sd uca's
my question is , is there any benefit being static using these arms , are they longer to help correct neg camber or anything like that ????
jim |
Re: sd uca's
there are no benefits suspension-wise for a static truck. if you had a v8 and a drop, then theyd be very helpful in header clearance, but thats it.
control arms arnt going to change your camber curve, the only product that will help there are spindles. |
bellcranks no more
Re: sd uca's
V8 with bags
Re: sd uca's
yep, speedwaymotors sells them, and are fabulous to deal with
Re: sd uca's
thats because theyre taller and increase the distance between the balljoints, giving you more camber. however, using them will have a negative effect for your truck unless you are roadracing it.
Re: sd uca's
V8 with bags
Re: sd uca's
im not sure, just email them, tell them you have an s10 or a g-body, its the same shit
Re: sd uca's
