Swapping Seats
Go Back   S-10 Forum > General Tech > S-Series How-To > Interior How-To
LinkBack (2) Thread Tools
Old 12-13-2002, 07:10 PM   2 links from elsewhere to this Post. Click to view. #1
drag~N~spark
DropindaS-Mini's Avatar
Swapping Seats
Tools needed are a 3/8" socket driver and a deep wall 15mm socket, and a #2 phillips head screwdriver..
Total nuts unbolted amount to 8-15mm
Total #2 phillips head screws amount to 2
Pic's displayed are shown in order on how to take seats out.
Total time a beginer 30min.
Total time a pro. 10min. or less.
Now when u have the seats unbolted, lift up over the ends of the bolts mounted in the floor and be carefull not to hit the trim,dash,and most importaint the body.
When re installing seats, place seats back in over the floor mounted bolts and bolt back down. Be carefull not to over tighten the nuts or u will strip the threads.
A helpfull hint...
After the seats have been taken out do not re adjust the position of the seat, or u will have trouble remounting them.
Old 12-13-2002, 07:12 PM   #2
drag~N~spark
1 move seat up and push back part forward.
Old 12-13-2002, 07:13 PM   #3
drag~N~spark
2 use the #2 phillips head screw driver and un screw it.
Old 12-13-2002, 07:15 PM   #4
drag~N~spark
3 pull on this there is a clip that pops out
Old 12-13-2002, 07:15 PM   #5
drag~N~spark
4 move plastic panel to the side.
Old 12-13-2002, 07:16 PM   #6
drag~N~spark
5 take the 3/8" socket driver and deep wall 15mm socket and un bolt the nut.
Old 12-13-2002, 07:16 PM   #7
drag~N~spark
6 do this again on the other side of the seat.
Old 12-13-2002, 07:17 PM   #8
drag~N~spark
File Type: jpg drivers side take out 6 ready for take out.jpg (30.0 KB, 2372 views)
Old 12-13-2002, 07:18 PM   #9
drag~N~spark
8 now move to the front 2-15mm nuts and unbolt them.
Old 12-13-2002, 07:18 PM   #10
drag~N~spark
9 lift seat up over the mounted floor bolts and remove seat.
Old 12-13-2002, 07:20 PM   #11
drag~N~spark
Old 12-13-2002, 07:21 PM   #12
drag~N~spark
Old 12-13-2002, 07:21 PM   #13
drag~N~spark
12 move seat forward
Old 12-13-2002, 07:22 PM   #14
drag~N~spark
13 use #2 phillips screw driver and un screw it
Old 12-13-2002, 07:22 PM   #15
drag~N~spark
14 pull on this, there is a clip that pop's out
Old 12-13-2002, 07:23 PM   #16
drag~N~spark
15 move plastic panel to the side.
Old 12-13-2002, 07:23 PM   #17
drag~N~spark
Old 12-13-2002, 07:24 PM   #18
drag~N~spark
17 take the 3/8" socket driver and deep wall 15mm socket and un bolt the nut.
Old 12-13-2002, 07:24 PM   #19
drag~N~spark
18 do this again on the other side of the seat.
Old 12-13-2002, 07:26 PM   #20
drag~N~spark
19 now move to the front 2-15mm nuts and unbolt them.
Old 12-13-2002, 07:28 PM   #21
drag~N~spark
20 move the back part of the seat forward and lift seat out.
File Type: jpg pass side take out 7 seat ready for take out.jpg (28.3 KB, 1701 views)
Old 12-13-2002, 07:29 PM   #22
drag~N~spark
21 seat lifted up and over the floor mounted bolts, and removed.
File Type: jpg pass side take out 7 seat taken out.jpg (26.9 KB, 1901 views)
Old 12-13-2002, 07:29 PM   #23
drag~N~spark
22 seat placed in bed, or where ever u want to put it.
Old 12-13-2002, 09:52 PM   #24
drag~N~spark
23 Seat's taken out.
Old 12-13-2002, 09:55 PM   #25
drag~N~spark
Tool's used
3/8" socket driver with a deep wall 15mm socket, and a #2 phillip's screw driver.
Old 12-13-2002, 09:55 PM   #26
drag~N~spark
DONE
Thats all there is to it. I hope u can learn from this, its very simple and actully kinda fun if ur into pullin things apart!!
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f200/swapping-seats-23754/
Posted By For Type Date
natewilkinson's bookmarks tagged with This thread Refback 10-12-2007 06:39 PM
Pages tagged with This thread Refback 09-30-2007 05:39 PM
Page generated in 0.65632 seconds with 32 queries
[Output: 129.27 Kb. compressed to 117.70 Kb. by saving 11.57 Kb. (8.95%)]
