16 i don't know jack shit about baggin a truck.
i weld and my dad helps so i have no problem with a kit that requires welding.
my dad know about the notch but I'm not familiar with it wanna fill me in? thanks
what else do i need to know and what kit would be best for my 02 xtreme
i got 17" rims need any more info to help?
we have a fully garage, lift and such
Old 01-03-2008, 12:17 PM   #2
It really does...
TubbD's Avatar
TubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to all
Re: looking for a the cheapest i can get but great quailty
www.suicidedoors.com
All you need with good prices also. Researching never hurt either.
Old 01-12-2008, 02:45 PM   #3
thanks
Old 01-12-2008, 02:48 PM   #4
ok i wanna get the roadgator kit but i want front and back i dont understand what i need
82-03 S10 rear RoadGRATER system
82-03 S10 front CoolRide w/control arm and bolt-on shock mounts
BigRed 4 way compressor system do i want all three for front and back bags?
i have a 02 extreme
Old 01-12-2008, 02:53 PM   #5
Whood'a Thought
russell's Avatar
russell is on a distinguished road
just get bolt in cups and bags. you gotta trim the spring pocket for clearance. get a vivair comp and 8 valves 4 up 4 down for f,b,s,s,
Old 01-12-2008, 02:53 PM   #6
Whood'a Thought
russell's Avatar
for the front
Old 01-16-2008, 06:05 PM   #7
marolf101x is on a distinguished road
Our kits are all broken down into Front, Rear, and compressor. So for your truck you would want:
Front: CoolRide (bags and cups. you can get tubular upper and lowers if you'd like, or you can use the stock arms.)
Rear: AirBar or RoadGrater (AirBar does not use c notches, RoadGrater does) (a C-notch is where you cut the rear frame above the axle and build or bolt-in a new frame that allows the rear end to travel further, thereby allowing the truck to go lower)
Compressor kit: My 02 X-cab has a 4800L (two 5-gal tanks, two viair compressors, BigRed 3/8-inch valves, LevelPro control system). I mounted the tanks, compressors, and valves under the bed. It's pretty fast on a little truck like a dime, but the LevelPro will get back to preset ride height with no problem. If you wanted a slightly slower system, or one that does not take as much room, you could use a 4100e2 or 4100L (one 5-gal tank, two Thomas compressors, RidePro 1/4-inch valves, E2 or LevelPro control system).
The only reason to have more storage is so you can raise and lower more before the compressors turn on. Since I do a lot of electronic testing I needed as much storage as I could fit.
Page generated in 0.10861 seconds with 12 queries
