Bolt on kit?
Old 02-12-2008, 11:11 PM   #1
IDLE is on a distinguished road
Bolt on kit?
Lookin for a bolt on kit that can handle 400lbs in the bed
Old 02-13-2008, 07:54 AM   #2
dont scare her, shock 'er
kyhombre's Avatar
kyhombre is on a distinguished road
Re: Bolt on kit?
for towing/hauling? laying out? or just getting low???
towing/hauling-the air over leaf load assist kit would work
laying out-roadgrater... but you have to cut a hole in your bed for the notch
getting low-airbar... no cuttin of the frame and still have a full bed uncut.
or airshocks...
but i need more info from ya, to help you out.
Old 02-13-2008, 08:00 AM   #3
HI
Juan@AirRideTech's Avatar
Juan@AirRideTech is on a distinguished road
Re: Bolt on kit?
or airshocks...
Just let me know what your looking for
Old 02-18-2008, 05:41 PM   #4
cUt_sh*t-uP is an unknown quantity at this point
Re: Bolt on kit?
all those systems should handle it, except the air shocks maybe!!!
Old 02-18-2008, 05:46 PM   #5
LXtasy's Avatar
LXtasy is on a distinguished road
Re: Bolt on kit?
I have the road grater in the back of my truck and I have had HVAC equipment in the back.Currently I have about 200Lbs or so of stuff in the rear now, Relocated battery, tools (work and automotive) and some other misc items. No problem at all.
Old 02-18-2008, 05:51 PM   #6
Re: Bolt on kit?
is your bed tubbed and tanks under bed????have you had any problems with the sleeve bags yet??
Old 02-18-2008, 05:56 PM   #7
LXtasy's Avatar
Re: Bolt on kit?
Bed is tubbed and a notch cover. Yes, my 8 gallon tank and valves are underneath. I have had no problems with the sleeve bags, except that with alot of weight I have to add more pressure, which in turns makes it ride alittle rough over some bumps.
Old 02-19-2008, 09:54 AM   #8
Post Whore
Tony@AirRideTech's Avatar
Tony@AirRideTech is on a distinguished road
Re: Bolt on kit?
all of our rear kits are designed to maintain and even "enhance" factory load carrying capabilities. I cant tell you that it will haul more than the truck was designed for because your brakes, axles ect were only designed for X amount of weight but what I can tell you is that you can load that truck to max capacity and inflate it up so it doesnt sag. I wouldnt use a pair of airshocks to do that.
Old 02-19-2008, 04:37 PM   #9
LXtasy's Avatar
Re: Bolt on kit?
I agree. LIke I said. I had no a lick of problems with the bags or the kit with any added weight because of it. I would trust the roadgrater kit holding the weight than a monoleaf and block setup any day of the week
Old 06-03-2008, 05:37 PM   #10
SSdime22 is on a distinguished road
Re: Bolt on kit?
do u have any pictures of this 8 gallon air tank under the bed?
Old 06-05-2008, 08:43 PM   #11
LXtasy's Avatar
Re: Bolt on kit?
Old 06-08-2008, 07:37 PM   #12
Re: Bolt on kit?
well done lol i was thinkin about running two 5 gallon tanks but you got me thinkin
Old 06-08-2008, 08:13 PM   #13
LXtasy's Avatar
Re: Bolt on kit?
Mind you the wiring etc is different now. That was when I removed the bed to clean some things. I have actually been thinking of adding another 8 gallon under there, and 2 viar 450's or so mounted on the side of the frame. (edc now)
Page generated in 0.11753 seconds with 11 queries
