EGR Replacement How-To
Go Back   S-10 Forum > General Tech > S-Series How-To > Drivetrain How-To
Old 10-11-2002, 07:55 PM   #1
pyros46290's Avatar
This is a step-by-step how-to on replacing your EGR valve. If the EGR is faulty it usually just gets stuck and will throw a code (code #???). The engine will run like poo and idle poorly and stall ocasionally. If the EGR is just stuck, sometimes you can get away with just hitting it with something to knock it loose. This will work temporarily but you will need to replace it eventually.
Old 10-11-2002, 07:57 PM   #2
pyros46290's Avatar
Tools needed: 8mm wrench, 14mm wrench, straight blade screwdriver, 10mm & 13mm sockets, extension, swivel, ratchet, and a magnet just in case
Old 10-11-2002, 07:59 PM   #3
pyros46290's Avatar
This is for the CPI motors (VIN W). This vehicle is a 93 olds Bravada with 4.3L V6
Old 10-11-2002, 08:00 PM   #4
pyros46290's Avatar
pic for above post
Old 10-11-2002, 08:03 PM   #5
pyros46290's Avatar
Step one is to remove the intake tube going into the throttle body. There is a connector plugged into the tube, so you will need to disconnect that and pull the entire tube out to gain access. The EGR is located here, underneath the throttle body.
Old 10-11-2002, 08:06 PM   #6
pyros46290's Avatar
Next you will need to disconnect the electrical connecter that is connected to the EGR. To remove the EGR from the engine, remove the bracket that is bolted to the back of the a/c compressor. There is a 14mm nut and a 13mm bolt.
Old 10-11-2002, 08:08 PM   #7
pyros46290's Avatar
With the bracket removed you now have an easy way to remove the EGR valve. Now, remove the two 10mm bolts that hold the EGR to the engine.
Old 10-11-2002, 08:11 PM   #8
pyros46290's Avatar
The EGR can now be pulled out with a little playing. If you inspect the EGR you will notice that there is a valve that acceps a torx bit. This is the valve that gets stuck. Notice the valve on the left is stuck, while the new one is not.
Old 10-11-2002, 08:12 PM   #9
pyros46290's Avatar
Part numbers for the new EGR valve and gasket (AC DELCO)
Old 10-11-2002, 08:14 PM   #10
pyros46290's Avatar
I hate you, old EGR.
Old 10-11-2002, 08:17 PM   #11
pyros46290's Avatar
This is what the new EGR looks like. Installation is reverse of removal. Be sure to put the new gasket on. You may need a dab of grease or something to help keep it in place. This is where the magnet will come in handy just in case you drop one of the bolts. After everything is back together, go ahead and disconnect the battery for a minute or two. This will clear the code from the computer. Reconnect the battery and re-set your presets on your stereo.
Old 10-11-2002, 08:51 PM   #12
pyros46290's Avatar
Remember to recycle all used packaging when done!
Page generated in 0.07630 seconds with 29 queries
[Output: 78.22 Kb. compressed to 72.65 Kb. by saving 5.57 Kb. (7.12%)]
