drag that b$tch!
damit!!!!
well i did my tie rod notch yestereday and today i remover the shock mount from the top of my ART arms so i could put it on the bottom. well i went and tried to see how much more tire i could tuck and **** my spindal hit the bottom tube on the ART top control arm. Ill have pics later but basically the spindal at the back of the top ball joint the edge hits the bottom of the tube on the upper ART arm.....i can use any ideas
Thanks |
Post Whore
Re: damit!!!!
ummm you are at the limits of the range of the ball joint. Are you running a drop spindle or stocker?
drag that b$tch!
Re: damit!!!!
drop and is the anything i can do i was told these things would lay on 20 now im pissed what can i do
drag that b$tch!
Re: damit!!!!
and another question...when i boght them they had stickers on them the uppers i think were backwards cause i couldnt get then to fit nice the way the sticker said but anyways iv driven on them for a year now with no prob till now when i desided to try to lay 20 AND I CANT!!!... so any help would be great tony. Thanks man
Jon@ridetech.com
Re: damit!!!!
drag that b$tch!
Re: damit!!!!
im using bell tech drop spindels
drag that b$tch!
Re: damit!!!!
heres a few pics it hit at the top of the spindel
![]() ![]() ![]() heres the other side and it seams to be doing it even without the tie rod notch ![]() |
UNDER CONSTRUCTION
Re: damit!!!!
the problem is you have the upper control arms mounted up side down. and probably on the wrong sides.
this is a small pic from arts site but should help you. ![]() |
Jon@ridetech.com
Re: damit!!!!
Correct they are mounted upside down and quite posibly on the wrong side, chances are they where labeled correctly. You need to remount them right side up and replace the ball joints.
drag that b$tch!
Re: damit!!!!
now how come u say i have to replace ball joint?
drag that b$tch!
Re: damit!!!!
and yah i check my other post too thanks for all your help everyone i feel stupid now.....
Re: damit!!!!
drag that b$tch!
Re: damit!!!!
i thoght he ment by new ones not change them around.
Jon@ridetech.com
Re: damit!!!!
the amount of stress that has been on them may have prematurely worn them down I think it would be a good idea to replace them.
drag that b$tch!
Re: damit!!!!
Post Whore
Re: damit!!!!
dude...... I agree with Jon.... I would change the uppers and install some new ones in there.... and dont worry man, we may remind you of this but we wont drag you through the mud too bad
Life Begins @ Zero PSI
Re: damit!!!!
i have belltech drop spindles and stocker arms and nothing hits, I was wondering why he was notching the frame? wow, nice to see someone with an eye on here to catch something mounted wrong. I 100% agree with replacing the ball joints.
