Here is a tip fellas! Cross Shaft swaparoooni!
Go Back   S-10 Forum > Sponsor Forums > Suicide Doors
Old 12-05-2007, 12:19 AM   #1
I AM A LUNATIC!
suicidedoors.com's Avatar
suicidedoors.com will become famous soon enoughsuicidedoors.com will become famous soon enough
hehe!
this is a little how to i put together showing how easy it is to swap a stock s10 cross shaft over to a SD upper arm.
Step 1
take the nuts off the cross shaft. an impact works like a champ! you might have to clamp the cross shaft in a vise to keep it from spinning.
your gonna need a BIG FUKKN HAMMER and a BIG FUKKN CHISEL to remove one of the stock bushings. if you have an air chisel try that first.
here we are knocking out the stock bushing
you want to work your way around the bushing flange so that it comes out evenly. this will keep it from getting in a bind. you have to beat the holy hell out of that thing to get it out. it is a whole lot easier with 2 people.
here you see the bushing is removed. you only have to take out 1 per arm, so you only have to go through hell twice, not four times.
if your cross shaft is all rusty make sure you clean it up and paint it or something. dont half ass it.
BAM!!!
here is what you get with the new $179.99 upper arm kit. minus the cross shaft and nuts. we even send you a inner bushing install tool! weeeeeeeee!
knock in JUST ONE bushing first.
then knock in the inner sleeve.
here is the inner bushing pressed in all the way.
put one of the small washers on the shaft and slide it through the bushing you just installed.
here is what you should have so far.
install the second small washer on the cross shaft.
knock the second poly bushing in place. make sure it goes all the way down.
install the other internal bushing sleeve.
we include this piece of tube to help you install the last internal bushing. with the cross shaft in the way its a pain in the ass without this little piece of tube.
you are almost there!
the big washers go on next.
holy shiit! the best arms ever made!! IMO haha!!!
any questions?
Old 12-05-2007, 12:23 AM   #2
Tim99Zr2's Avatar
Tim99Zr2 will become famous soon enough
Re: Here is a tip fellas! Cross Shaft swaparoooni!
you didnt paint your cross shaft like the directions said... you fail!
nice products
Old 12-05-2007, 12:26 AM   #3
I AM A LUNATIC!
nice products
i took it apart and did it after the install. i like to put myself through hell as a disciplinary tool.
Old 12-05-2007, 12:30 AM   #4
On Vacation
01_STL_X's Avatar
01_STL_X is on a distinguished road
Quote: Originally Posted by suicidedoors.com
hehe!
BAM!!!
But as you can see there is a huge difference. I will definitly be getting these soon!
Old 12-05-2007, 12:39 AM   #5
Tim99Zr2's Avatar
oh, well you did a good write up anyway!
now get makin stuff for us lifted guys.... maybe like lift spindles..
Old 12-05-2007, 01:11 AM   #6
Banned
sws10 is an unknown quantity at this point
awesome, I bet you make some dough off of this deal
Old 12-05-2007, 01:13 AM   #7
brakenit's Avatar
brakenit is on a distinguished road
Nice writeup, now start making parts for Colorado's damnit!
Old 12-05-2007, 01:15 AM   #8
S.I.C.
KENNYMO's Avatar
KENNYMO will become famous soon enoughKENNYMO will become famous soon enough
do i have to have bags to run this? or can i use it with my static?
Old 12-05-2007, 01:26 AM   #9
I AM A LUNATIC!
you can use it with your static.
Old 12-05-2007, 01:35 AM   #10
PPG sprayin' member
downtoearth's Avatar
downtoearth is an unknown quantity at this point
Air chisel FTW!
I usually end up with a bum hand when I get a chisel and hammer in my hand. lol
Old 12-05-2007, 01:42 AM   #11
S.I.C.
KENNYMO's Avatar
SCORE. ill be ordering one in about a month
Old 12-05-2007, 10:16 AM   #12
It really does...
TubbD's Avatar
TubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to allTubbD is a name known to all
Oh baby, thats sexy. 200 bucks eh.....hmmmm....
Old 12-05-2007, 10:48 AM   #13
Afterhours Admin
AVTekk's Avatar
Tip: If you don't have a chisel, and don't care about the stock arms, you can cut the end of the arm off at the dotted line:
Old 12-05-2007, 12:29 PM   #14
damned 4banger
Noremac's Avatar
Noremac is an unknown quantity at this point
ok, now i am going to have to buy a set.... damn you guys lol j/k, you keep it up, and make it easier/cheaper on us!!!!
Old 12-05-2007, 08:29 PM   #15
Groundd Kustoms Sales Rep
Innis's Avatar
Innis is on a distinguished road
nice cant wait for these, gonna be gettin a double order from canada come the new yr
Old 12-05-2007, 08:46 PM   #16
registered s10 sex offender
orangesonoma's Avatar
orangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud oforangesonoma has much to be proud of
Old 12-09-2007, 11:56 PM   #17
NT LO ENF is on a distinguished road
Whats the wait time in these? Could i install the chrome cross shaft instead. And i assume you can powdercoat them?
Old 12-10-2007, 12:11 AM   #18
Afterhours Admin
AVTekk's Avatar
at that point youll be buying the normal control arms, they all take about 2 weeks to receive, 4 weeks for powdercoated.
Old 12-13-2007, 08:15 AM   #19
Wears Black Shirts
RacerXS10's Avatar
RacerXS10 is on a distinguished road
Nice. I would apply some grease. Would make assembly easy and reduce the risk of squeeks.
Old 12-14-2007, 03:49 AM   #20
PHAT JOE
blazerida88's Avatar
blazerida88 is on a distinguished road
nice write up jason, so when will u have the xcab keychains?
hahahahahahahahaha
sorry
Old 12-15-2007, 10:34 PM   #21
chumpchange's Avatar
chumpchange is on a distinguished road
what size are the bushings you use on your UCA's? i ordered 2 inch to make mine and the only problem is the metal sleeve wont fit over the stock cross shaft. do you have a special sleeve that you are using for arms that has a larger hole that i can purchase?
Old 12-15-2007, 10:40 PM   #22
I AM A LUNATIC!
yeah, its special everything.
Old 12-16-2007, 05:38 PM   #23
can i buy the parts?
Old 12-17-2007, 12:53 AM   #24
I AM A LUNATIC!
yeah
Old 01-26-2008, 07:06 PM   #25
Good Bye SonomaST
91sonomast's Avatar
91sonomast is on a distinguished road
BAHAHAHAHAHAHAHAHAHAHAHAHA, i seem to be doing that alot here lately, it works quite well doesnt it?
nice little how to man
Old 02-04-2008, 11:50 AM   #26
Mr. Token Black
chvys10's Avatar
chvys10 is on a distinguished road
Anybody do this yet..... any pro's or con's??
Old 02-18-2008, 08:58 PM   #27
feenin' for more psi
SCOOTER77's Avatar
SCOOTER77 is an unknown quantity at this point
do those use stock style upper ball joints?
Old 02-18-2008, 09:01 PM   #28
PPG sprayin' member
yes
Old 04-04-2008, 04:28 PM   #29
Frame Laying Member
GCash's Avatar
GCash is on a distinguished road
Just got mine in the mail today, they look sweet, hopefully i'll get them on my frame 2nite
Old 04-04-2008, 04:32 PM   #30
Frame Laying Member
GCash's Avatar
Am i able to buy new nuts for the crossshatf? what size are the threads?
Old 05-03-2008, 03:01 AM   #31
Its that dam ADD!
Forklift's Avatar
Forklift will become famous soon enough
my dad taught me with an air chisel, but thanks for showing these boys Jason, great tip.
Old 05-03-2008, 03:14 AM   #32
Frame Laying Member
GCash's Avatar
mine came out easier out of the stock control arm than they did when i was taking the SD arm back apart to send it to the coater lol
