#51 |
I dont know what I'm doin
Re: airbar install
very nice.. making me jones...
want to install mine |
#52 |
Re: airbar install
Hi looks great how does it ride compared to dropped suspension? Do you feel its good set up or practical for a daily driver?
#53 |
got me some 20s
Re: airbar install
mine feels 10X better than just being dropped..and mine has been daily for a year and a half with no problems |
#54 |
In the Works
Re: airbar install
i really like the dash
#55 |
now XTREME
Re: airbar install
what valves are u running on ur airbar?
#56 |
deuce deuce!
Re: airbar install
pics of laid out??
#57 |
ARE YOU F*CKING HIGH?
Re: airbar install
love it, looks great! lets see it throwin some sparks. tehe
#58 |
Re: airbar install
I am working on a manual valve set up just to be different and (so far it is not cheaper this will cost me @ the same as a set of 4 or 6 valves all done) I will post a few pictures when I get it done. I need a raised tank crossmember and will have to fab it up to work with the airbar. I am also in the process on bagging the front with cups and bags from SD so I will post pics probably in the spring.
#59 |
Re: airbar install
if anyone has a used raised tank cross member from SD please let me know.
#60 |
got me some 20s
Re: airbar install
hey man if you get a raised crossmember and it works out good, take some pics and post up, cuz ill be interested too lol..im just waiting for someone to try that and show how..ill probably be having to replace bushings really soon in this thing cuz i looked at it the other day and they're not looking so great
#61 |
Re: airbar install
#62 |
now XTREME
Re: airbar install
#63 |
Re: airbar install
#64 |
Re: airbar install
here was the thread http://www.s10forum.com/forum/f207/cross-member-362274/
#65 |
ML
Re: airbar install
I used the raised crossmember from SD. Just asked them to leave the tabs off and I would weld them on myself. In my opinion it really isn't worth it. It puts alot of strain on the system. That's why I ended up just getting the road grater. Handles way better then the airbar, and I lay out.
#66 |
Re: airbar install
Thanks!
#67 |
Re: airbar install
well just got done baggin the front so here is a few pictures of what I ended up with.
#68 |
Re: airbar install
and now it sits @ 1 inch from the ground in the rear and @ 3/4 in the front. Oh sooooo close :>
#69 |
Bring back *DARK STYLE*
Re: airbar install
Whats left holding it up?
#70 |
Re: airbar install
the front wheels hit the front inner fenders I have to cut them and the tierods hit the frame slightly. In the rear the drive shaft is hitting the stock crossmemeber and the pumpkin is just about hitting the bed floor. so I will have to remove the bed and see what can be done, if it is too much work to do it I will call SD and get their 4 link kit or something.
#71 |
got me some 20s
Re: airbar install
looks good man
#72 |
I like candy
Re: airbar install
installed my airbar last weekend and everything went smooth was pretty easy im def happy with it didnt get to drive it far its snowin hea soo cant wait till i finish the front and start hittin switches, heas some pics from the install
#73 |
got me some 20s
Re: airbar install
looks nice, need some pics with the bed on outside though..but ill forgive you since you said its snowing lol
#74 |
I like candy
Re: airbar install
yeah my driveway is all ice so i wont make it back in the garage lol but its gonna be a while cuz im gonna be doin the front still then gonna put the bed on to do the air management shit but cant wait ill try to get some more pics of the truck with no air in the bags for you guys
#75 |
Jon@ridetech.com
Re: airbar install
looks killer!
#76 |
Re: airbar install
I just picked up a raised gas tank crossmember and I am thinking of modifying to lay frame with this kit.
#77 |
got me some 20s
Re: airbar install
well do it and if it works out let me know cuz i want to too lol
#78 |
Re: airbar install
no prob will post some pic's if it works out. If it cannot be done I am going to sell it.
#79 |
Re: airbar install
hey man what did you make your dash out of? looks badass
#80 |
Re: airbar install
It is made from 2 tubes @ 1.5 or 1 inch and the top is sheet metal welded to the tube and the center is a piece of 16 gauge sheet metal all welded. Then I cut vents in top for heater and got a piece of aluminum and hit it with 1000 grit with a da for a dull finish but swirly and wrapped the whole thing in a soft vinyl . I like it turned out pretty good. I was going for a simple but clean idea. It doesn't have a bottom panel so you can see some wiring and under the dash . I am probably going to rewrap it or I may sell it and section a 1956 merc dash I got laying around. |
#81 |
Re: airbar install
any luck with the cross member?
#82 |
Re: airbar install
Yeah still working on it but I mounted it and cut the clamshell and mounted it to the cross member and the wishbone angle is off from the lower bars the instant center is behind the axle, I am still thinking of ideas to correct it I may have to make the wishbone adjustable. I will post a few pics soon but it is layin on the mounts for the lower arms and I bagged the front so it lays out as well.
#83 |
Re: airbar install
ok keep us posted on it....
#84 |
Re: airbar install
#85 |
Re: airbar install
here is the 2 angles I am talking about (instant center) I think they are too far apart
![]() ![]() Last edited by m007gunit : 03-04-2009 at 11:59 PM. |
#86 |
Re: airbar install
#87 |
Re: airbar install
#88 |
Re: airbar install
very interesting....thats some mad angle there
#89 |
Re: airbar install
#90 |
got me some 20s
Re: airbar install
looks nice, keep us airbar guys posted! lol
#91 |
V8 with bags
Re: airbar install
your going to have to make your forward wishbone mount the lowest part of that x-member. Maybe lay the truck out, and move the wishbone mount as low as you can get it before it touches the driveshaft. B/c with those angles its not going to work well
#92 |
Re: airbar install
I know I don't like them at all I have another idea and Currently waiting on parts from SD when I figure more shizz out I will post the pictures. I have a possible way to make the angle way better. |
#93 |
Re: airbar install
#94 |
Re: airbar install
I got some metal today to correct my angles and I talked to dlynfrms10, and he helped me out with a few things and I will post some pics later.
#95 |
Re: airbar install
"I installed a 2 inch block and the wheel hop is almost gone I need to change pinion angle and play with pressures now but without the block I did not like the height it rode(I like to ride low)"
I just purchased an AirBar and havn't had time to mess with it yet, but I was thinking about adding the 2 inch blocks to get the 1 inch off the ground that I am looking for. First question, with 2 inch blocks arn't your lower bars extremely low to the ground (below your scrub line?) Second question, how bad does it hit the fuel tank cross member and when (fully deflated or before it fully deflates)? |
#96 |
Re: airbar install
umm i would just go with the one inch block and the 2.25" notch....imo
#97 |
Re: airbar install
plus with the tank in the stock location I put a decent size dent in it when pulling into work so this is why I chose to raise the tank. As far as my lower bars being too low never had a problem. |
#98 |
Re: airbar install
Anyboy else have a problem with the upper bag mount not being "bolt-on?" I believe I am going to have to cut my factory shock mounting tabs.
#99 |
Re: airbar install
#100 |
Re: airbar install
