longbed and bolt on 3 link compatibility.
Go Back   S-10 Forum > Sponsor Forums > Suicide Doors
Old 01-19-2007, 02:09 AM   #1
bellcranks no more
greencactus3's Avatar
http://www.s10forum.com/suicidedoors...5_link_install
mentions that the SD.com 3link wont work with longbeds?
if so, are there any longbed compatible ones?
Old 01-19-2007, 10:23 AM   #2
Afterhours Admin
AVTekk's Avatar
Re: longbed and bolt on 3 link compatibility.
from what other people have said, the 3-link works, but the 5-link rear crossmembers have to be repositioned, but you can make it work. i know theres a couple people on here with longbeds and 3-link.
Old 01-19-2007, 10:28 AM   #3
PUNISHING GROUNDS
got_u_sick's Avatar
got_u_sick is on a distinguished road
Yup...3 links work fine, thats what I'm running. The 5 link is a different story, like he said, you could probably make it work.
Old 01-19-2007, 11:56 AM   #4
bellcranks no more
alright cool. i thought i saw another thread like this before, but it went bye bye...
so the 3link would still be a complete bolt on?
and anyone have pics of how the 3link looks on a longbed frame without the bed?
Old 01-19-2007, 12:10 PM   #5
PUNISHING GROUNDS
got_u_sick's Avatar
If you get the completly bolt on kit it will. If not, you will just have to weld on your lower tabs to the axle. Heres a couple pics, not the best but the best I can do at the time.
Old 01-19-2007, 12:55 PM   #6
bellcranks no more
thanks. is the gas tank moved farther back than the stock location then?
Old 01-19-2007, 01:01 PM   #7
bellcranks no more
also, i was looking the SD.com website, and saw the bolt on 3link kit comes with brackets for the front end of the lower bars, but the weld on 3link kit doesnt.. at least in the pictures... so where do those get mounted for the weld on kit?
and the entire upper link setup is the same exact thing between the bolt on and weld on?
Old 01-19-2007, 04:37 PM   #8
Afterhours Admin
AVTekk's Avatar
yes the upper pieces are the same. for the weld on kit, you use your factory leaf spring hangers relocated rearward. the gas tank is further away from the cab on a longbed than it is on a normal truck.
Old 01-19-2007, 09:49 PM   #9
PUNISHING GROUNDS
got_u_sick's Avatar
The gas tank does sit farther away from the cab on a long bed, but when you put the new x-member in, the tank still stays in the stock location...other than it being raised up. You dont have to move it foreward or backward at all.
Old 01-20-2007, 05:08 AM   #10
bellcranks no more
ah cool!. i really really wanna lose the leaf setup.. but i cant weld... and the price difference is pretty big too..
Page generated in 0.10234 seconds with 12 queries
