98+ flasher/relay mod for the fast flash
Go Back   S-10 Forum > General Tech > S-Series How-To > Misc How-To
Old 11-11-2008, 10:44 PM   #1
forum idiot
orangesonoma's Avatar
now i am not going to lie.. i did not come up with the flasher/relay mod.. Zeeke98 did and showed me...i wish i did..but here we go...
but here are the pics i just took of me doing it..
here is the unit
use a small screw driver to pry open the case..there are spots on both sides to pry
once you get it open it will look like this
i am pointing to the leg on the ic chip that has to be removed
with the edge of the razor put the end under the leg of the resistor...and apply light pressure to pop the leg up...you can also use a fine tip solder iron to heat up the solder and then pry it up...but i did this with a razor
snap the cover back on and you are good to go...
on 98+ s-series this is located behind the glove box door on the passenger side...it has a small green strap holding it in..push that aside and pull the unit out.
Page generated in 0.55380 seconds with 31 queries
[Output: 40.89 Kb. compressed to 39.63 Kb. by saving 1.26 Kb. (3.09%)]
