ART arms
can you use a sway bar with these?
The Bowtie Brigade
Re: ART arms
I am.
Post Whore
Re: ART arms
yup.......
Re: ART arms
Re: ART arms
I am also
Next: Exhaust
Re: ART arms
Yup.
Belltech bar on front and rear (silver) ![]() |
PHAT JOE
Re: ART arms
Severed TIES pledge
Re: ART arms
they do look like the stingers
Next: Exhaust
Re: ART arms
Yea, they are 18x7 Boze Stingers.
I Like Fire....HaHaHa
Location: God Damn Garage, STL User is: OffLine ![]() |
Re: ART arms
You can but with an 18" wheel or higher you are really going to start torquing hard on that end-link bolt. If you plan on laying out with an 18" wheel or larger, your bigger problem will be the shock tab hitting the frame. You'll need to cut it off and relocate it to the underside.
In hinde-sight: For the money, I am pissed that ART didn't do something about the shock tab, and that the powder coating it worthless. The damn RG of mine was plastic coated. I will be switching to SD arms STAT when the funds are available. SD learned and corrected where ART fu cked up.................and the powder coating is better. |
Re: ART arms
Re: ART arms
Never Finished
Location: Clinton / Knoxville, TN User is: OffLine ![]() |
Re: ART arms
Mine doesn't hit with a 245/40R18. About the endlinks...you WILL bend endlink bolts. I tried a couple different lengths and they still bent. I made some endlinks with a heim joint and a clevis bolted to the LCA.
Re: ART arms
Are you guy's laying out the skid plate, cause everyone I know of with these arms has the shock tab issue. Hense why SD designed their with it on the bottom.
Re: ART arms
How much for you to make me a set of those? I have been trying to find something similar. Because I am tired of bending mine. ![]() |
Next: Exhaust
Re: ART arms
Re: ART arms
Ahh, then that makes sense now. |
Re: ART arms
i run art upper and lower arms and beltech 2 inch drop spindles i have an o2 extreme blazer i switched to a std s10 sway bar and everyhign cleared
Post Whore
Re: ART arms
dude....... that is a good looking little rig you fixed up there with the sway bar!
