#101 |
Re: For those who want pics of Xtreme's with Airbar
just thought i through up a better pic even though it isnt an x but i still am running the airbar...
#102 |
40 oz. of FREEDOM
Looks great man!
#103 |
thanks....
#104 |
I can haz transformer?
hell ya man!
#105 |
thanks tucking22's
#106 |
blacker then black X
for xbowtie...
for your whole setup (airbar.coolride.airmangenment) how much did the cost total out to be? i wanna do my bag setup just like you..i love it. and what are the links off of airrides website of the products you bought? thanks. matt. |
#107 |
The Bowtie Brigade
I have about $3000 in mine.
#108 |
is it possible to run slam bags on the airbar?
ive heard of some running them. |
#109 |
redrider...Did you notch the frame at truck sits real low....Any other site pics with it up and layed out...
#110 |
so does this truck then with the airbar not sit on the ground.
#111 |
yeah i notched my frame with a 1" block to get it to sit as low as it can go(basically lay out on the notch. oh and for the other guy correct this kit does not allow the truck to lay frame
#112 |
I have the same set up in my 00 extreme. the only difference is I added A muscle bar sway bar from ART. It really stifened up my stearing responce and handling. I just thought I would let you know.
#113 |
how much would this kit run? and where would you be able to get it?
#114 |
the airbar runs 995 by itself. u can pick it up from suicidedoors.com
#115 |
I had the air bar on my first truck, it has a real good ride quality.
#116 |
redrider do you have any pics of you set up under the back of your truck?
#117 |
just put up a post of what i should put for air suspension in my s10 def goin wit the air bar and cool ride i got a question how much did u spend on the suspension when u were all said and done?
#118 |
Automotive Renderings
Redrider----your running the airbar with a 2.25 bolt in notch right? Any need for the raised gastank crossmember with the notch? I have an 01 and I know you have a later model but i love the way your truck sits
#119 |
so I was reading your post's about this set up and I have a v8 inmy truck will be getting more wheel hop with set up than the stock motor? or if I install the blocks will it eliminate even though I have all the extra torque and horse power?
#120 |
ok can you do a roadgrater with a stepside bed?
#121 |
The Bowtie Brigade
I don't see why not...You have to cut the bed either way.
#122 |
Registered Newb
A wee bit OT,
but, Would a '94 regular cab, on BFG Radial T/A white letter P225/60R14's lay or come close to laying out, say with a notch and a block to fix the wheel hop with the Air bar? |
#123 |
KeepDreaminXtreme
Xtremebowtie are you running shocks up front or just the bags?
#124 |
The Bowtie Brigade
Yup, I'm running shocks.
#125 |
Registered Newb
![]() All I really wanted to do is be able to raise/lower my truck and drag the rear. Is it possible for the airbar to lay the rear/drag blocks with modifications? XtremeBowtie, your first link in your sig doesn't work.. ![]() |
#126 |
u could probably fab something up to drag... but with the blocks mounted to the rails...i doubt it. i think my frame sits like 4 or 5 inches to the ground.
depends on how tall the blocks are... |
